Results 1 to 24 of 24
Thread: All AM2X2 Junkies , AMD OcHolics pssssst...CCB8F-0720XPMW
Hybrid View
    Jul 2007
    Talking All AM2X2 Junkies , AMD OcHolics pssssst...CCB8F-0720XPMW
    Ok lets get busy. Ive always liked AMD and will never go Intel . The last Month has been Kinda hectic looking for the best OverClockable X2 for AM2.
    After buying a 5600+ and CrossHair and couldnt Oc worth beans cuz of a crummy Bios at the time .I returned my CrossHair for a M2N32 wifi DeLuXe . It made my day when my 5600+ hit 3.1ghz on Air! It took alot of tweaking . The Cpu multis and the memory controler would act kinda funny. I figured it was the max for the X2. No way , I found that the TRC for memory should be run @21 to 25 which makes the memory the most stable. I also found that Asus boards like 3000Ht . I always wanted more ,so i picked up a BigTyphoon 120 heatsink thinking id only get to maybe 3.15ghz or 3.2ghz.Turns out the F3's whole problem is the memory controler not staying cool even if the CPU only loads to 47c! After a good lap job on the Heatsink/IHS not on meIt did a whopping 3.3Ghz at 25c idle and 46c load.
    Like most Overclockers i wanted more! Just remeber one thing ,"iT aInt BrOke Till yA FixeD iT"
    I became wise and discovered that since i removed my I H S from my Orleans 3200+ it wopped out a nice 2.8ghz on Air! I felt why not unlid my 5600+. I cut the glue just fine , even read a post that some of the I H S's have lots of goop and may appear stuck after cutting the epoxy/glue. I was at the point where it was cut but not off. A lil Twist here and There and Crack it was off! It felt like it came off easy even though i heard the cracK SOund .As i flipped her over i could see the wafer under the core lid They are soldered on,did i say they are Soldered on!The 5600+ now a simple reminder " Shoulda left well enuff alone!"
    Well before she broke i took a screenshot and have a batch /stepping #
    5600+2.8@ 3.3Ghz = CCB8F-0711TPMW
    So now what would you do ? I know lets buy a 6000+ why not! I called numerous places and kept bugging people to check stepping numbers for me .They thought i was crazy. I just wanted best stepping if im gonna waste $250.00 on achip to Oc the u know what out of it. It came down to this , a few people i know that work @Frys and Microcenter let me know when the new arrivals were gonna be in. I then went down and read the batch#'s on the chips for new stepping and 42 of th 61 chips i had checked all had the newest stepping.
    6000+ 3.0@3.5 ghz and Higher= CCB8F-0720XPMW....
    Me and a few friends grabbed Three 6000's and they are all above 3.5 on Air or 3.6 and Higher on water !
    Yes i Know that stepping isnt a garentee, But having the same stepping on three different chips and clock @Over 3.5Ghz and its 90soi makes me look for best stepping!!!!!!. So there@$169.00 each Now and i Paid $250 for mine three weeks ago after taxes! Despite me paying more at the time of purchase ,I like AMD and cant wait for X4core to put in this AM2!
    I am still gonna try more with Air,Perhaps a ThermalRight Extream120! I am also going to look at watercooling after i find max on Air .
    5600+ Oc @3.3ghz with 3000Ht! AIR
    6000+ Oc @3.51ghz with lapped IHS/heatsink BigTyphoon 110cfm
    Jun 2005
    NYC
    now put that sucker on water
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    I am Xtreme
    Apr 2005
    Upstate, NY
    Damn, Windsors got awesome
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    c[_]
    Nov 2002
    Alberta, Canada
    Tec's are looking pretty again.
    All along the watchtower the watchmen watch the eternal return.
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    3.5Ghz on air is very awesome
    waiting for more results, and yes we would like to see this cpu under water and maybe something more aggressive, i am sure with some tweaks and extreme cooling like ln2 u can break the WR
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by SaFrOuT View Post
    One guy already got his X2 6000+ CCB8F up to 4100MHz using Mach II freezer
    This new stepping is simply AWESOME !
    I bought 5600+ last week and sadly it's CCB6F .... only 3.2GHz on air (sarcasm ).
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Mar 2005
    Cairo, Egypt
    Quote Originally Posted by Lightman View Post
    ONLY 3.2GHz on air
    u deserve a good
    lol
    Soon to be :
    Used to be: SaFrOuT
    Feb 2007
    Arizona, USA
    Nice results. And as others have said, get that sucker under water!
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
    Jul 2004
    One more week and I'll join the 6000+ club, see how far I can get. And I was going to get a Crosshair, looks like I need to reconsider. Thanks.
    Athlon 64 X2 4200+ @ 2800Mhz
    Zalman CNPS9500
    Asus M2N-E
    2GB PQI DDRII @ 800Mhz CL5
    Asus GeForce 7900GT @ 550/1520
    18x DVD Burner
    Maxtor 120GB IDE
    WD 160GB SATA
    Iiyama Vision Master Pro 410
    Saving for Phenom X4
    Xtreme Mentor
    Feb 2004
    The Netherlands
    awesome! keep on clockin'
    Any orthos tests though?
    and to XS!
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Where do these 3.5GHz chips top out in orthos/prime?
    You were not supposed to see this.
    Aug 2005
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Xtreme Mentor
    Nov 2005
    Devon
    Yeah! That's the one I was talking about
    It's 4GHz bench stable, and was one screen of 4.1GHz... let me look for it .
    Jul 2006
    Washington State
    anyone know what stepping newegg has been shipping recently?
    Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
    A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
    Current Phenom overclock
    Max Phenom overclock
    Banned
    Jul 2004
    Scotland
    BTW, out of this CCB8F 0711TPMW, the CCB8F is not the stepping, the TPMW part is the stepping.
    I have a CCBVF 0713 RPMW and its crap, cant do 3.250mhz or more stable no matter how high I put volts.
    I got a CCB8F 0717 UPMW next and it does 3290 on stock volts (Asus Crosshair volt droops) but cant get it stable above no matter how much volts and 1 core is lazy and far slower than other in testing.
    I also think I have a bad mobo as I have had 3weeks of crap since it was built and I have tested all other parts but dont ahve spare mobo.
    On the rise!
    Sep 2005
    Quote Originally Posted by humeyboy View Post
    My CCBVF 0704RPMW does 3.4ghz stable with 1.6vcore.
    Banned
    Jul 2004
    Scotland
    Some get 3.5GiG with 1.5-1.55v, 1.6v is getting bit high for air and esp to get to 2.4GiG
  18. #18
    Jul 2007
    Talking Uh Oh here we go! CCB8F-0720XPMW
    Havnt got Orthos loaded i had reinstalled Os and only put the minimum stuff back in.Then I oCed the Crap of it. i wanted to make shure it could at least do 3.5ghz -3.6ghz on Air because i was planning on using A THERMALRIGHT 120Extream! Then i found out my ThermalRight Extream was on BACKORDER ,So i drove to Microcenter just too look ,Yeah Right. I walked in with nothing and came out with everything
    Just installed Swiftech /Apogee GT/1xMcr120/1xMcr220/665pump/and micro resivior/ im using 3/8ths tube and easy to route in my case or i woulda went 1/2. this should be enuff to cool my 6000+ if not i guess ill invest in a thermalchill PA12.3 down the road.I grabed what ever the Microcenter had on hand over the weekend. So i was limeted to what radiators to get for now. They had big table clearance sale so both Rads cost me $50bucks .I found thier last Apogee GT for $25.00bucks The 665pump $56.00bucks and the MicroResivoir was $19.00bucks and 1 roll 3/8green tube $10.00bucks.I really wanted clear, but hey 1/2off! I had fittings and 3-120 panaflos already.
    So now im letting the As5 set up which takes a lil longer. was gonna use Ceramique but i just like As5. if it dosnt seem good enuff i can always swap it out. I left the Apogee stock unlapped, I may lap it . just means gotta Drain the thingWell im cycling the As5 @3.51ghz for now and in few days or hours maybe ill start raising the bar!
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
  19. #19
    Jun 2007
    i have 6000+ too and I tried to overclock it. I am at 1.5125v core at 3.225ghz. I see you guys are so much higher with that voltage. how do you guys do it?
    my specs are
    amd 6000+ at 3.225GHz FSB 215 15X very stable!
    M2N SLI deluxe
    gskill pc6400 2GB ram at 2.1v 4-4-4-12 2t
    nvidia 8600gt 256mb oced
    700watt coolmax psu
    the core voltage maxes at 1.5600v. HT is now at about 1075mhz.
  20. #20
    Jul 2007
    Quote Originally Posted by pslee View Post
    my specs are
    M2N SLI deluxe
    700watt coolmax psu
    Ok try this for 3.3ghz..............300x11 5xHT=1500 or3000mhz,This board loved it 100%stable with my 5600+ and 6000+ use 667 or 533 memDivider and use 1.55vcore ....Go slow Hope you have good Air or water!
    Also set the (TRC )for memory @23 or 24. It allows for tight timming at higher clock rate and makes memory/mem controler a lil more stable on a ASUS mobo! Try Overclocking with the memory set @5-5-5-12 then lower timing after you find you Max CPU
  21. #21
    Banned
    Mar 2007
    Biggest country on earth - Latvia
    CCB6F 5600+ X2 @ 3,2 GHz @ 1,35V @Infinty
    F*****g ASUS M2N32 WS PRO. It won't boot if vcore is more than 1,35 and no chance to even boot with fsb over 240 at max multi. same s**t was with old 3800+ single core.
    Arrggggg.
    2 weeks and only then I can RMA
    I now my english sucks. But that isn't my problem
  22. #22
    May 2005
    [EU] Latvia, Jelgava
    Quote Originally Posted by spainis View Post
    It is. You're living in worst country in this world. Whats the problem not to RMA board now? You bought it from sucky local shop or from warehouse?
  23. #23
    Banned
    Mar 2007
    Nē vinnēju loterijā.
    (No won in lottery)
  24. #24
    Jul 2007
    I'd love to recompile Gentoo on that 6000+@3.51 GHz. It would be so fast. I'd like to compile speed increase in comparison to my 3600+@2.8 GHz.
