I cannot get my board to do over 390FSB for the life of me. No matter what voltage combination I try it is impossible. No matter what CPU multi I use I can still not get respectable FSB's. I can run 8x390FSB on stock volts for 8+ hours but soon as I try to go over 390 it kills me. I have tried combinations all the way from 400FSB-500FSB and nothing works. I have tried the default 8x multiplier as well as 6 and 7. All settings in BIOS that I don't need are turned off, ram is at 1:1 with manufacturers suggest volts and stock timings. I have tried different BIOS versions to no avail.
I did 8 hours of memtest fine for 8+ but it shouldn't be my ram because I am not coming even CLOSE to its rated speed.
Cooling is not an issue as it is open on the kitchen table and I have a fan blowing directly on the NB and CPU temps are well within range.
I have not updated Windows at all. All I did was install Windows, activate it, installed Orthos, Coretemp etc. and started to OC. Does updating Windows have any effect on overclocking? I don't think this would be the issue because a lot of the time when I up the FSB my board doesn't even POST.
It is interesting to note that this is a replacement DS3 for the one I RMA'd because my first one had booting issues where it would constantly boot from floppy no matter what. This replacement is an open box unit per NCIX's policy. They will replace RMA's with open box units if they are tested and everything is ok. Obviously they don't test for overclocking but it makes you wonder why the original owner returned it. Considering the DS3's heavy enthusiast base maybe he returned it for these odd FSB problems I am having.
Is it also possible my CPU is a dud? This CPU can do 3ghz stable on stock volts so it doesn't seem like it should be a bad CPU. Input anyone?
