Hello People,
I am having some stability problems with my Gigabyte IP35 DQ6 mobo (GA-P35-DQ6). I just cannot get the system stable on standard settings.
I have all the BIOS settings in the M.I.T section set to default / standard including the RAM timings set to SPD. Only change I am really doing is the RAM voltage set to 2.4 or +-.50 and nothing else. The vcore for the CPU is set to 1.4v in the bios and actual in vista is 1.3x. I disabled all the power management stuff like TM2, etc and that made no difference. In the MIT screen the ‘Memory Freq )Mhz) reads 1066 1066.
The spec’s of the PC are:
CPU: QX6800 (Quad)
Mobo: Gigabyte P35 DQ6 F4 BIOS
Cooling: Thermalright 120 Extreme
RAM: Corsair Dominator PC8888 2x 1GB DDR2 (with cooling fans)
PSU: Enermax 1Kw
GPU: 8800Ultra
HDDs: 2x 150GB Raptors Intel Raid, 2x 1Tb Hitachi, 3x Samsung 500GB
I am really starting to lose patience with this mobo. I’ve never had too many problems getting a system stable on non-OC settings before and one that did give me problems were replaced (and never bough that vendors mobo’s again) pretty quickly.
Can someone please post up what settings I should enter for default/standard non-OCed settings please?
I am giving myself until Tuesday night to get it all stable or I am so getting a different mobo.
I’ve messed around with settings, etc and still its stable for a few hours and then the PC just freezes and I’ve systematically removed all my HDDs thinking once of them could be causing the problem but I don’t think they are. Even with just the raid 0 HDDs it was still happening ruling out almost all the HDDs.
I’ve read the other threads of people OCing the mobo with awesome results…having enough problems getting it stable…which is so not fun.
