Results 1 to 4 of 4
Thread: e4300 + p5k vanilla = 325 fsb wall????
    Jun 2006
    Hey guys,
    I'm looking for suggestions as how to get through this fsb wall... i know it's the fsb cuz everything is super stable up to 324.. and nothing happens at 325. I'm thinking more volts.. but... I don't think that's the case either to vcore or vmch.. c1e.. all that stuff is disabled... time for a new processor?
    I am Xtreme
    Sep 2006
    400 FSB should be possible mate, upped NB voltage to 1.4 ? Can ou plz post your bios settings here as this info is not enough to determine the cause of find a solution
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Jun 2006
    JumperFree Configuration Settings
    AI Overclocking: Manual
    CPU Ratio Control: Manual
    - Ratio CMOS Setting: 9
    FSB Frequency: 320
    PCI-E Frequency: 100
    DRAM Frequency: DDR2-640 (1:1)
    DRAM Timing Control: Manual
    CAS# Latency: 5
    RAS# to CAS# Delay: 5
    RAS# Precharge: 5
    RAS# Activate to Precharge: 15
    TWR: AUTO
    TRFC: AUTO
    TWTR: AUTO
    TRRD: AUTO
    TRTP: AUTO
    Transaction Booster: AUTO
    Clock Over-Charging Mode: AUTO
    CPU Spread Spectrum: Disabled
    CPU Voltage: 1.40000
    CPU Voltage Reference: AUTO
    CPU Voltage Damper: Enabled
    CPU PLL Voltage: AUTO
    DRAM Voltage: 2.10
    FSB Termination Voltage: AUTO
    North Bridge Voltage: AUTO
    North Bridge Voltage Reference: AUTO
    Advance CPU Settings
    C1E Suppport: Disabled
    Max CPUID Value Limit: Disabled
    Vanderpool Technology: Disabled
    CPU TM Function: Disabled
    Execute Disable Bit: Disabled
    PECI: Disabled
    This is basically the highest stable point I get..
    At one point.. I pushed the Vcore to 1.45.... NB voltage to 1.7... PLL 1.7... over-charging... 1000mV... all of this stuff I gradually moved up to. Any suggestions are greatly appreciated.. my RAM is buffalo firestix 6400.. d9gmh so that isnt the problem i think.
    I am Xtreme
    Sep 2006
    Drop the CPU multiplier to see if the board can run 400FSB and to eliminate the CPU isn't holding you back, this should be doable with the below settings... test it throuroughly then up the multi back to 9 and up the Vcore accordingly, it could be it need over 1.55 volts to get it stable at 3600mhz
    - Ratio CMOS Setting: 9 --> drop to 8x
    FSB Frequency: 320 --> 400
    DRAM Frequency: DDR2-640 (1:1) --> DDR800
    CAS# Latency: 5
    RAS# Precharge: 5
    TWR: AUTO
    TRFC: AUTO
    TWTR: AUTO
    TRRD: AUTO
    TRTP: AUTO
    CPU Voltage: 1.40000 --> 1.45
    CPU Voltage Reference: AUTO --> 0.63x
    CPU PLL Voltage: AUTO --> 1.5
    DRAM Voltage: 2.10
    FSB Termination Voltage: AUTO --> 1.3
    North Bridge Voltage: AUTO --> 1.4
    - Ratio CMOS Setting: 8
    PECI: Disabled
