Results 1 to 20 of 20
Thread: New Prime95 v25.3 Full Support for Dual/Quad Core + HardwareMonitor v4.3.1.2
    Feb 2006
    Arrow New Prime95 v25.3 Full Support for Dual/Quad Core + HardwareMonitor v4.3.1.2
    Whats New in Prime95 v25.3 :
    Note* : Prime95 v25.3 Now Full Support Dual/Quad Cores and you dont need run 2 or 4 prime for test your Dual/Quad Cores ... Best Replacement for old dead Orthos!
    1)Multiple LL tests can be run within a single mprime instance.There is no longer a need to run multiple instances of mprime on multi-cpu machines
    2)Uses a new version of the Primenet server.Features include user IDs that are different than team IDs.New work types.Ability to set some client options using web-based forms.
    3)Communication with the server runs in a separate thread.
    4)The CURL library is used for communication with the server.Hopefully this will support a wider variety of client networking configurations.
    5)Supports using multiple logical or physical CPUs on a single LL test.Except for some hyperthreaded CPUs and only on some FFT sizes, this is not recommended as you will get more throughput by giving each CPU its own number to test.
    6)ECM and P-1 now support B1 and B2 values above 4.29 billion.
    7)Several files have been renamed so that they are not changed by Windows save/restore.Prime.ini is now prime.txt.Local.ini is now local.txt. Worktodo.ini is now worktodo.txt. The primenet.ini file has been deleted - it is now a section within the prime.txt file.
    8)It is now legal to put comment lines in the prime.txt, local.txt, and worktodo.txt files.
    9)In older versions, editing the worktodo.ini file while mprime was running sometimes had the desired effect.That is no longer the case.You can create a worktodo.add file to add work to a running mprime.
    10)WARNINGS: Previous versions of mprime will not be able to read save files generated by this version.This version will not be able to ontinue from P-1 save files generated by the previous version in the middle of stage 2.
    11)Program can now do PRP tests of k*b^n+c.Add a line worktodo.txt that looks like this:
    PRP=k,b,n,c[,how_far_factored,tests_saved]
    The optional how_far_factored (in bits) and tests_saved values are used to determine if P-1 factoring prior to the PRP test would be beneficial.
    12)The program no longer does a one-hour self-test before testing an exponent with a new FFT length.
    13)The torture test dialog box lets you choose how many CPUs or cores you want to torture test.
    14)The benchmark times both single-threaded and multi-threaded FFTs.
    Download Here
    Whats New in HardwareMonitor v4.3.1.2 :
    Intel Bearlake chipsets support added;
    ITE IT8716F, IT8718F sensor chips support corrected;
    Gigabyte P35-DQ6 mainboard support verified;
    Gigabyte P35-DS3P mainboard support verified;
    Asus P5K mainboard support verified;
    Asus A8N-LA(NAGAMI) OEM mainboard support verified;
    MSI P6N SLI-FI (MS-7350) mainboard support verified;
    Gigabyte GA-965GM-S2 mainboard support verified;
    Tyan S2882 mainboard support verified;
    Abit AL8-V mainboard support verified;
    HP Pavilion dv8000 family notebooks support verified;
    Toshiba Satellite Pro 4300 notebook support verified;
    Toshiba Qosmio F30 notebook support verified;
    Download HMonitor v4.3.1.2 Here
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    May 2007
    There's no place like 127.0.0.1, Brazil
    Nice!
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Damn I'm in the middle of Priming right now, guess i'll have to wait till tomorrow!
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Jan 2006
    Montreal
    thank you!
    |::| i7 920 3849A914
    |::|EVGA Classified 760
    |::|G.Skill Trident 6GB DDR3-2000
    |::|BFG GTX 275
    |::|G.Skill Falcon 2 128GB
    |::|WD BLACK 1TBx2
    |::|Ultra X3 1000W
    |::|Powered by Heatkiller LT/Ek-Classified/EK 275GTX /Feser x360/MCP355x2
    |::|LCD: Samsung T260
    "Sharing your knowledge is always the best way to learn new things". OPB
    Xtreme Legend
    Mar 2005
    Australia
    ah excellent
    Team.AU
    Got tube?
    GIGABYTE Australia
    Feb 2006
    Arrow New Prime95 v25.3 Full Support for Dual/Quad Cores ... Run only 1 Prime for Stability
    Download Here
    Note* : Prime95 v25.3 Now Full Support Dual/Quad Cores and you dont need run 2 or 4 prime to test your Dual/Quad Cores just run Prime95 v25.3 one time!... Best Replacement for old dead Orthos!
    1)Multiple LL tests can be run within a single mprime instance There is no longer a need to run multiple instances of mprime on multi-cpu machines
    Xtreme Legend
    Mar 2005
    Australia
    ROFL WTF
    i turn my VM off normally
    well this test ran in blend for a minute or so and it crapped out just as a got a warning from Windows that i'm running out of virutal memory.............at least now i know this program is going to stress all the RAM but i'll have to enable VM lol
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jan 2003
    Knoxville, TN
    Hmm...
    http://www.xtremesystems.org/forums/...d.php?t=126820
    I haven't tried the link you downloaded but I assume it's just a slight update to 25.1 which was posted here back in December of 2006
    Main Rig:
    CPU Intel i5 2500K @ 4500mhz
    Mobo Gigabyte GA-Z68X-UD3H-B3
    Memory 4x4GB Corsair Vengeance DDR3 1600
    Video Cards Sapphire 5850
    PSU Silverstone ST75F Strider 750W
    Hard Drive OCZ Solid 3 60GB | OCZ Vertex 2 60GB | Samsung 103SJ's 4TB
    Cooling Thermalright Ultra 120 | 1 Yate Loon D12SM 120MM
    Sep 2006
    Brazil
    Download link:
    ftp://mersenne.org/gimps/
    P95V253.zip
    Aug 2006
    St. Louis
    Wow, I just downloaded orthos like 5 minutes ago, thanks!
    i5 750 @ 3.2 Ghz, stock volts on stock cooling
    4GB G.Skill DDR3-1600 7-7-7-21
    Gigabyte P55-DS2
    EVGA GTX260 192shader
    Mar 2006
    Arcadia, CA
    Excellent find, thanks!
    Jun 2006
    Ger
    Nice Found thank You
    Apr 2006
    Pleasant Hill, MO
    cool beans. Thanks for the hardware monitor.
    Ryan
    "Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
    Abit IP35 Pro
    Intel Core 2 Quad 6600 @ 3200 w/ Tuniq Tower
    2x2gb A-Data DDR2 800
    AMD/ATi HD 4870
    Jul 2006
    Great!
    Intel E8400.C0 "Wolfe"| 400x9 3600 Mhz @ 1.272 Vcore
    TT Sonic Tower | Dual 120mm Antec Fans | Silent Air @ 1200 RPM
    ASUS P5Q-E | BIOS 0610
    G.Skill F2-8000CL5-2GBPQ | 400 MHz (5-5-5-15) @ 2.0 V (? Auto)
    XFX 7800GT
    Wester Digital Raptor 74GB | Maxtor Maxline III 300GB | Seagate 7200.7 120GB
    Antec P-180 | Antec True Power 2.0 550W
    Dell 2407 | Dell 2405
    Crunching for Poppabear
    Feb 2006
    Covington, GA
    Thanks for the heads up.
    D.F.I Pimp Daddy
    Jan 2007
    Quote Originally Posted by Chewbenator View Post
    Eh....I have never put any stock in Orthos because what I would fail in Prime95 would pass in Orthos!
    SuperMicro X8SAX
    Xeon 5620
    Aug 2006
    St. Louis
    Meh, I've heard people reporting the opposite, but in the end my overnight F@H runs are what makes final judgment. Been having problems lately especially since I switched over to Vista. Sometimes it'll work through the night, sometimes it'll crash, so I decided to do some testing with these programs and restabilize.
    Gigabyte P55-DS2
  18. #18
    Nov 2005
    AWESOME!!! Now I can go and test my new cpu to come! (Opty170)
    -Cpu:Opteron 170 LCBQE 0722RPBW(2.87ghz @ 1.300v)
    (retired)Opteron 146 (939) CAB2E 0540
    -Heatsink: Thermalright XP-90
    -Fan:120mm Yate Loon 1650 RPM @ 12V, 70.5 CFM, 33dB
    -Motherboard: DFI Lanparty nF4 UT Ultra-D
    -Ram: Mushkin High Performance blue, 2gigs(2X1gig kit) PC3200 991434
    -Hard drive: Seagate 400GB Barracuda SATA HD 7200.10(AS noisey model)
    -Video card: evga 6800GS @520/1170
    -Case: P180
    -PSU:Enermax 535Watt EG565P-VE FMA (24P)
  19. #19
    D.F.I Pimp Daddy
    Jan 2007
    Was running it before for 3hrs works great!
    SuperMicro X8SAX
    Xeon 5620
  20. #20
    Nov 2004
    HATU<--->UTAH
    very good !...thank you
