Nice chip Flasker, hmmm $200AU for a 5600+ hmmmmmmmmmmmmmmmmmmmmmm should I or should'nt I
lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
Flasker,
Did you remove the heatspreader yet?
btw, I've got a pretty decent 6000+ in the other thread. Does 3557MHz aircooled for SPi1M with TT V1 cooler (+additional cool air). CPU idle temp is 24-26C according to Coretemp (cooler base/Heatspreader temp is around 21C idle) - under load (quick SPi1M run) it gets up to around 40C Coretemp / 28C cooler base/heatspreader. 1.5V.
I didnt see any gain going from 1.5V up to 1.6 or 1.65V - might require better cooling to see the voltage scaling though.
Damn! Thats some nice clocks.
If you're gonna remove the heatspreader you should know that some of the new A64 got the IHS glued on like the Intel cpu's
(you probably know about this, but anyways...)
Take a look at the part number in cpuz, cpuz reads "everything" as pc 6400
Whoa! Nice clocks bud. Man I really want to try a f3 core...
Ply
for 80 bucks you can get an f3 3800+ from newegg. just look for CZ in the part code.
3800 MHz barrier is broken,
had it higher, but the darn thing would freeze every time I tried to save the validation file.
Coldbugs @ 8C
http://valid.x86-secret.com/show_oc.php?id=210833
what voltage? So close to 4 now.. above 0. that will be a milestone in coldbugged AMD times.
GAME-AMD x6 1055T|ASUS M4A870TD|8GB DDR3|HD5858|SSD RAID0|Seasonic!700w
VMWARE-E6420|Asus P5Q-VM|4GB|320GB|BEQUIET!600w|
NAS-Via 1.5 GHz ITX|Dual Gigabit|1gb ddr|2*3TB WD
MbP 13"|C2D 2.53GHz|4gb DDR3
Barton 2600+@2800mhz SuperPI 37s Sempron 2800+@2665mhz SuperPI 35,5s OLD SCHOOl
-Apple Iphone 3g |X10 mini Pro 2.2.1|Nintendo WII|PS3 Slim
Who would thought a year ago that 3.8GHz will be possible on 90nm AMD X2 with above 0C temperatures? (No one! )
This is showing how good AMD/IBM DSL SOI can (compared to Intel bulk) be if tweaked properly! What a pita it takes so long to get where it is now...
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
I haven't had much time for benching lately, summertime and all, but I had some time last night so I fired up the chiller. Twisted my 5600+ as hard as I could.
I thought this thing coldbugged at 8C, but it was a BIOS issue that behaved like a coldbug. Anyway got the CPU to -5C @ idle, 2C @ load, best I can do with high v-core required to get the clocks. Measuring the temp of the top of the block I had -15C. This thing is like a toaster!
Won't be able to catch flytek, not with this chip, got a CPU-Z of 3892 MHz, but the file was corrupt, I'll try again.
Here's a SuperPi 32M run @ 3782 MHz
Isn't this new SuperPi WR on AMD X2??
Congratz!!
Holy ! I never imagined these kinds of speeds on a A64! I thought I was doing good with a 2.9ghz chip! (ram limited) this is just incredible!
How does a 3.6 A64 do against a 3.6 C2D in other benches, lie cinebench and encoding and higher resolution gaming?
Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
Current Phenom overclock
Max Phenom overclock
we need some F3 FX action!! darn coldbug
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
