This will be my first time with water cooling.. Thanks to Hard H20 and newls1 for hooking me up with this unit called the waterkegIII.. Hard H20 didnt have the time to do the review so he asked me to do it for him..
I am going to do a full review of this unit and its performance on a Q6600 and a X3210 that I have here. This Q6600 does seem to run a bit hotter than the X3210 but that could be the HS's. The X3210 is using a Ultra-120 and the Q6600 is using a Big Typhoon.
I am putting this thread here cuz this would be a GREAT solution for water cooling a rack system. All that would need to be done is drill 2 holes for the tubing to go into the case. So, lets see how the cools some Kentsfields.
First Impressions-
I opened the box thinking this was going to be a huge unit.. Well, to my surprise its really not. In fact I think its the perfect size. Looking at the workmanship of the case itself I was quite impressed. The only thing I would change is the screws.. Seth, (newls) said he had update the screws already though..
Another thing I thought about was the pricing of the unit. I was thinking that he had the price tag a tad bit high thats until I actually saw the unit.
Whats inside-
I opened the case to see what was inside and how well it was put together.. All I can really say is DAMN Everything was placed very well and looked great.
This particular unit came with the Swiftech 120.3 rad but he does offer an upgrade to the Thermochill P120.3 rad. The pump is a relabeled Laing D5. Honestly being a water n00b I dont know whats good yet but, I was told that is a great pump. Seth also offers a D-TEK Fusion block with the unit which he has included for me already. There are alot of accessories like the molex pci plate to put in your case for a much cleaner look. He's also included some zip ties and UV Reactive water additive to go along with the lights inside the case.
Here are a couple pics of the inside of the unit.. I'll be putting this all together tomorrow and running some test on it.. So look for more info soon
You can also find out more information on the unit in this thread.
Leak testing-
Starting temps on air-
Initial Water temps-
