07-27-2007, 10:07 AM
#801
For all who think they need it :-
07-27-2007, 10:42 AM
#802
Originally Posted by 226
I just ordered this board with the g0 q6600 so was this a good choice for the quad core?
Can anyone confirm this? If this needs a new bios for the g0 q6600 I'll have to RMA the board since I don't have another 775 CPU.
i got it to 3.4 on air
the PWM is getting close to 80degrees under full load so im scared to go any further until i can find a way to cool it
btw, can someone tell me what IS pwm anways...
07-27-2007, 10:51 AM
#803
So you just solder 1K Ohm resister to those to points?
I've never done a board mod before; sorry if it's a n00b-question.
__________________
abit IP35 Pro (Snake) | Core 2 Duo E6420 @ 3.4GHz (425FSB x 8 - should I push it further?!) | Thermalright XP-90C w/ Panaflow 92mm | 2GB Kingston Hyper-X DDR2-800 | OCZ GeForce 8800GTX | Audigy 2zs Platinum | 150GB Raptor X, 500GB Seagate 7200.10 | CoolerMaster CM Stacker | CoolerMaster iGreen 600w
My Heatware
07-27-2007, 11:26 AM
#804
Anyone attempted the vDroop mod using a pencil ?
07-27-2007, 11:55 AM
#805
yep just sold the middle leg and one of the outer legs of the variable resistor to each of those points making sure that the resistance between the two legs is 1Kohm before hand.
As for pencil mods I'm no fan of them due to them being really unstable and inaccurate - this is a low resistance mod is its best to do it right!
07-27-2007, 12:11 PM
#806
I believe it stands for Pulse Width Modulation....
__________________
Main Rig:
| eVGA X58 Classified | 920 D0 | Corsair Dominator GT 3x2gb | 3X eVGA GTX285 -Tri SLI |
| 4x 32gb SSD - RAID 0 | Plexy 716SA Black | PC P&C Turbo Cool 1200 | Dell 2405FPW |
| Dimastech Bench Table |
HEAT EBAY
07-27-2007, 12:53 PM
#807
Thats correct.
A quote from Michael Hyatt
"Pulse-width modulation of a signal or power source involves the modulation of its duty cycle, to either convey information over a communications channel or control the amount of power sent to a load.
The temps vary according to the amount of power being used and/or how well they are cooled. (none of mine are above 40*C, but they are extremely well cooled) 50~60*C is safe; 60~75*C is warm and acceptable to some; anything above that, and I think they are too hot and you had better consider improving your (case) cooling."
__________________
E6750 G0 POS!
GA-P35-DS4 Rev. 2.0
Visiontek HD4870
Maxtor SATA 160
OCZ Reaper 2x2 1066
X-Fi Fatality XG Pro
Tsunami Dream/Thermaltake TP650
07-27-2007, 01:40 PM
#808
thanks for posting that mod.
at least i have an idea now.
anyone hear of news on upcoming bios releases btw? I have b04 right now. Im hoping they includ a vdroop regulation option like in the p5k.
i had a p5kdlx, but returned it. board was not stable with my rams, i did like that feature though
__________________
07-27-2007, 01:47 PM
#809
Originally Posted by Mr.Bones
Thats correct.
ooh thanks a lot. If i want to improve my cooling for them... where are they located exactly?
07-27-2007, 01:59 PM
#810
Xtreme Cruncher
Under the top left heatpipe heatsink on this board
I'm new to Intel OC'ing, could someone explain to me what some of these voltages do?
CPU VTT 1.2V
MCH 1.25V
ICH 1.05V
ICHIO 1.5V
DDR2 Reference Voltage
CPU GTLREF 0-3?
Thanks!
07-27-2007, 02:04 PM
#811
Wish I had the skills and know-how for that mod.
Just had a look inside the case, and that area you've posted is minuscule.
Can I take it that the resistor would be something like this
http://www.maplin.co.uk/module.aspx?...&doy=27m7#spec
Any photos of the finished mod? Maybe able to take it in and get it done by someone who does know how.
Is that something that could be done just in a bios mod?
RLM
__________________
QX9650@4.5ghz Vapochill LS
E8600 (Boxed)
Rampage Extreme
OCZ Gold DDR3 (8500) 1680 7-6-6-20-2T
4870x2 Vmodded + Ek Nickel
9800GX2 Vmod + EK H20 (Stored  )
Thermaltake TP 1000W
Lian Li P007 Case
07-27-2007, 02:20 PM
#812
CPU VTT 1.2V
MCH 1.25V
ICH 1.05V
ICHIO 1.5V
CPU GTLREF 0-3?
This is a non expert response
VTT and MCH seems to be the most significant.
Upping VTT a bit with my quadcore has increased stability a bit, or should I say given me a few extra minutes before prime failure.
MCH You up when going for higher FSBs(I think I'm right in saying that). Also of note the higher the MCH value the more volt options in the VTT, so I presume the increases should go hand in hand.
ICH I leave as is
ICHIO Same really. Maybe just a nudge up
CPU GTLREF
Read this
http://sg.vr-zone.com/?i=4409&s=7
In theory these settings should have a significant effect on the FSB you can reach. It's a percentage of the VTT. A quadcore requires a different percentage for instance to a dualcore. The aim is to find the sweet spot with this setting(As the article says)
In practice it doesn't seem to be too effective on this board, so around default is the way to go.
As I say, non expert advice. Expert advice hopefully to follow
RLM
__________________
E8600 (Boxed)
Rampage Extreme
Lian Li P007 Case
07-27-2007, 02:32 PM
#813
Hey johny thanks a bunch for the vdroop mod, now quick question does this decrease the drrop from what you set in bios to what you get in windows or does this help control the droop caused by placing the cpu under load.
thanks
__________________
W3520,UD5, gskill trident, 9800gtx+,
corsair 850, Water
07-27-2007, 02:33 PM
#814
Xtreme Cruncher
Your advice is appreciated, as for your vmod, the pentiometer you listed will work fine, I get my supplies at my local radioshack
http://www.radioshack.com/product/in...entPage=family
I'll be getting one of those soon enough
As for an update on my E6750, priming at 3.4GHz with stock volts
07-27-2007, 02:40 PM
#815
Really need help with this Pro mobo. Can´t get past 480fsb nomather what voltage i set. Using the B04 bios and a E6850 G0.
Have active fans to pwm and mosfets. This mobo should do over 500 fsb what i´ve seen. And caan someone explain what the CPU GLTREF 1-4 do for fsb. What % should i choose ?
__________________
EVGA X58 SLI LE, Patriot Viper 3x2GB, Vertex 5850, Corsair 620W and W7 Ultimate X64
07-27-2007, 02:56 PM
#816
Very nice
Really need help with this Pro mobo. Canīt get past 480fsb nomather what voltage i set. Using the B04 bios and a E6850 G0.
Have active fans to pwm and mosfets. This mobo should do over 500 fsb what iīve seen. And caan someone explain what the CPU GLTREF 1-4 do for fsb. What % should i choose ?
A few posts up, I've linked to an article which touches on GTLREFs and what they are about.
This page shows the use of them in practice with a DFI board
http://sg.vr-zone.com/?i=4409&s=17
However as stated they don't seem to be amazingly effective on this board.
RLM
__________________
E8600 (Boxed)
Rampage Extreme
Lian Li P007 Case
07-27-2007, 03:20 PM
#817
Read these to get a good idea or atleast get started
Link1
Link2
__________________
corsair 850, Water
07-27-2007, 03:27 PM
#818
Link1
Link2
Didn't find those. A bit more like it
__________________
E8600 (Boxed)
Rampage Extreme
Lian Li P007 Case
07-27-2007, 04:00 PM
#819
CPU VTT 1.2V
MCH 1.25V
ICH 1.05V
ICHIO 1.5V
CPU GTLREF 0-3?
Thanks!
VTT - the CPU->NB interconnect voltage
MCH - Northbridge, you may need to up this a couple notches
ICH - soutbridge leave at stock (southbridge controls disks and other IO)
ICHIO - southbridge related as well, leave
DDR2 Ref - ??
CPU GTLREF- don't know how to explain in a concise way, here's a link http://www.thetechrepository.com/showthread.php?t=87
07-27-2007, 04:50 PM
#820
Xtreme Cruncher
Thanks for clearing that up you guys, any info on the DDR2 Ref. Voltage?
Had to up my vcore and MCH a little to hit 3.52 stable (not sure which was the culprit), with vdroop my vcore is still under stock
07-27-2007, 05:15 PM
#821
For goodness' sake, don't try a mobo volt mod without a lot of practice. Here are some tips. 3 sec too long with the tip too close to the board, and pow, you may have a new door stop.
07-27-2007, 06:03 PM
#822
Originally Posted by shawn1998
I resolved my IE7 32bit issue by reformatting and installing Vista 32bit. Vista 64bit seemed ok, but that issue was a deal-killer for me. So, everything is back up and running normal now, with the internet working 100% again.
Shawn
I use Vista x64 and IE works both 32bit and 64bit...I just never installed a killernic (i.e. waste of cash nic). So perhaps that had something to do with it.
Anyhow just use Firefox instead
__________________
Abit IP35 Pro @ 448Mhz FSB
Q9550 @ 3.8Ghz
4GB GSkill PC6400 @ DDR2-896
EVGA GTX 95 @
WD 300GB Velociraptor
WD 250GB SE16 HDD
Seagate 7200.11 1TB HDD
Soundblaster X-FI
Corsair HX1000 PSU
Thermalright Ultra-120 w/Panaflow H1BX
Cooler Master HAF 932
07-27-2007, 06:17 PM
#823
Feedback on this Build?
Hi,
I am about to pull the trigger on this build. I wanted to post it for a sanity check and make sure I am not overkill on the memory...and that the Tuniq will fit the board ok without any modification. Hoping for a decent overclock, but nothing crazy.
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail
Intel Core 2 Duo E6850 Conroe 3.0GHz LGA 775 Processor Model BX80557E6850 - Retail
Tuniq Tower 120 P4 & K8 CPU Cooler - Retail
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model BL2KIT12864AA1065 - Retail Thanks!
scaryogre
07-27-2007, 06:27 PM
#824
Xtreme Cruncher
The memory is fine, I have that kit but have not tested it much, but from what I can gather it does 800/1000 speeds with ~1.8v
The build looks good overall
Could someone recommend safe voltages for the options in BIOS? (mch, even vcore, etc)
07-27-2007, 06:33 PM
#825
Thanks!  The memory spec calls for 2.2v. Would one still set it to 1.8v or should I run it at rated speed (i.e. 2.2v)?
Any pros/cons either way?
Again, thanks!!!
-scaryogre
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
