XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 05-27-2007, 08:41 AM   #26
njkid32
Hiding from the cops and people I ripped off
I just did another cpu change and decided to a little more permanent solution.. I put a penny instead of the cardboard. I still have a little play when I twist it but overall my cpu temps have dropped over 5c with this particular cpu. I honestly think the cardboard was a better solution than the penny cuz I wants able to twist the hs as much before. Either way this is working quite well.
Edit: As you can see the hs is not totally level in this pic but I have fixed that now.
Edit2: Resized for the complainers out there
__________________
njkid32 is offline   Reply With Quote
Old 05-27-2007, 09:19 AM   #27
Eagleclaw
Eagleclaw's Avatar
Thanks for the pic, this should give everyone a good idea on how much to add. I bet we will see some creative shims
A US silver dollar should work pretty well
__________________
i7 920 @ 4.0GHz
Scythe MUGEN-2 with Push/Pull
Gigabyte EX58 UD5
3X2GB G-Skill DDR3
eVGA GTX 260
24" Acer HDMI LCD
Corsair TX850
Lian-Li PC-V1000
Core 2 Duo E6600 (L629F) @ 3.690GHz
Thermalright ultra 120 Extreme Yate Loons Push/Pull
ASUS P5K DELUXE/WIFI
4X2GB A-DATA PC2 6400
ATI HD 2600
22" Hanns.G HDMI LCD
Corsair HX620
CM Stacker 810
Eagleclaw is offline   Reply With Quote
Old 05-27-2007, 09:19 AM   #28
graysky
Damn dude, no need to post a full 6 MP image. Download photo resizer from:
http://www.rw-designer.com/picture-resize
graysky is offline   Reply With Quote
Old 05-27-2007, 11:03 AM   #29
xenoasd
xenoasd's Avatar
how big should the cardboard be? or how thick.
__________________
E6600 - 3.6Ghz @ 1.4V
Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
Asus P5B-Deluxe WiFi-AP
Crucial Ballistix DDR2-1000 2GB
eVGA 8800GTS SuperClocked 320MB 650/1900
Creative X-Fi XtremeMusic
Corsair HX520W
Antec 900 Case
3DMark06 - 13,078
xenoasd is offline   Reply With Quote
Old 05-27-2007, 11:18 AM   #30
sierra_bound
Moderator
sierra_bound's Avatar
Thanks for the tips, Eric.
sierra_bound is offline   Reply With Quote
Old 05-27-2007, 03:44 PM   #31
ineedaname
ineedaname's Avatar
This is getting off topic but you can just use the image resizer that microsoft provides with their power toys. That way u can just right click to change photo sizes.
http://download.microsoft.com/downlo...ertoySetup.exe
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
ineedaname is offline   Reply With Quote
Old 05-27-2007, 04:04 PM   #32
njkid32
@xenoasd I'd say a min of 1/8" but since your using cardboard you might want to go a little thicker cuz it'll compress..
I am on Vista so image resizer wont work.
__________________
Old 05-27-2007, 04:56 PM   #33
Pete
Banned
Pete's Avatar
Send a message via MSN to Pete
I think some nice steal brackets in an X will do perfectly
Pete is offline   Reply With Quote
Old 05-27-2007, 06:42 PM   #34
[XC] 4X4N
100% Load 24/7
[XC] 4X4N's Avatar
I tried this today with a big fender washer. It's a little over 1/8th inch thick. Worked pretty well, I can barely move the heatsink now. It's only been running about an hour, but temps are the same as before. My temps were good already, so I don't know if I can improve them much. This is with dpad running. Stresses about the same as wcg, not quite as much as orthos.
__________________
Main Rig
i7 920 l Gigabyte X58 UD4P l 3x2 OCZ l GTX260 l Seasonic M12D 750
[XC] 4X4N is online now   Reply With Quote
Old 05-27-2007, 07:33 PM   #35
humeyboy
AFAIR, Image resizer does work and there is Vista Powertoys.
humeyboy is offline   Reply With Quote
Old 05-28-2007, 04:39 AM   #36
Retrolock
do i need to re-apply thermal paste after i put a penny under the bracket? I just unscrewed, place, then rescrew. I didn't lift the HSF though.
Retrolock is offline   Reply With Quote
Old 05-28-2007, 06:22 AM   #37
njkid32
If you didnt pull the hs off you should be ok..
__________________
Old 05-28-2007, 08:06 AM   #38
IAmATeaf
You've done something similar to what I typed here a few days ago http://www.xtremesystems.org/forums/...=144423&page=2 glad you got it sorted but TR really need to revise the bracket as a lot of people are reporting problems with the HS not being secure.
IAmATeaf is offline   Reply With Quote
Old 05-28-2007, 07:10 PM   #39
burton
that looks pretty nice to bad i use the tuniq
burton is offline   Reply With Quote
Old 06-04-2007, 12:55 PM   #40
Jodiuh
Jodiuh's Avatar
Send a message via AIM to Jodiuh Send a message via MSN to Jodiuh
Nothing wrong w/ the Tuniq. I only get slightly better temps w/ the TR, but it looks a lot better IMO. I too have a moving mount. Perhaps some of that soft foam used in mobo boxes would be a good alternative here. I picked up something similar from Michael's when I had to replace the Tuniq's back plate mount.
Jodiuh is offline   Reply With Quote
Old 06-04-2007, 02:14 PM   #41
xenoasd
xenoasd's Avatar
i just installed my ultra-120 extreme.. sheeze its freaking loose~!, what kind of washer and size should i use ? (i proberly use a penny if i cant find the right washer)
__________________
Corsair HX520W
Antec 900 Case
3DMark06 - 13,078
Old 06-04-2007, 02:47 PM   #42
wfp
Just replaced my ninja ver B with the ultra 120 extreme today. I'm seeing a 11C difference so far. I think I messed up my ninja really bad though . About a 4-5C difference from before I messed up my ninja. The ultra 120 extreme I got came without the washer and is pretty loose. I will have to add a washer/penny in later.
wfp is offline   Reply With Quote
Old 06-05-2007, 12:45 AM   #43
introstand
Also got the new rev. without the washer and it's loose.
Which is the best way to go, penny or cardboard??
__________________
Lian Li V1000
e6600 @ 3,6Ghz (1,36v)
Ultra 120 Extreme / S-Flex 1600rmp Push-Pull
Asus P5B Deluxe
2048 Crucial Ballistix 8500
Asus 8800GTS
Tagan 480W
LG L1980Q
introstand is offline   Reply With Quote
Old 06-05-2007, 12:27 PM   #44
njkid32
I'd say go with the cardboard it gives more friction for less movement. Just make sure you add enough cuz it's going to compress when you screw the bracket down.
__________________
Old 06-05-2007, 12:50 PM   #45
introstand
OK, then how much is enough?
__________________
Lian Li V1000
Asus P5B Deluxe
Asus 8800GTS
Tagan 480W
LG L1980Q
Old 06-05-2007, 12:53 PM   #46
njkid32
I'd say a little over an 1/8".
__________________
Old 06-05-2007, 01:26 PM   #47
introstand
Ok, thanks. I'll try that tomorrow. I installed my Ultra-120 Extreme yesterday and right now i'm running stock and hitting 45c on load, which i think is too high. The ihs is lapped and i have really good airflow in the case.
Think I will lap the heatsink too tomorrow while i'm at it...
__________________
Lian Li V1000
Asus P5B Deluxe
Asus 8800GTS
Tagan 480W
LG L1980Q
Old 06-05-2007, 01:36 PM   #48
Dublin_Gunner
Dublin_Gunner's Avatar
Seems I've ben lucky, I just installed the 120 extreme today, and its a solid fit.
My temps arent great though, but probably due to it being like a sauna in my room, with rubbish airflow in the case.
__________________
E6400 L628 @3.4 1.4V
Ultra 120 Extreme
2GB team Xtreem @ DDR2-850 4 4 3 10
Abit Quad GT
X1800XT flashed to XTPE 700/1600
OCZ GameXstream 600W
Dublin_Gunner is offline   Reply With Quote
Old 06-05-2007, 03:35 PM   #49
wfp
I decided to switch out the plastic washer I was using with a dime today.
Set up with plastic washer. Twisted the hsf a bit in the picture.
This is the plastic washer I was using before. I guess since it has the hole to accommodate the screw that is on the x clamp, it really only added 1mm more thickness.
With the newly added dime.
Looks like a huge improvement When I was running orthos yesterday, I was getting 58-59C at load. Today after I added the dime, it is currently going back and forth at 52-54C after 60 mins of orthos. Temps measured with core temp .94.
Old 06-05-2007, 03:46 PM   #50
Eagleclaw
Eagleclaw's Avatar
5-6c drop on load is huge, nice going
__________________
i7 920 @ 4.0GHz
Gigabyte EX58 UD5
3X2GB G-Skill DDR3
eVGA GTX 260
24" Acer HDMI LCD
Corsair TX850
Lian-Li PC-V1000
ATI HD 2600
Corsair HX620
CM Stacker 810
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
