9x400@2:3=1200 5,5,5,12,3,30,3,3 3 vd=2.3v vc=1.525v bios=0311hornet
Someone could put SS with 400FSB@DDR1200 orthos blend.
- i7 920
- DFI DK X58-T3eH6
- G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
- Crossfire 2x ATI HD4670 GPU 785 Ram 1060
- Thermaltake Toughpower 1200w
- Cooling: Water - EK Supreme
- Lian Li V2000B+
24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
Official Gigabyte X48T-DQ6 Info Thread
DFI DK X58-T3eH6 on Test
Any word on a 5 series BIOS for P5K Deluxe?
No word yet... 0311 is still the best bios for me right now but my focus is on max memory oc'/performance
I can't get into the BIOS. I'm hitting the Del key during the boot process but I get a 'No keyboard detected' message. That message is correct: none of the keys are detected. My Memtest86+ v1.70 CD in my DVD drive and it loads after the above message. The funny thing is the keyboard works while Memtest86+ is running.
Am I going to have to clear the CMOS? Any ideas?
| Intel Core i7-2600K | ASRock P67 EXTREME4 GEN3 | G.SKILL Sniper Series 8GB (2 x 4GB) DDR3 1866 | EVGA GTS 450 |
| Swiftech APOGEE Drive II CPU Waterblock with Integrated Pump | XSPC RX360 | Swiftech MCP655-B Pump | XSPC Dual 5.25in. Bay Reservoir |
| Thermaltake 850W PSU | NZXT SWITCH 810 | Windows 7 64-bit |
[SIGPIC][/SIGPIC]
Ok good work, already now you could put the settings applied in jumperfree.
- Multiplier 9
FSB Frequency: 400
PCI-E Frequency: 102
Strap 03:02
DRAM Frequency: 1200
Dram Command Rate 2T
DRAM Timings:-
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# Activate to Precharge: 12
TWR: 3
TRFC: 30
TWTR: 3
TRRD: 3
TRTP: 3
Transaction Booster: Enabled
Boost Level* 1
Clock Over-Charging Mode: Auto
Level N/A
CPU Spread Spectrum: Disabled
CPU Voltage: 1.525
CPU Voltage Reference: Auto
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.5
DRAM Voltage: 2.3
FSB Termination Voltage: 1.3
North Bridge Voltage: 1.4
North Bridge Voltage Reference: Auto
South Bridge Voltage: Auto
Advance CPU Settings
C1E Suppport Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit Disabled
PECI: Disabled
Intel® Speedstep™ Tech Disabled
- i7 920
- DFI DK X58-T3eH6
- Lian Li V2000B+
That solved the keyboard problem. I first tried it without removing the battery and thankfully that worked.
Now that I've got back into the BIOS I'll tell you'll what I did to get me in this fix!
I have flashed to the 0404 bios and was trying to find my best settings using my new Crucial Ballistix PC-8500 memory. While trying to get it stable I tried a vcore of 1.45v but under full load the cpu temp went to 70c and the cores were 81c. I quickly exited Prime95.
I have a temperature sensor in the tubing going from the CPU waterblock to the tank and it was below 35c. My MB temp was around 30c. I'm asking myself why isn't the CPU getting cooled down. This only happened when I raised vcore. Putting off the obvious of reinstalling the waterblock and possibly lapping my CPU I decided to see if any of the BIOSs setting affected the CPU temperature. That's when I got into this fix.
I can tell you that PECI disabled raised my cpu temperature around 10c. Also with Transaction Booster enabled I couldn't boot: had to use F1 to get back into the BIOS. Finally I enabled CPU TM Function. That was a bad idea. Leave CPU TM Function disabled.
It looks like I'll need to solve this CPU temperature / vcore issue if I'm going to use higher vcore.
[SIGPIC][/SIGPIC]
hey eva since your the RAM-expert, and I am really new to Intel just got my rig for 5 days, looking the specs of my ram settings is there any improvement, by upping the FSB and lower the mulitplier , the divider : 16:10 , reason why i stay @ 3ghz range is that i got still the stock cooler, otherwise it will be to hot!, what i got now 382fsb @1222mhz 5-5-5-15 @ 2.3v 4-30-12-4-4, is about the tightest i can get I had @ 1203mhz @ 5-5-5-12 stable tho didnt tweaked the sub timing of it. Could u maybe give me some advice @ what fsb/ timings /speed i could aim for better performance?
• DFI Lanparty LT X48-T2R
• Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
• eVGA 8800GTS (G92) 512MB {stock}
• Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
• Lian Li PC-V1000 {modded}
• Corsair HX 620W
• Creative X-FI ExtremeMusic
• Western Digital Raptor X 150GB
• Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
mc2k have a go at 7x433FSB 4:5 with ram @541mhz 4-4-4-5/9 3-30-3-3-8 if they can hit those clocks should be nice and fast.. don't be afraid to try 541mhz 5-4-4-9 in order to keep vdimm low and sub timings tight.
Since I can't remember having such a high CPU temperature with a vcore of 1.45v using the 0311 BIOS, I've decided to go back and check it. After I flashed 0311 I reloaded my default settings. When I booted I kept getting the checksum error and to boot with F1 message. I finally manually entered my defaults and now the checksum error is gone.
[SIGPIC][/SIGPIC]
eva a big Thanks will defo try will feetback with everest results
*edit eva for the subtimings u posted is it this follow? tWR -tRFC -tWTR -tRRD - tRTP and for the NBv: to 1.4? and how much for the FSB Therni volts? would 1.3v do? @ that fsb , I got till 382 fsb so far stable with just 1.2 fsbv and 1.25 for the NB. thnx and @ 433fsb with probbly NB 1.4v , would it be safe without a fan directly blowing @ it, but i got a fan mounted @ the ram: [img] http://img224.imageshack.us/my.php?i...img0756di7.jpg [/img] , it covers a small bit of the NB 2, and i got 4 intake fans @ sidepanel of my evo, would that be good? or should i mount a fan for that speed on the NB?
• Corsair HX 620W
i'm currently using the thermalright ultra-120 extreme w/ 60cfm fan and with the p5k deluxe, no mods done.
i dont intend to add any extra fans because i'm building a silent pc. can anyone advise me on whether 400 - 450fsb fully passive nb cooling is safe? kinda worried because the ultra-120 extreme blows air through and not down at the board. i'm using an antec p180 case with a 75cfm intake, and also another of the same 75cfm fan as exhaust. thanks!
450FSB with NB 1.4v should be fine.. i'd have a fan over passive NB and cpu socket area regardless
as for sub timings i always quote them in order of bios listing from top to bottom
Which are the main differences for the deluxe?
does the 0404 BIOS solve the 4:5 divider "PCIE freq cannot lock to exactly 100MHz" issue? (cant seem to find any updates within the posts to this)
That varies with build no one i know with a quad can run with 1 or 0. Works for me though, but i have the problem with 0404.But I with the Transaction Booster enabled and the remaining equal values, to motherborad does not do the boot.
- i7 920
- DFI DK X58-T3eH6
- Lian Li V2000B+
Gosh, 35 pages. Could someone sum up this board for me, nice and quickly? Pros, cons, overall conclusion would be nice. Is this the P35 board to get?
- Intel Xeon W3520 #3848A352 D0 @ 4.4GHz
- DFI LanParty UT X58-T3eH8 (bios 05/08)
- 3x2GB Corsair Failinator GT 1866MHz 7-8-7-20 (3x2GB Patriot Viper 1600MHz C8 backup...)
- Sapphire Radeon HD 4870 X2 2GB @ 872/1000
- ~5TB assorted WD/Seagate
- SB X-Fi XtremeMusic & Logitech Z-680 THX
- Tt Toughpower 1200W Modular
- CM Stacker T01 Black
- Eizo FlexScan SX2761W 27" & Samsung 226CW 22"
CPU Loop: MCP655/D5 - Swiftech Apogee GTZ - Thermochilll PA120.3 - YateLoon SL's - 1/2" MasterKleer
GPU/Chipset Loop: MCP655/D5 - EK-FC4870 X2 Acetal CF - Swiftech MCW30 - Thermochill PA120.3 - YateLoon SL's - 1/2" MasterKleer
No real cons; It's a great board. The "Heatsink2" isn't attached the best, but it hasn't caused any failures that I (we?) know of, overclocking included. The 0311 bios seems to be the best performance wise still, and it overclocks great even with all 4 DIMMS populated. (see sig) It's got a bios feature (voltage damper) that arguablably negates the need for a VDroop mod, which is a real blessing on an Asus board.
I guess I can think of one con; it's $225 while competing boards aren't quite as expensive, but I think it's worth it....
Don't take my word for it tho, I already bought it so I'm a bit biased.
Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
Sapphire 5870 @ 985/1245 1.2v
X-Fi "Fatal1ty" & Klipsch ProMedia Ultra 5.1 Speaks/Beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
WD 150GB Raptor (Games) & 2x WD 640GB (System)
PC Power & Cooling 750w
Homebrew watercooling on CPU and GPU
and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
Windows 7 Utimate x64
Two more cons:
1. high power consumption
2. RAID issues (there is a thread around here somewhere)
Docendo discimus (lat.)
