07-29-2007, 05:03 AM
#326
Xtreme Legend
Originally Posted by Lightman
Sweet!
First test with proper mousepots coming  !
Now I can't wait till Tuesday!
Hope you have truck full of LN2 around the corner ...
I'm going to a event (Assembly) in Finland with ASUS next week and hopefully I'll have the pots by then for some live benching with em. We have orderd 100 liters of ln2 for the event so it should be all good
07-29-2007, 07:54 AM
#327
Wow, those are gorgeous pots! Keep us posted about the event. Good luck as well!!
__________________
Gautam: "I like the black one... its 4" longer too... but its not 'high performance"
Mobo------------Asus Commando
CPU-------------L628B121-E6600(Apogee GTX)@ 505x8@ 1.53V Actual (Still Testing)
Vid--------------BBA ATI X1900XTX @ 765/900@ 1.550/2.217 volts (Swiftech MCW60)
Ram----------- 2x1024 OCZ PC2-8500
HDD------------74GB Raptor, 2 320GB 7200.10's Matrix Raid
Optical--------- DVDRW's- Dual Lite-On LH-20A1S
PSU------------ Thermaltake Toughpower 1200W
Water Cooling- PA120.2 & PA120.3 (San Ace fans), Dual DDC2's with Petra tops, 7/16" lines
Benchies
PCMark05: 9420 3DMark06: 7751 3DMark05: 13203 3DMark 03: 26301 SuperPi: 12.782
Project: Clean Overkill
07-29-2007, 08:51 AM
#328
Wow.. reallly nice pots.. excellent... really, he have make a perfect work..
07-29-2007, 03:42 PM
#329
Champion
Those are some beefy looking Mouspots, should work very well running without a coldplate.
07-30-2007, 01:16 AM
#330
OCTeamDenmark Staff
Now that is reall ART
__________________
OCTeamDenmark.com Staff
Cooled and sponsored by Coolerkit.dk
Gigabyte EP45 Extreme | QX9770
2x1 Gb G.skill DDR3 PC3-16000
2xFoxconn 3870, Vcore,Vmem,OCP,Cap mods.
22" Samsung 225BW | Antec 1000 Watt
Mach 2 GT (moddet by t!m) | MX510 - Func F10s
07-30-2007, 02:06 AM
#331
Xtreme Legend
I think 1300MHz for a singel card is within reach with these pots. Should be no problem really looking at how 1240MHz ran with my rev1 almost holding -80C with 1.55V. Well over 1200MHz should be no problem for Crossfire.
07-30-2007, 03:47 AM
#332
Wow nice..
It seems i can get the Asus Blitz, the 2 versions Extreme and formula, will go for the DDR2 versions, You can't get them Kinc?
07-30-2007, 07:37 AM
#333
Xtreme Legend
Originally Posted by Lane-k
Wow nice..
I have enough of em  But I lack a QX6850 to run on em. QX6700 wont clock at all on those cards maxing at 4900MHz, really strange.
07-30-2007, 09:31 PM
#334
Kinc, can you get quad penryn system (of course if it will be able to hit 5GHz) to run 2x2900XT ? we're are waiting for >=26100 '06 score
07-31-2007, 01:40 AM
#335
Gulftown addicted
My ASUS Blitz Formula, is not as overclockable as my other two ABIT AW9D-MAX mobos.....I mean that with the AW9D I can bench on ait 3Ds at ~4060MHz and with the Formula maxed out at ~4000MHz.... BUT Formula IS dumn fast, VERY easy to use, it boots EVERY TIME no matter what and I have enjoed it since I got it.....I'll give it a try under LN2 to see how it will react...
07-31-2007, 02:23 AM
#336
Great job Kinc!
hipro >> does the lower clocks on Blitz are caused by bad Vcore section?
__________________
07-31-2007, 02:43 AM
#337
What was the CPu you have use.. ?
07-31-2007, 02:47 AM
#338
Gulftown addicted
Originally Posted by ent
Great job Kinc!
No I don't think so coz I've tested many VCore feeds.....
What was the CPu you have use.. Kinc was saying his QX (RIP) was not overclocking well on it
X6800 and QX6700....
QX6700 does on AW9D ~4000MHz 3Ds and on Blitz ~3900MHz....Though on Blitz it's MUCH easier to overclock/play with it....
07-31-2007, 02:49 AM
#339
ok.. strange.. it seems KInc is right with that, the "old" quad don't overlock same with it..perhaps QX6850 will go better with it.. but i can think to the bios imaturity.. I plan take one when i can..
07-31-2007, 04:05 AM
#340
Xtreme Legend
The same thing for me with blitz compared to p5w64 on air. I had a difference of 100MHz. But as you say the perf is very good, a tight perf card indeed  And crosslinx works very good!
07-31-2007, 09:14 PM
#341
I can't remember what is the Cfire PCI ex on the Blitz?.. 2x 16x or 2x 8?
07-31-2007, 10:02 PM
#342
2X8 would be great to see what 2X16 would give
__________________
08-01-2007, 12:03 AM
#343
Xtreme Legend
2x8, limiting the perf. indeed (but far better than 16/4). X38 samples is around the corner, will be very interesting to test with 2x16 PCIE2.0.
08-01-2007, 12:25 AM
#344
yes.. specially cause it seems the 2900 have been designed for PCIEX 2.0.. even if the card is not only designed for, the 8pin connectors and the increase when you up the PCI exrpress frequencies show they will really scale with PCI ex2.0
08-02-2007, 10:51 AM
#345
Agreed! Must see 2x x16 pci-e scores!
08-02-2007, 01:49 PM
#346
What are you guys using in those screenshots to OC? Is that RivaTuner?
__________________
Q6600 G0 @ 3.8 (475x8) 1.496V || ASUS Maximus Formula X38 || 4x2GB Geil Evo One DDR2-950 5-5-5-15 ||
Sapphire 4870X2 857/1000 || XSPC Delrin full coverage block || MCP655 || D-Tek Fuzion Nozzled ||
Black Ice 480GTX 8 120mm Yate Loon push/pull || Silverstone DA850 PSU 70A +12V || Auzentech Prelude ||
Vantage P15071 in Vista x64
08-02-2007, 01:59 PM
#347
If u refering to the screenshots on page 1 , thats Atitool 0.27
__________________
CPU : Intel Core 2 Extreme QX9650
MB : Asus P5E X38 Rampage bios
RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
VGA : Sapphire HD2900XT
Power : Antec Quattro 850w
Storage : 1 x 74GB Raptor + 2 x 500gb WD 16Mb + 1 x 750GB Samsung 32Mb
DVD : Samsungs DVDwriter Sata + Liteon DVD
Sound : Creative XFI Xtrememusic
Cooling : D-Tek Fusion + D-Tek Fusion GFX
Monitor : Samsung 226BW
Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
08-03-2007, 06:10 PM
#348
hi
can you tell me how you oced the cards in Crossfire mode?
because i have got also two HD2900xt @ my Q6600
and i can not find out how to clock the grafik cards at crossfire mode
here some 3dmark06 benchs from me
Intel Q6600 @ 3407 MHZ
Asus P5B Deluxe
2x1 GB Gskill @ DDR2 946 5-5-5-15-2T
Treiber ATI 7.7 Final
Singel HD2900xt @ Default:
3DMark Score 12440 3DMarks
SM 2.0 Score 4647 Marks
SM 3.0 Score 5245 Marks
CPU Score 5152 Marks
http://service.futuremark.com/compare?3dm06=2628725
2x HD2900xt @ Crossfire Mode @ Default:
3DMark Score 17181 3DMarks
SM 2.0 Score 7011 Marks
SM 3.0 Score 7760 Marks
CPU Score 4932 Marks
http://service.futuremark.com/compare?3dm06=2628585
And here a comparison link where you can see that the grafik cards at Crossfire mode at different CPU Speeds
Q6600 @ 2,4 GHZ vs 3,0 GHZ vs 3,4 GHZ
http://service.futuremark.com/orb/mu...=1&c=387061186
Feichti
08-04-2007, 12:20 AM
#349
You need to flash the cards with new BIOSes for CF overclocking to work right now.
//Andreas
08-04-2007, 12:34 AM
#350
//Andreas
is there anywhere the files or the tool/instruction to to this ?
because i think under water 850/1000 would be no problem for the cards
feichti
__________________
Lian Li V2000: Intel Q6600@ 3600 MHZ @ Watercooled D-Tek FuZion Universal
Gigabyte GA-X48-DQ X48
4GB DDR2 1066 Kingston @5-5-5-15 @DDR2-1066
2x Sapphire HD2900xt @ 930/940 @ Crossfire @ Watercooled EK-FCR600 CF Extreme
2x Raptor 73.4GB 10k rpm 16mb @ ICHR9
Cooled by Thermochill Trippel & Dual & Laing Ultra
See Pic at www.hardware.feichti.com
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
