XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 12-12-2007, 04:31 AM   #1801
necron66
Originally Posted by allen41547 View Post
I have the f7b on my machine with a q6600. Went to test a e4300 on my board and had to downgrade to f6 to see chip. Just wanted everyone to know the f7b doesnt support all chips. ALLEN
F7b only shows 3 core on my Q6600.
necron66 is offline   Reply With Quote
Old 12-12-2007, 10:08 AM   #1802
Getttosmurf
Getttosmurf's Avatar
Hi , whats the best bios for overclocking q6600 on p35 Dq6 ?
Having some problems with my board , anything past 1.5ish vcore and it seems to get unstable , perhaps some component on mb getting warm ? Im running 4x1GB pc8500 ballistix around stock speeds atm seems to work fine. increased mch and
vfsb voltages slightly just to take that out of the equation. I can boot 4 ghz at 1.6v bios setting but prime95 crashes instantly but heres the strange part the same thing happens at 3.8Ghz 1.6v but 3.8 1.5v primes for 20 minutes before one of the cores fail. Cpu gets kinda hot at 1.6v quadprime around 70c measured with intel tat , speedfan and everest. Coretemp crashes the rig instantly for some reason.
__________________
Q6600 | P35 DQ6 | 4x1GB Ballistix8500 | 8800GT 512 | PC P & P 750w | WC Mcp655, D-tek Fuzion, Maze 4, Bip3 |
E6600 | Abit AB9 QuadGT | 3x1GB D9GMH | 7900GTO | Silverstone Zeus 850W | Aircooled |
E2160 | Giga 965 Ds3 | 3x1GB D9HNL | 7600GS Silent |Seasonic s12 600w | Aircooled |
Getttosmurf is offline   Reply With Quote
Old 12-12-2007, 10:48 AM   #1803
Klimpen
I actually think your CPU is overheating and thus making Prime shut down.
You said it yourself with the "3.8Ghz 1.6v but 3.8 1.5v primes for 20 minutes before one of the cores fail." -statement.
That is probably the reason for one core shutting down.
I guess you need more cooling!
I see you have 4xBallistix. Which ones do you have? An image or a link perhaps? Are they running fine and how high have you reached with 4 of them ?
Klimpen is offline   Reply With Quote
Old 12-12-2007, 12:05 PM   #1804
Getttosmurf
Yeah i was thinking its a cpu heat problem but its kinda strange since i see people running 1.5-1.55v on air and im on a decent watercooling setup and cant run 1.55v.
I have the pc8500 non tracers havent tested them much yet but 600Mhz 5 5 5 15 2.20v seems ok 520Mhz is stable around 2.05v havent tested lower voltage yet. Theres a thread about them here http://www.xtremesystems.org/forums/...d.php?t=143009
__________________
Old 12-12-2007, 01:53 PM   #1805
hifiking
hifiking's Avatar
The new BIOSes had some errors over 1.5vcore I my memory serves me right. I'm using F7d now, but haven't had time for OC latly, so I don't know if its any better.
hifiking is offline   Reply With Quote
Old 12-13-2007, 08:12 AM   #1806
Family man 72
Family man 72's Avatar
F9 bios is working great with P35-DS4 rev 1.0 Actual voltages are now in bios and there is also option for loadline calibration. With it enabled I could clock higher than bios F6. Also noticed that now cpu-z shows 1.520-1.536V load when 1.575V set in bios With bios F6 cpu-z showed 1.504-1.520V when priming.
__________________
Asus P5Q Deluxe
Q9650@4.2GHz, 1.2875V
2x2GB Mushkin XP6400
Club3D Radeon 4870X2
Samsung SATA DVD-burner
1.25TB HDD
Chiectec full tower
Zalman ZM850-HP
BenQ G2400W
Vista64 Ultimate
Watercooled with PA120.3 & BIX3,Laing DDC,Swiftech Apogee GT & EK FC Acetal blocks
Family man 72 is offline   Reply With Quote
Old 12-13-2007, 10:28 AM   #1807
fausto412
i wonder if loadline calibration is coming to p35c board bios. anybody know? i wish gigabyte would communicate more with us.
__________________
C2D 6750 G0 @3.6 GHZ 1.40 Vcore (1.36 Actual, 1.32 Vdroop)
Scythe Ninja Rev. B CPU Cooler
Gigabyte P35C Rev 1.1 F10
2 GIGS OF OCZ Platinum Rev 2.0 PC6400 @ 900 MHZ w/ 5-6-6-17 Timings +0.3 VDIMM (2.26 Volts actual)
BFG-TECH 8800GTS 512mb @ 750/1050 w/ G92 chip
Antec P180B Rev 1.1(P182 minus painted insides)
Sound Blaster Fatal!ty XtremeGamer w/64 Megs X-ram
Logitech G15 Keyboard
Logitech G5 Mouse
fausto412 is offline   Reply With Quote
Old 12-13-2007, 12:47 PM   #1808
jonxm05
Angry Unusual FSB behavior
I am new to overclocking. This is the first time I haver ever bought hardware with overclocking in mind
So this is what I put together
Gigabyte P35-DS3R Rev 2.1
Intel E2160
2 GB OZA PC 6400
Had it all set up on the table open system and was testing different settings. I was able to get the system up to 3.2Ghz stable and cool using 355 FSB vcore at 1.47 and memory multiplier at a 2.4 ratio giving me a small overclock on the memory
Took it all apart & put everything back together this time inside my case. Reinstalled the OS while playing around with Raid options.
About a week latter I noticed that the system felt a bit slow so I ran CPUZ to see if the overclock was still in place. The system was back at 1.8Ghz.
I quickly ran back to the BIOS to reset the overclock but the bios is set correctly. the system is just ignoring the FSB setting. now I cab set the FSB anywhere from 200 -700 with no affect on the CPU clock in post
What have I missed or done wrong?
Could the move to the case have caused this somehow?
Is it possible one of the component of the broad is damaged ?
Should I be considering the RMA approach?
Any help would be greatly appreciated as I can not get a reply form the Gigabyte support
thanks
Jonx
jonxm05 is offline   Reply With Quote
Old 12-13-2007, 02:06 PM   #1809
zsamz_
Xtreme Guru
zsamz_'s Avatar
take battery out for a few minutes make sure no power going to the board
__________________
evga p55-ftw+i7 860 @4.1+megahalems
rampage extremeII 920 Batch# 3849B018 4.4@1.38v
gigabut p55-ud4p died after 4 days
e8600@ 510x9 1.38v +thermalright 120X
rampage extreme500x9 1.34v
dominator 1800 cas7
hyperx 2k cas8
northq blackmagic 850
p35c-ds3r bios suks
gigabut x38-d6q dead thank god
ballistix 8500 1240mhz@2.02v 5++sets of d9 downsizin
zsamz_ is offline   Reply With Quote
Old 12-13-2007, 02:53 PM   #1810
jonxm05
Smile yess
Yes !!!!!! I'm back in the game
Zsamz Thank you very much I have been searching the web for almost two weeks.
BTW just for interest is there a difference between removing the battery and resetting the Bios with the jumper
Jonx
Old 12-13-2007, 06:27 PM   #1811
scoobie
oc
well thanks alot peeps yous are very friendly in here!
scoobie is offline   Reply With Quote
Old 12-13-2007, 09:07 PM   #1812
zsamz_
Xtreme Guru
zsamz_'s Avatar
Jonx
you welcome
yes big difference
in worse cases you gotta leave battery out for a few hours even overnight till all juice drains out of the board
__________________
dominator 1800 cas7
hyperx 2k cas8
p35c-ds3r bios suks
Old 12-13-2007, 10:13 PM   #1813
road-runner
Xtreme Cruncher
road-runner's Avatar
Got a DS4 from NewEgg today and its a rev. 2.1. I noticed when I started it up it had flashing LEDs on the MB. Board come with F8 Bios. I was looking for an updated bios on Gigabytes website but I do not even see a rev. 2.1 on there. Is 2.0 the same bios?
__________________
road-runner is offline   Reply With Quote
Old 12-14-2007, 02:45 AM   #1814
Getttosmurf
So tested some more, tried really relaxed memtimings and standard mode instead of turbo and some other settings and managed to prime for an hour at 3.9Ghz 1.5v but then i tried playing cod4 and got an instant shutdown , no bluscreen no freeze. Tried 3.8Ghz
3.7Ghz etc and i keep getting these shutdowns not the usual bsod or freeze = ( anything past 3.6Ghz no mather what settings. Really whised there was a 1:1 setting so i could take the memory out of the equation , altho memtest runs fine.
Having some problems with my board , anything past 1.5ish vcore and it seems to get unstable , perhaps some component on mb getting warm ? increased mch and vfsb voltages slightly just to take that out of the equation. I can boot 4 ghz at 1.6v bios setting but prime95 crashes instantly but heres the strange part the same thing happens at 3.8Ghz 1.6v but 3.8 1.5v primes for 20 minutes before one of the cores fail.
__________________
Old 12-14-2007, 04:34 AM   #1815
Millyons
Millyons's Avatar
so basicly the loadline doesnt do nothing major, just makes the vcore closer to bios setting and it doesn't eliminate the vdroop.
Millyons is offline   Reply With Quote
Old 12-14-2007, 02:07 PM   #1816
SySTaXer
Originally Posted by road-runner View Post
I got the Swiftech MCW30 on a P35 DQ6 with no problems...
Thank you for the info road-runner.
__________________
Q6600 G0
GIGABYTE P35-DQ6 - ASUS MAXIMUS RAMPAGE
2x2GB G.SKILL F2-8000CL5D-PQ - 2x1G CORSAIR DOMINATOR XMS2-8500C5D -2X1GB PATRIOT PC2-9600 C5
8800ULTRA - X1900XTX -HD4870X2
TOUGHPOWER 1200W
SySTaXer is offline   Reply With Quote
Old 12-14-2007, 07:51 PM   #1817
omz
Anyone know the current best BIOS for the DS3P? I'm still running on the F4 BIOS that came with it
__________________
Intel E6600 (L630F)
Gigabyte P35-DS3P
2 x 1gb Crucial Ballistix 1066
ASUS EN7800GTX
2 x 250gb WD 2500KS in RAID-0
OCZ Powerstream SLi 520
CM Centurion 5
omz is offline   Reply With Quote
Old 12-14-2007, 08:41 PM   #1818
[XC] DragonOrta
Xtreme Cruncher
[XC] DragonOrta's Avatar
Send a message via AIM to [XC] DragonOrta Send a message via MSN to [XC] DragonOrta Send a message via Yahoo to [XC] DragonOrta
The best one that I've ran is the F7b beta bios. Station-drivers had it, but they were having some connectivity problems a few days ago, so I put it up on Rapidshare. My post with the link should be a page or so back.
__________________
A wolf in wolves clothing.
[XC] DragonOrta is offline   Reply With Quote
Old 12-14-2007, 08:47 PM   #1819
omz
i see. thanks for the version
btw, does anyone know how to control the fans on the mobo? my s-flex is way too loud for my liking in this open air rig...
__________________
Intel E6600 (L630F)
Gigabyte P35-DS3P
ASUS EN7800GTX
CM Centurion 5
Old 12-15-2007, 12:17 AM   #1820
Family man 72
It doesn't eliminate droop totally; it is now 0.016, With F6 bios droop was 0.032. So it is working
__________________
Asus P5Q Deluxe
1.25TB HDD
Chiectec full tower
Zalman ZM850-HP
BenQ G2400W
Vista64 Ultimate
Old 12-15-2007, 11:07 AM   #1821
swaaye
swaaye's Avatar
You know, the most annoying thing about the P35-DS3R is that it undervolts the CPU even at stock. I see 1.17 v when Primeing. As such, I can't get as much of an overclock with normal votage settings, meaning that I can't get a sweet 3.2 GHz without increasing the volts, which in itself means no nice power-save C1E idle voltage.
I was messing with a G33-DS2R yesterday and found that it has much nicer voltage delivery. Of course, I was just running a E6750 @ 3.2 GHz; no quad core there. Stock volts, 8x400 is a nice, cool, ultra-speedy setup though.
swaaye is offline   Reply With Quote
Old 12-15-2007, 11:21 AM   #1822
Repliquant67
Repliquant67's Avatar
I have tested the F7b on the P35 DQ6 with a QX9650. There is a lot of issues : impossible to clock over 4Ghz in the bios (with setfsb, yes) and there is problems with the vcore : sometimes, I have to change the value of the the vcore (for example, if I have 1.4V, I need to use 1.42V or 1.38V...) because it is impossible to load windows.
In other ways, ocing results are not bad : with water cooling : max fsb with my qx9650~470mhz, 3dmark06@10x465mhz@1.6V, spi1M@4750mhz@1.6V, prim95 10h@4300mhz@1.49V
Gigabyte seems to be not hurry to release a news bios for the P35 DQ6
Repliquant67 is offline   Reply With Quote
Old 12-15-2007, 03:53 PM   #1823
Ryouko
I have a question for the people who have a p35-ds4:
I have been running memtest86+ on it (usb legacy disabled) with 3 different sets of corsair CM2X1024-6400C4 and then I tried the Crucial Ballistix BL2Kit12864AA804 and they both failed, both with using the pc35-ds4 default configuration, and with the optimized configurations that are recommended by the memory companies website.
However, I never noticed any crashing while playing games, errors when encoding videos or winraring my project files. I looked upon their faq and it seems like it doesn't give out false positives.. should I be concerned?
I was wondering if anyone else was having the same problems, and if memtest86+ ver 1.70 is giving me false positives.
Thank you in advance!
Ryouko is offline   Reply With Quote
Old 12-15-2007, 09:20 PM   #1824
miahallen
World Champion - IRONMODS
miahallen's Avatar
Interesting...What board revision, and what BIOS?
I have a Rev.2.0 F9b and just tried running memtest86+ v1.7 on some Crucial Ballistix PC2-6400 that previously passed with flying colors...this time they started popping up errors immediatly. I backed off my speeds/timings, but it did not help. They previously passed without error on F7 & F8...
Consequently, I just completed an RMA request last night for a G.SKILL 2x2GB PC2-8000 kit I just got from newegg last week because they were failing memtest the same way (even with relaxed speeds/timings). Now I'm thinking maybe they're OK.
I think I may try flashing back to F8 and see if the problem remains.
__________________
THE POST COUNTER IS NOT AN INTELIGENCE METER!
Ross: "Gautam or Vince? I think if we just wave an open thermos of LN2 under their noses, they'll go into a trance and we can extract whatever information we need without having to resort to force LOL"
Gautam: "I remember when Mark started doing DI I thought he was psycho and that it was a dangerous, reckless cooling method that had no future."
www.ironmods.com
Heat
miahallen is offline   Reply With Quote
Old 12-15-2007, 10:34 PM   #1825
Ryouko
I have the rev 2.0, bios ver F9 (2007/11/30), I unfortunately didn't run memtest86+ ver 1.7 while I had the F7 bios so that's why I kept exchanging those memory sticks. I felt bad for doing that and thinking it was the ram.
I'm not too sure how I would be able to downgrade my bios- I wasn't able to update the bios update through the bios but through the gigabyte bios web update program (@bios)... I tried to update it through Q-Flash, but never got it to work...
I hope it's the bios and if it is a fix might be in the works!
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
