Page 26 of 104 FirstFirst ... 16232425262728293676 ... LastLast
Results 626 to 650 of 2585
Thread: Official GIGA P35-S3/DS3/DS3R/DS3P/DS4/DQ6 bios/info thread
  1. #626
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by kadir_slayer View Post
    hi
    I have a question.. I once loaded F4b bios and it was 3+ more hours orthos stable at 490fsb but when I rebooted , it didn't open as it was an overclocking failure. and one of the times it booted, all the things in bios turned to default settings, ı mean like clearing the cmos, and it repeated sometimes when an overclocking failure happened. bu the performance was better than f3a, I mean memory latency etc, Now currently ı'm using f3a bios but when I saw u using f4b without any problem ı want to reload it. did you experience something like that similar to my problems with f4b bios?
    to be honest the only thing i see f4b is good for is memory to reach 1200+
    i tried it before and it wasnt stable @ performance level 7 @ 1000mhz
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
  2. #627
    Aug 2006
    Quote Originally Posted by Klimpen View Post
    Oh man, this is a massive thread. Thank you all for contibuting to all this knowledge on one single place. I have picked up a lot to try when I get home from vacation.
    I also got a note in "PC-Health" that say DDR18V - Fail
    What is that?? It doesn't matter if I set it to AUTO or +0.550 (default for my mem)
    System:
    P35-DQ6 (F4)
    E6600 (good for 4.05)
    OCZ PC-9200 FlexXLC DDR-1150 (on water along with CPU)
    HD 2900 XT
    i also get the vdimm "fail" message using xclio greatpower 600w or an antec 500w smartpower on the p35c-ds3r. hope it's just the bios misreporting
  3. #628
    Dave's Mentor!
    May 2007
    montreal
    lol i get that too its ok
    why is your system temp so high?
    did you take off the northbridge heatsink n put arcticsilver?
    i run @ 510 fsb n my temp is 30c
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  4. #629
    Dave's Mentor!
    May 2007
    montreal
    well my system not stable @ 4-4-4-4 or 4-4-4-8 with f4b with f3b was ok
    but its good for 1224mhz+ with f4b i hit 10100 read 50.5 latency
    but not 100% stable
    i might go back to f3b
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  5. #630
    Aug 2006
    Quote Originally Posted by zsamz_ View Post
    yes, i did. that's not my board that's the pic from klimpen's post. ya scared me at first and thought my as5 job was bad
    looks like mixed verdict on f3b or f4b. i'm still on shipping f2 and can't get over 490, so guess i'll start with f4b since looks like that's getting a tad higher freq
  6. #631
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by burn what? View Post
    oh i forgot i put a fan on the heatsink lol
    btw u better off with f3b use f4b if u want 1222mhz+ for memory
    go with f3b 510fsb best results for me unless your memory can do 1222+
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  7. #632
    Aug 2006
    yeah, i'm looking to push 2x1gb ocz flex 9200's into the 1200's. on air though, no water through them, but i read they can make 1300. i usually superglue a fan to the nb heatsink but in testing i held it there and still couldn't get over 490, made no difference, so not sure if i'm gonna bother with this board.
  8. #633
    Jan 2007
    well i can confirm what vld says about the memory at 1200 my system will not boot at all if i set my memory between 1101-1210 anything below and up to about 1260 above the system will boot ok.
    i am currently running my E6600 at 7*505 with memory at 606 5:6 divider, it will boot at 7*515 but prime will fail after about 10 minutes
    thks
  9. #634
    Sep 2006
    You guys are not doing something right, you dont need such high FSB to get the numbers... use higher multi and less FSB, this will result in a stable system plus good numbers. Try it... High FSB is only needed if u have like a 6300 and want to push it... What you guys are doing by lowering mulitplier and increasing fsb is putting more stress on the system. try to keep FSB under 417. This chipset is designed for much higher memory mhz, so it is prolbably the high FSB that keeps your system unstable not the memory mhz.
    For example try the following settings on for P35C F4B bios:
    FSB: 410
    cpu multi: 8
    mem multi: 3.0
    Try that in performance level 6 and then 5 for d9 chips... Mine is really stable and I like this setting. Make sure the CPU is getting enough voltage first by running small ffts (usually cpu needs 1.5 in bios at 3280 mhz) and also u need +0.4 for vdimm.
    Basically try using the highest mulitpliers...
  10. #635
    Apr 2006
    NIce thread guys
    I just finished setting up my new rig with H20 and she running nice and cool @ 3.2ghz 8x400 with 1.31v on this lucky quad
    [IMG][/IMG]
    Im able to run my memory with the 3.0 divider which gives 1200mhz with 5-5-4-7 timmings option 2.
    So far im extremely dissapointed with my memory scores, 7660/7700 in sandra and 9000 read/7300 write/7800 copy/ 64.3 ns in everest
    [IMG][/IMG]
    I was doing a hell of alot better with my asus 680i with cheap ocz gold pc6400@800 4-4-4-12 1t, was getting
    7800/7900 sandra and 17200 read/7228 write/ 6937 copy/ 50.5ns
    [IMG][/IMG]
    Am i doing something wrong or is there some memory tweaking to be done?
    Q6600 GO @3.6Ghz 1.45v
    Crucial Ballistix PC8500 1200mhz 5-5-4-7@ 2.2v
    BFG 8800GTX OC @ 625/2000
    Gigabyte GA-P35-DQ6 F3
    Swiftech H20-premium
    Thermaltake Armor
    Ultra X-Finity 800w
    Sharp Aquos 37" LC37GP1U DVI-D 1920x1080 6ms
    Logitech Z-5500
    Xi-Fi XtremeGamer Fatal1ty
  11. #636
    Dave's Mentor!
    May 2007
    montreal
    do more reading
    you should hit @ least 10100 in read
    you every try 500+fsb
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  12. #637
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by vld View Post
    FSB: 410
    cpu multi: 8
    mem multi: 3.0
    i'm gettin best performace 500+fsb
    3 years warranty
    if x38 any good i'll keep this one as a backup
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  13. #638
    Jan 2007
    FSB: 410
    cpu multi: 8
    mem multi: 3.0
    i can run 505 stable and still hit 1200+ latency at 50.2ns
    with performance at 8 i have not try 7 yet and system is stable
    so you are saying that i should go lower on the fsb and higher on memory?
  14. #639
    Jan 2007
    Thank you very much. It's always good to see other with the same "error" since I then know that all is OK so to speak.
    I won't worry about it no more.
    The same to you zsamz, Thanks for answering!
    I have a case with absolutely NO fans running when I don't bench. I have WC on CPU so the air is pretty much non-moving at all.
    I might take it apart some day just to be sure about good contact.
    Nice to see someone with the same setup as me. I have the exact same mem's but having trouble to reach any high with them.
    Would you like to start exchange ideas with each other? Maybe we can set a new "high" on these babies
    If you feel like it you could send me a mail and we can continue there?
    klimpen |at| jobbig.se
    I will be back home tomorrow and then the tweaking starts...
  15. #640
    Aug 2006
    need opinions before making final decision:
    2 rigs with same memory/psu/etc. 1 is p35c-ds3r and 1 is p35-ds3r. also have 1 e6600 and 1 e6450. the p35c i had the 6600 in and couldn't get over 480-490 fsb, the p35 i had the 6450 and got to 520 stock straight out of box no prob. so i thought the fsb was better on the p35. put the 6600 in the p35 and same thing, now couldn't get over 480-490 fsb. so it seems it's the 6600 limiting fsb. so do i use the 6450 with higher fsb though lower multi or 6600 which has lower fsb but a 9 multi? i guess at this point the boards don't matter either way, just that the p35c has ddr3. any opinions would be appreciated
  16. #641
    Dave's Mentor!
    May 2007
    montreal
    you need f4b bios to go over 1200mhz f3b wont do it
    for 24/7 you better off with 4-4-4-4 timings or 4-4-4-8
    510fsb read 9700+ latency 49-50 f3b bois "f4b unstable for tight timings"
    fsb 510+ not stable
    i wished i had better cpu to test 550-620fsb
    but it commin soon lol
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  17. #642
    Aug 2006
    has anyone used f5b bios on the p35? the p35c and p35 have to be pretty much the same bios. i searched back in the thread and didn't see anyone using f5b yet on the p35
  18. #643
    Jun 2007
    I am using F5B. It fixed a weird issue I was encountering with my overclock being reset on some cold boots, even though I've done 24hr+ of memtest and orthos. It happens very rarely now, about 5% of the time instead of 50%.
    I suspect it has something to do with the strap setting for the E2160. I'll be getting a new CPU as soon as the price cuts take effect in Canada.
    So F5B gets a thumbs up from me, seems to be more stable, not that any of the other BIOSs ever gave me any serious trouble.
  19. #644
    Dave's Mentor!
    May 2007
    montreal
    where to find the f5b for the p35c
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  20. #645
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    hello everyone and good job on all this information you guys have gathered for this board.
    I just received mine yesterday (P35-DS3R) and was wondering how to check which bios version i have. Also was wondering how important it is for me to update the bios
    Nikon User
    Nikon D200 (Gone =( )/D300
    Nikkor 18-105mm(Gone) // Nikkor 50mm 1.8 // Nikkor 55-200VR(Gone)
    Tokina 12-24 // Tamron 90mm //
    Manfrotto & Benro Legs // Benro Ballhead.
    Current Lust = 80-200 Or 70-200VR1 <--Pending
    No more computer parts for me... Well for now until I
    really REALLY need to upgrade.
  21. #646
    100% Load 24/7
    Mar 2005
    Seattle
    When it first posts, it shows the bios version. Also, the mainboard tab of cpu-z shows the bios version.
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
  22. #647
    Sep 2006
    i dont think it exists yet. Basically u know what. We have to stop all the overclock testing until a good bios comes out. And it will come out. the p965 series only became good on the F9 bios. I think the p35 will become good on like F6 or F7
  23. #648
    Dave's Mentor!
    May 2007
    montreal
    yup u right
    i'm back to f3b f4b shaky with low lattencies
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
  24. #649
    Xtreme Mentor
    Jan 2005
    Official F3 bios for the P35-DS3L:
    http://tw.giga-byte.com/Support/Moth...S&FileID=12907
    Official F3 bios for the P35-S3L:
    http://tw.giga-byte.com/Support/Moth...S&FileID=12908
    Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
  25. #650
    Aug 2006
    tested vdimm with dmm, bios is overvolting by +.1
    +.4 setting in bios is 2.3
    +.5 in bios is 2.4
    supposedly default is 1.8v so +.4 should be 2.2 and +.5 should be 2.3
    this is on the p35, i'll test p35c later. let me know if this has already been posted for these boards.
    *****UPDATE*****
    the p35c is overvolting even more. same psu, +.5 gives 2.5v showing on the dmm.
