4. Hazards
The hazards of liquid nitrogen are largely related to the large volume of gas produced on evaporation and to the liquid's low temperature. Its very low viscosity means that it rapidly and completely covers surfaces on which it is spilt and it easily penetrates cracks and voids. This means that any spillage on clothing will penetrate much more readily than, say, water. Large spillages on other surfaces may affect areas beneath the surface, by damaging materials or even by causing oxygen depletion in areas remote from the spill.
(a) Asphyxiation
On boiling, liquid nitrogen produces approximately 700 times its volume of gas. The resulting displacement of oxygen from the atmosphere may be sufficient to cause asphyxiation. There is no preliminary warning of oxygen deficiency caused by the addition of nitrogen. This is a significant hazard, which has been responsible for a number of deaths in research institutions over the past few years. In these incidents, asphyxiation is usually sudden. The victims inhale air with little or no oxygen content, causing immediate collapse into a layer of dense, cold, nitrogen-enriched air. Unconsciousness followed rapidly by death is inevitable without immediate rescue and resuscitation. Rescue attempts often result in the rescuers being overcome as well.
Smaller leaks or spills, or normal boil-off from liquid nitrogen containers in confined spaces (e.g. poorly ventilated small rooms, or cold rooms) may give rise to lesser reductions in oxygen content, but they may still carry a risk of asphyxiation. The risk of asphyxiation must be assessed wherever liquid nitrogen is used or stored, taking into account the volume present in relation to the room volume, the likelihood of leakage or spillage, the normal evaporative losses that occur with liquid nitrogen use and any ventilation arrangements.
