Just found this, looks good much better than stock mosfet cooling
Source: Thermalright
Thermalright at it again
-=The Gamer=-
MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
-=The Server=-
Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
Heat
Very nice!!!
Intel i5 2500k @ 4GHz || Gigabyte Z68 UD3 || Vengeance 8GB 8-8-8-24 1T || CM Stacker 810
ATI 4850 || Samsung Spinpoint F3 x 2 || SilverStone ST60F
Asus DVD RW +- || Logitech G15 || MS Intel-eye 1.1|| CMV 19" Wide-Screen || Scythe Ninja
Yes, this really looks like some effective cooling blocks! Will be looking for them...
- DFI LANParty LT X38-T2R Rev. AA1
- Core 2 Duo E8500 @ 4009MHz, 1.31V
- TRUE @ 2x Scythe S-Flex SFF21F, 5V
- 4 x 2GB G.Skill Pi PC2-8800
- MSI R4870X2-T2D2G-OC
- 3x 74GB Raptor ICH9R Raid0 @ 128KB Stripe Size
- Plextor PX-716SA/T3KB DVD-RW
- Auzen X-Fi Prelude @ TI OPA637AU - Thule - Dali/Ultimate Ears - Argento
- SilverStone OP700
- CM Stacker 830 Evo
- Eizo FlexScan HD2441W - Audioquest DV-X
- WinVista Ultimate 64bit SP1
Posted before in the aircooling section
They are out now though.
http://www.svc.com/hr-09u.html
http://www.svc.com/hr-09s.html
$19.99 each.
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
Each?! WTF? Unless two come in a package, that's ubber rip off.
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
Depends, plenty of people can afford that, and they WILL buy it. (esp. since all thermalright stuff contributes majorly to the wow factor of your computer). I'm not one of those people who feels comfortable with dropping 20 bucks on just mosfet cooling, but they're out there In fact, I expect this to sell very well, because its actually a decent cooling solution for mosfets.
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
there are only 2 to match teh type of motherboard....
FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
eXceed TJ07 worklog/build
do these just attach by thermal tape?
Silverstone Temjin TJ-09BW w/ Silverstone DA750
Asus P8P67
2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
8GB G.Skill DDR-1600 7-8-7-24
Gigabyte GTX 460 1G
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
1 X 120GB OCZ Vertex
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
Um when did alu HS conduct heat better then copper HS? with copper HS coming standard on some boards?
[SIGPIC][/SIGPIC]
what is the diff between the S and U
Soon to be :
ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
Used to be: SaFrOuT
Did you even read the site?
The HR-09 comes in two distinctive designs and types (sold separately); HR-09U and HR-09S. The difference lies in positioning and orientation of the fins and heatpipe. For HR-09U, which fits most major motherboards, sits upright. It is the choice when you have no obstacles to hinder the installation of HR-09U. As for HR-09S, which sits at a slant angle, would be the choice when you have a big CPU heatsink such as the SI-128 and have limited space on your motherboard. But whatever the choice you make between HR-09U and HR-09S, know that you have nothing but the best quality and performance…now working for your MOSFET.
Intel Core i7 920 @ 3.8GHz (183x21)
Gigabyte EX58-DS4 BIOS F5
3GB PATRIOT PC3-10666 DDR3
Sapphire Radeon HD4870 512MB BLACK
2x500GB SEAGATE SATA-II 7200.11
OCZ GameXstream 750W PSU
Antec Three Hundred Chassis
How do they attach. Because thermal tape, or whatever is gonna seriously suck.
Kentsfield Q6600@ 3100Mhz
Asus P5B-E Plus
2GB GSkill DDRII PC6400GBHZ
Albatron Geforce 8800GTX
Thermalright Ultra 120
Corsair 620W HX
74GB Raptor/ X-Fi Platinum
19" CRT NEC 930 SB
Windows XP Pro SP2
- SilverStone OP700
-=The Gamer=-
-=The Server=-
Heat
Soon to be :
Used to be: SaFrOuT
- SilverStone OP700
Funny how boards that doesn't require Mosfet cooling is on the compatibility list. Too bad it doesnt fit the Abit Quad GT. That board needs serious mosfet cooling.
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
very nice another vote for Thermalright!
www.HotOverclock.com Founder & Editor in Chief
Upgrading to X58 ...
Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
abit IX38 QuadGT Rev1.0 (X38 Rev.01)
4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
HDD 120GB Maxtor Max.10 6L120M0
PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
DFI 965-s has holes too.
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
Hahaha, I was about to say the same thing. No way mobo manufacturers are spending that much for copper.
these arent alu are they? i mean its nickel plated copper per usual thermalright correct?
