Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Thermalright IFX-14 cpu heatsink
    May 2004
    ILLinois
    Once more, more new stuff from thermarlight
    Feature
    Larger surface area than any other heatsinks (140mm x 120mm) with option to install one or even two 140mm fans
    Designed for better air flow management to work with the heatsink fans* and the air inside your computer case
    Four large 8mm heatpipes to distribute massive amount of heat fast and efficiently
    Optional to rotate the heatsink 90 degrees to best fit your system configuration
    Multi-platform compatible backplate for installation on vast number and type of motherboard. No need for complicated tools to convert
    Includes a back-side dual heatpipe heatsink (patent pending), which not only additionally cools your CPU but also takes care of the heat coming from the back of the motherboard to extend the life expectancy and stability of your motherboard
    Core 2 Duo and Core 2 Extreme Ready
    AM2 Ready
    Technical Spec.
    Heatsink Body
    - Dimension : L146.2 x W124 x H161 mm (heatsink only)
    - Weigh t: 790g (heatsink only)
    - Recommended Fan : All 120mm & 140mm Fan
    Back-side Heatsink
    - Dimension : L134.5 x W163.5 x H112.6 mm (heatsink only)
    - Weight : 130g (heatsink only)
    - Recommended Fan : All 80mm & 70mm Fan
    Compatibility
    - INTEL: All Intel Socket LGA775 processors
    - AMD: Athlon64 / FX / X2 / Opteron Socket AM2 processors
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    with how good the Ultra 120 + is doing, I wonder how they can possibly improve on the design.
    Sep 2006
    Surat, India.
    Cant wait for this, seems good in teh pic
    Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
    Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
    Xtreme Cruncher
    Sep 2006
    Norway
    Wow
    Im look forward to reviews of theese
    Perhaps they already have sent some sample to Anandtech
    May 2006
    When's this supposed to come out? O_o Looks freaking awesome. Do you put a fan in the middle of it?
    Aug 2004
    Austin, TX
    Quote Originally Posted by Kunaak
    Obviously by sticking TWO of them together
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Wow, goodbye every other heatsink. The coolermaster gemini never even had a chance.
    Formerly XIP, now just P.
    Feb 2006
    IFX-14 = Ultra120 X 2
    Cant wait for it
    when it would be Ready?
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    May 2006
    UK
    i'll take one of these and a cheap Q6600 please, I wonder what this back-side heatsink looks like...
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Nov 2005
    Where the Cheese Heads Reside
    *Checks paints* BRB...
    Damn wet myself on that one, fricken huge. Definatly when does this beast come out, while my heatsink does work great, hey cooler and higher OC I don't mind that one bit that thing is a beast!
    -=The Gamer=-
    MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
    8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
    Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
    BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
    -=The Server=-
    Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
    3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
    Heat
    Jul 2006
    NYC
    I remembered someone in the Thermalright Ultra 120 Extreme thread mentioned that they should have thicker heatpipes. Well there goes your wish
    GG to every other heatsink, Thermalright wins.
    Watch 24!
    Q6600 G0 w/ Scythe Zipang
    A Data 2x2gb DDR2-800
    Corsair 750w PSU
    8800GTX
    320gb Maxtor HDD
    Audigy 2 ZS
    RocketFish case
    Nov 2002
    Juneau Alaska
    http://www.frozencpu.com/cat/l3/g36/...ans-Page1.html
    those are the only 140 mm fans I know of, and they definatly dont impress me...
    Xtreme Cruncher
    Mar 2005
    Lancaster, PA
    Performance PCs has some 140mm fans, including a Yate Loon.
    A wolf in wolves clothing.
    Nov 2002
    Juneau Alaska
    http://www.crazypc.com/products/5750.html
    finally a decent CFM 1400 fan...
    May 2004
    ILLinois
    Nov 2002
    Juneau Alaska
    yep, but look at the CFM...
    even low end 120mm fans will move more air, then these typical 140mm fans I am seeing.
    they seem to be built for extremely low noise.
    me, If I get a heatsink like this, I want all the cooling I can get.
    the max CFM at around 32-34 db is what I would aim for.
    Nov 2002
    Juneau Alaska
    whats most interesting to me so far is...
    "Includes a back-side dual heatpipe heatsink (patent pending), which not only additionally cools your CPU but also takes care of the heat coming from the back of the motherboard to extend the life expectancy and stability of your motherboard"
    that I definatly want to see
  18. #18
    Xtreme Mentor
    Jul 2004
    Ontario
    I'm sure you don't need 140mm 100%. With the heatsink being as beefy as it is I am sure zip tying a high powered 120mm fan will do just fine.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  19. #19
    May 2003
    Edmonton Alberta
    I think 33 DB might be still to high, id like something in the mid 20s for dB myself. OF course im not sure of the pitch that 140mm fans put out.
  20. #20
    May 2006
    Canada
    I agree with kuunaak, I really don't see how this is going to top up the ultra 120+ especially when it has even less heat pipes.
    That back side heat pipe thing sounds VERY interesting tho.
    I hope they sell it seperately so i can put it along with an ultra 120+ or something.
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
  21. #21
    Mar 2005
    Rotterdam
    in terms of fans I personally think you just can't beat SilenX all the way up to 120mm
    2x This one would be PERFECT for example:
    90CFM @ 18dBA
    http://www.silenx.com/ixtremaprofans.asp?sku=ixp-76-18
  22. #22
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Oooo...indeed, very eager to see how this works and what impact it makes.
  23. #23
    May 2004
    ILLinois
    Quote Originally Posted by Dimitriman
    90CFM @ 18dBA
    Silenx don't bring that stuff. These fans are known for being underated in terms of noise. As goes for air movement not much different than any other high end fans.
  24. #24
    Xtreme Mentor
    Aug 2006
    HD0
    this is what happens when you bread a sonic tower and a Ultra-120
  25. #25
    I am Xtreme
    Dec 2002
    wow what a monster
