Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 108
Thread: [MemoryReaction] CellShock 2x1GB PC2-8000C4
  1. #76
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by marauder16 View Post
    damn, that's too low mine are getting 2.3V maximum now, I'll take my chances here.
    what about those 2GB sticks, what's their case, for Micron ICs?
    EDIT: what about those highly binned sticks that are rated to run at 2.35V like Corsair or OCZ, those are D9?
    Yes, the high end FleXLC and Dominator sticks from OCZ and Corsair use D9. Just because they rate them to 2.35-2.4v, does not mean they are any more tolerant to those voltages than the rest of the D9 sticks out there, they just mean that they are willing to warranty it for the few that buy them.
    Formerly XIP, now just P.
  2. #77
    Jun 2006
    Croatia, Europe
    that is a good point, just another part of my question:
    what about those 2GB sticks, what's their max V, for Micron ICs?
    thnx for your help
    DFI ICFX3200 07/30 w/ MCW30
    E6600 L632A407 w/ EK Supreme
    Powercolor HD3870 w/ MCW60
    OCZ Reaper 2x2GB CAS4
    WD Caviar Black 1TB
    Silverstone Strider 750W
    MM U2-UFO Extended CYO
    CPU & NB loop = PA120.3, DDC 18W w/ Petra's top, 7/16''
    VGA loop = PA120.2, DDC 18W w/ Petra's top, 7/16''
    10 fans on 7V, PX-750A, all on SM 930BF
    " Having a DFI board is like having a hot girlfriend thats a total b1tch" ...
  3. #78
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    thnx for your help
    I'd say about the same, but remember with the 2GB sticks, heat will become more of an issue than it is with 1GB sticks, so you'll want to pay more attention to keeping them cool.
  4. #79
    Jun 2006
    Croatia, Europe
    Quote Originally Posted by EnJoY View Post
    aha, I have the OCZ mem cooler over them, and enough flow through the case...
    thnx again for your help
    WD Caviar Black 1TB
  5. #80
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Speaking of voltages, i had a pair of Supertalent D9's @ 2.4v for 8 months 24/7 without a single prob nor a degrade in achieved oc's.
    It depends on how long u want to keep them.
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
  6. #81
    Jun 2006
    Croatia, Europe
    Quote Originally Posted by JoeBar View Post
    guess it depends on the luck of the draw, this is the second Cellshock kit I have, and it's very V sensitive...
    WD Caviar Black 1TB
  7. #82
    Nov 2006
    Cruz Alta - CBA - Argentina
    Sorry for born again this thread, where can i buy a pair of this ram?
    iMac 24''
    BNDMOD @
    Cruz Alta (Cba.) Argentina
  8. #83
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by BND|MOD View Post
    www.tankguys.com
  9. #84
    Nov 2006
    Thanks bro, and what do you think? it's a good way to spend in ram ddr2?
    iMac 24''
    BNDMOD @
  10. #85
    Xtreme X.I.P.
    Nov 2002
    Shipai
    your already at 1150 according to your sig.
    cas5 wise the 8000 wont give you a boost, but they clock well with cas4.
    the perf gain will be small tho... or do you want to add another 2gb to your set to upgrade to 4gb?
  11. #86
    Jul 2007
    UK
    Thought I give my 2 cents...
    MemTest 3.8 stable after 100%
    As you can see a lower CL of 4 does not necessarily provide better performance.
    The crucial memory timing is tRD or Performance Level as it appears on the ASUS motherboards. Get it below 8 and you'll exceed 10GB/s.
    I'm still running the E8400 at stock speed. I'll post results at 3.5GHz and (hopefully) at 4GHz.
    DESKTOP
    | ASUS P5Q-E (Bios 2101) | E8400 (E0) | Cell Shock PC2-8000 2GB | ATI 4870 | Raptor 150 | Enermax Galaxy DXX 1KW | HSPC Tech Station |
  12. #87
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    i didnt even know there was a thread for this kit of ram.
    well im on my third set of these and this is the best kit yet.
    ddr1200 5-5-4-12-30 pl8 w/ 2.14 bios 2.10 load
    _________________________________________________
    ............................ImAcOmPuTeRsPoNgE............................
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  13. #88
    Jul 2007
    UK
    Nice!
    And at a low voltage too. I'll try your settings and post back.
    DESKTOP
  14. #89
    Jul 2007
    UK
    Here is what I had before your settings:
    (HyperPi:32M stable, 2.18v)
    As you can see, my Write and Copy values are actually higher than yours but your Read is way higher.
    However, I suspect that this is due to the higher CPU frequency; tRAS doesn't affect performance.
    DESKTOP
  15. #90
    Jul 2007
    UK
    As I suspected...
    DESKTOP
  16. #91
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    i tried your settings of 5-5-5-15-25 and got this.
    are you using XP,cause im on vista.i know when on vista
    you get lower copy scores w/32bit than 64bit.and
    if memory serves me correctly XP gets better scores than vista.
    and heres 8x500 ddr1200 5-5-5-15-25 pl8
    8x500 ddr1200 5-5-4-10-25 pl8
    8x500 ddr1200 5-5-5-15-42 pl8
    8.5x530 ddr1272 5-5-5-15-42 pl8
    8.5x530 ddr1272 5-5-5-15-25 pl8
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  17. #92
    Jul 2007
    UK
    Yes, I am on XP. Is that why you're getting a better READ score at the same frequency?
    I see you hit a new high with the extra low tRFC, well done!
    I also see 8x500 ddr1200 5-5-4-10-25 pl8 settings allow you to raise your copy score. Nice, I'll implement that as well.
    Is that E8400 E0 and is it stable at 1.216?
    How much vDimm to get the RAM at 636?
    DESKTOP
  18. #93
    Jul 2007
    UK
    By the way, have you tried these tRD recommendations?
    DESKTOP
  19. #94
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    Faiakes,thanks for tRD recommendations article.
    vdimm was at 2.18v
    yes this is a great cpu,i can run it at 1.18v for9x445@4GHz .its vid is 1.237,thats what i had it at for that 8x500 run.
    and it will do 4123 at stock vcore 1.237 bios/1.21 load
    and 8x500@4000 w 1.20v ddr1200 w/2.10v
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  20. #95
    Jul 2007
    UK
    Fantastic numbers! It is an awesome CPU indeed
    I will try your voltage specs, too.
    In the mean time, I figured out that if I switch to the 266 strap I can get higher clock options for the Cellshock....
    I will try to tighten things up later. The RAM should require less than 2.3v.
    First I want to see how high I can push it within 2.3v or below. What is your experience?
    DESKTOP
  21. #96
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    nice one.my last kit i needed 2.28v-2.30v for 1300.with this new kit i can do ddr1300 with 2.20v
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  22. #97
    Feb 2008
    Russia
    Good job guys
    I have ~ the same READ, near 10400
    Intel Q9650 @500x9MHz/1,3V
    Asus Maximus II Formula @Performance Level=7
    OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
    OCZ SSD Vertex 3 120Gb
    Seagate RAID0 2x ST1000DM003
    XFX HD7970 3GB @1111MHz
    Thermaltake Xaser VI BWS
    Seasonic Platinum SS-1000XP
    M-Audio Audiophile 192
    LG W2486L
    Liquid Cooling System :
    ThermoChill PA120.3 + Coolgate 4x120
    Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
    Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
    Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
    3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
    Apple MacBook Pro 17` Early 2011:
    CPU: Sandy Bridge Intel Core i7 2720QM
    RAM: Crucial 2x4GB DDR3 1333
    SSD: Samsung 840 Pro 256 GB SSD
    HDD: ADATA Nobility NH13 1GB White
    OS: Mac OS X Mavericks
  23. #98
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    heres an example of the difference between 32bit vista and 64bit vista.
    first is 32 bit, notice the copy score
    and 64 bit
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
  24. #99
    Jul 2007
    UK
    Welcome to the +10GB/s club WaterFlex
    Still testing this brilliant Cellshock. I'm tempted to buy another 2GB (for £50!).
    Don't know if i'd see any benefit though (for gaming).
    radaja man, I'll test for lowest cCore first and then see how much I can stretch the CellShock.
    Vista is simply appauling. I hope you didn't pay for it. Myself I'll go straight to Win7 after I read a few good reviews, once it's out.
    DESKTOP
  25. #100
    Jul 2007
    UK
    Can confirm that my Cellshock too, will only go as low as v2.14 at 600 MHz (HyperPi@32M stable).
    Which is not bad, not bad at all
    DESKTOP
