Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: Is anodized aluminum that bad when mixed with copper?
    Nov 2006
    I've read countless threads about not mixing metals, but what I really want to find out is if anyone has had an anodized aluminum/copper loop using proper corrosive resistant coolant where it ended up corroded? What about radiators as well, such as 120.3s that use brass tubing? Should I be worried if using something like Fluid XP when mixing metals or?
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    What? Fluid XP??????
    Lenovo Thinkpad X220 - Core i5 2410m, 4gb
    waiting on 28nm video cards...
    Xtreme Cruncher
    Nov 2006
    'burb of Cleveland, Ohio
    Brass and copper are fine together.
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    Brass and Copper are side by side effectively in the galvanic series - corrosion won't occur between them.
    Aluminium however is further apart in the galvanic series, so corrosion will occur between Alu & Brass, or Alu & Copper, or Alu vs Brass&Copper.
    Anodized aluminium is fine to use in a loop if you can GUARANTEE that the quality of anodizing is perfect. The slightest scratch that goes thru the anodized layer, exposing bare aluminium underneath, will result in corrosion taking place very quickly. FluidXP etc will slow down the problem, but if you don't change the FluidXP frequently enough then corrosion will still take place. Same applies to distilled water and anti-corrosive additive.
    As you can't guarantee the quality of the anodizing in the hardware within our scene, it's just safer to steer clear of aluminium altogether.
    Nov 2006
    Quote Originally Posted by Marci
    Last two posts, very informative. Thanks for the info!!
    E6700 | eVGA 680i MB | 4GB OCZ Spec Ops DDR2-800 | Raptor 74GB + 150GB | eVGA 8800 GTX SLI | TJ07 | OCZ 1000w | HP LP3065 30" LCD
    D-tek Fuzion | DD 8800 GTX GPU blocks | BIX GTX 480 & 240 Rad | 2 x Swiftech MCP655 Pump | 2 x EK-Res-200...all in one pimped out TJ07 case!
    Project thread - http://www.xtremesystems.org/forums/...d.php?t=136408
    Xtreme Mentor
    Sep 2004
    my pants
    Quote Originally Posted by masaville
    What you should be worries about is using FluidXP, that stuff is utter crap and people here had nothing but problems with it. You just cant beat good clean water when it comes to moving heat. With a few drops of biocide to keep things sterile and maybe a few drops of dye if you like color.
    French Duron Poof
    Every time you lap a swiftech block a kitten dies
    "Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
    HEAT
    Nov 2006
    Quote Originally Posted by epion2985
    Is it really that bad? I have mixed metals in the loop....I will need some kind of anti-corrosive fluid. Any other recommendations?
    Nov 2006
    Quote Originally Posted by mcoffey
    Get ready for 30-35 bucks a jug then if you use XP+, or whateverthe lastest version that's supposed to have addressed some of the issues people have been having. You can get good anti corrosion additives for a lot less than what they are charging for XP+
    I use Pentosin, and it has good anti corrosion properties. If you use this, and change fluid often as I suggested above, you most likey as safe as you'll ever be IMO. With XP, you'll still need to change often, and it's price is silly IMO.
    andyc
    Is Zerex or Pentosin available in the US or Canada? Seems to be heavily used by Europeans, but I don't know if we have it in Canada. I know you can get it from Petra's, but it's out of stock and I was hoping to pick it up sooner.
    Jan 2007
    Are you sure? It sure looks like it is in stock at Petras:
    http://www.petrastechshop.com/peg11coadb4o.html
    http://www.petrastechshop.com/peg12coaduvr.html
    http://www.petrastechshop.com/loliredcoad.html (not Pentosin but basically the same stuff)
    Aug 2006
    Its also available at your neighborhood Audi dealer (in blue), BMW dealer (in blue), VW dealer (in red/pink) and Mercedes dealer (in orange). Its named differently for the various auto brands, and the chemical compositions may be a tiny bit different, but its all Pentosin.
    Valvoline Zerex Super Racing Coolant is available at almost all Napa auto parts stores, and I'm sure also at Autozone and Pep Boys. Make sure its the Super Racing Zerex (pink) and not the regular Zerex (green).
    Aug 2006
    And stay away from Prestone and PEAK
    If you are adventurous, you can go down to your local Ferrari dealership and ask for some of their proprietary clear antifreeze. Tell them your Enzo needs a flush but you only need like 50 ml rofl You may have to give up your left hand though lol
    Aug 2006
    And if you use Zerex, *do not* follow the instruction of a 5% mix, aka 5/95. 5% concentration is too strong for Zerex and you run the danger of crystallization and potential clogging a more restrictive block like the Storm or AquaExtreme.
    I personally have had success with using a 1% to 2% concentration, but it may upset you guys that look for a more "bling" look I have no regard for appearances.
    Nov 2006
    Quote Originally Posted by IanY
    LOL good one. Made me laugh.
    I just picked up a gallon of it at the local Audi dealer....G11. Only one fellow knew it by the name of Pentosin, but nobody else did. When I said G12 and G11 they caught on. Now I have enough to last me....well.....forever lol.
    Btw, if I'm mixing metals - copper, anondized aluminum, and brass 5% should be fine right? Or do I even need 5% with distilled water?
    Jan 2007
    San Jose, CA
    I believe G11 doesn't have anti corrosion from what I've researched. It's G12 that does. Zerex at 2-3% or G12 is what you want for mixed metals.
    Mar 2005
    Cologne, Germany
    Quote Originally Posted by ramenchef
    You might find this link helpful. G11 is HOAT, G12 (+) is OAT.
    Xtreme Mentor
    Sep 2004
    my pants
    Not necessarily, you can try to wing it and siphon some out of someones ferrari.
    On second hand you might not even have to. Someone I know was at the track on open day a while back and they had a pair of Enzo's there, and boy, they were an embarasement, both leaking coolant and oil everywhere, it was pitiful.
    French Duron Poof
    HEAT
    Nov 2006
    Nice link,
    I see what "OAT" is as described, but not what "HOAT" is. Am I missing something, very intersting none the less.
    thanks,
    andyc
    From what I've just read in automative threads, G12 is superior to 11 in thermal heat transfer, anti-corrosion, etc. and was designed for aluminum engines. So, based on the above you could technically use G11 or G12, but with G12 you won't run into any issues with silicates (maybe not in G11 either).
    So....should I keep this G11 I have for my copper/anod. aluminum loop or run back and get some G12???
    Unlike the previous coolant, this newly developed product permits a
    cooling system fill that lasts the service life of the engine and
    was designed with all-aluminum engines in mind.
    Advantages over previous coolant:
    Improved corrosion protection
    Improve thermal stability
    Improved heat transfer/control
    Improved hard water tolerance
    Improved environmental protection
    CAUTION!G 012 A8D A1 must NEVER be mixed with any other coolant.
    Engine damage will result !
    Don't mix G11 and G12 heh.
    Here's a real interesting thread about G11 and G12.
    http://www.gti-vr6.net/wiki/index.ph...ine_coolant%3F
    I especially like the part about lifetime coolant with a 2 yr shelf life. lol
    From the sounds of it, both of them are just as good.
  18. #18
    Unoriginal Macho Energy
    Dec 2002
    From Petra's... is non-foaming
    This is , I can foam that stuff like mad.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
  19. #19
    Jan 2007
    San Jose, CA
    Here is one of the things I read:
    g11 was designed to prevent corrosion in aluminum blocks and G12 was designed to prevent corrosion in alloy blocks.
    By blocks, they are referring to engine blocks.
    From that I concluded, probably mistakenly after reading this thread, that G11 wasn't good for mixed metal loops and that G12 should be used instead.
  20. #20
    Nov 2006
    Think I should be okay - guess we'll find out. Heh.
  21. #21
    Nov 2006
    I'm thinking fluid being emulsified by air when first filing the loop is a little different than foaming. If it wasn't anti foaming, than foam would be seeping out of my fill line now.
    if you want to see the difference, just drop 3-4 drops of dish washing liquid in a test loop after the airs bleed out. Then you can see what true foaming is.
    At least that's my thoughts,
    andyc
    Well, the G11/distilled mix is running in a single loop now on a BIX480, cooling 2 x 8800 GTXs and a 6700. There was some initial foam when I bled the loop, but that has since subsided. It was minor.
    As for temps, they seem slightly higher at idle than the Zalman G200/Fluid XP, but it's so marginal at this point and also too early to tell. Gotta put a load on it and run some tests and see what happens.
    It was super easy to bleed the 480 rad with the res mounted above it. Took a whole 2 mins if that.
  22. #22
    Nov 2006
    good to hear. what ratio did you do your mix in?
    Gl luck on the build,
    andyc
    5%, I believe that's what you stated you're using? I read elsewhere that it's plenty. Guess we'll see.
    Temps under load seem to be just about the same....GPU is up maybe 2 degrees on avg compared to the g200/distilled and fluid xp I had in there before, but that might not be the fluid. It could be anything as I remounted the CPU, repasted, etc.
    Do I need any PT nuke in there or similar?
    I'll be posting lots of pics soon.
  23. #23
    Jan 2007
    San Jose, CA
    Correct me if I'm wrong, but G11 should be at a 10% ratio according to Petra's site. I could be wrong though.
  24. #24
    May 2005
    Baltimore
    Though I'd like to point out that from personal experience, mixing is okay:
    o I've used a Koolance EXOS AL with an MCW5002 and DD Maze4gpu for about two years straight. No corrosion whatsoever occurred.
    o The EXOS uses an Al radiator
    o The MCW5002 features a Cu base and an anodized Al housing
    o Maze4gpu is part Cu and part acetal
    I used water and plenty of Redline Waterwetter.
  25. #25
    Xtreme Mentor
    Sep 2004
    my pants
    Quote Originally Posted by L33T
    mixing is okay
    Not that simple. Weather its ok depends on certain criterion. There are three conditions that must exist for galvanic corrosion to occur. First there must be two electrochemically dissimilar metals present. Second, there must be an electrically conductive path between the two metals. And third, there must be a conductive path for the metal ions to move from the more anodic metal to the more cathodic metal.
    French Duron Poof
    HEAT
