I reached 3.6ghz but it isn't stable.
Did you guys use pencil on this mod?
GA965P DS3 / E4300 @ 3.6ghz / Thermalright Ultra 120 + Vantec 120mm / 1gb ddr667 / 7600GT
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
mod worked for me on rev1 c1 ds3. used copper ink from rear window defrost repair kit
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
Unfortunately I don't have that ds3 anymore, but yeah, I don't think you can reduce resistance to 0 with a pencil. I didn't have any noticable issues after the mod, and indeed vdroop was gone
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
Source:
http://forums.vr-zone.com/showthread.php?t=83208
Are we sure about the mod I posted above and the locations? This one is completely different. So I highlighted in 2 other colors possible locations. I tried the first (yellow one) with no change in droop at all, which tells me that isnt the right location. Or is it possible you are supposed to pencil across the (green)?
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
anyone?
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
I got the silver pen. www.bondloc.com Just that my Rev 1 DS3 rig is over in another house crunching away. Well its the one that has the biggest droop. I'll try it tomorrow. I MAY try it out on my main rig DS3 tonight here. But that'll be a lot of hassle. Would prefer to try it on my caseless cruncher.
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
Finished. No change. Covered the green resister in silver conductive paint. Still droops.
The original mod was the yellow one
Check the pics back on the top of this page.
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
I'm gonna try the mod on my Rev 1 C1 S3 in a little bit. I didn't realize how horrible the vdrop is. Setting 1.425V = 1.344V idle 1.325V load. Also have the 1.6V bug, but it usually bugs out when setting 1.56 or higher (multimeter reads less than 1.46V, a full .1V vdrop.)
I can confirm that the vMCH and vDIMM mods work, 10K VR works fine. Can bring it up higher than 3V with only a 10K VR but have only tried up to 2.82V. Did 501mhz Cas 3 with 2.82 and 1.68V on the MCH. Don't put more than 1.74V on the northbridge or it won't post, it has OVP at 1.75V.
E6400 L624A768 @ 3600mhz 1.48V
Biostar TP35D2-A7
2x1GB Micron D9JKH, 2x1GB OCZ Gold DDR2-1100
1x250GB WD SATAII 2x120GB Maxtor IDE 1x200GB
EVGA 8800GTS 512MB stock 799/1998/2075
MCW350, Apogee, 120.1 Swiftech Rad
Antec Smartpower 500W
BenQ DVDrw
Logitech z-5300e
Where do you guys measure the Vcore from on the board? You have any pictures showing where?
Cheers, Cool_Dude.
<<< fear.teh.squirrel
any of the copper coil backs around the cpu area will show you vcore and droop.
the pwm units will also. 1 leg will show way high voltage which is simply the input voltage of the PWM the other leg will show real vcore.
dont be surprised at all if you see a much different voltage than what the bios shows.
"These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
Welcome to the Roughnecks"
"Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
Heat Ebay Feedback
ON the Rev3.3, the Vdropp is hardly anything anyway.
Lestat, could you confirm what I've done in the picture?
BTW, mines the first revision.... and carey8 how did you find this out?
Cheers, Cool_Dude.
Here is a working Vdroop and consequently Vdrop mod for the GA965P DS3/S3 V3.3 motherboard.
Before this mod for me on my DS3:
1.5V in bios
1.47 Idle Everest
1.42 Load Everest
After mod
1.5V Bios
1.49 Idle Everest
1.49 Load Everest
Thanks for the layout picture RejZoR.
EDIT:
Another Picture from a different angle
Gigabyte P35-DS4 rev 2.1 | Q6600 G0 (L737A679) @ 3.6Ghz | Scythe Mudgen
OCZ PC8500 4x2GB | Radeon 4870X2 @ 800/1000 | Antec 900| Coolermaster M1000 1KW| Terratec Dmx 6Fire
Dell 3007WFP-HC A02
