Wow O_o 565
Wow O_o 565
SPLMANN!!! What voltages are you using for the motherboard? MCH, CPU VTT, ICH?
-Collin-
I am like an alcoholic, but with motherboards.
Our AquaMark-results are very simulair. You have 501MHz FSB, I have 498MHz FSB and you get a few hundred points more.
As usual, cooling for your NB? I am getting frustrated about that I cannot run for example 6*500MHz with my Noctua on the NB... It sure seems to do it works but I only earned 15-20MHz FSB compared with stock NB-cooler. I have almost same voltages as you but atm I have 1.84vMCH, that sould be enough for 500MHz FSB though...(?)
Ok, thanks. Either something is not 100% ok with my board or I am doing something wrong.
hi guys , with new 11 bios my onboard lan dessapears at second or third POST
i't's normal?
i5 760 @ 3.80Ghz (200x19) 1.25v | Asus P7P55D-E Pro
2x EVGA 460GTX 1G | G.Skill 8G CL9 1600 @ 1600 8-8-8-24-1 1.60v
2x WD 160G Raid 0 | Hitachi 750G | WD 1TB
Antec Quattro 850w | CNPS 10X Performa
Antec Twelve Hundred Case
I am using the official 11 bios but in cpuz it shows it as version 1.x(bios:10)
What bios are you using?
Guys, has anyone here had an issue with running a PCI video card in this board? I get a "2d" hang on boot and it just sits there with a black screen.
CNC Waterblock Builder
Q9550, Rev. E0
Gigabyte EP45-UD3P
4GB G.Skill DDR2-1000
eVga GTX 260 Core 216 Superclocked
3 Western Digital 80GB, RAID 0; 500GB Seagate 7200.11
Silverstone OP750 PSU
Extreme Watercooling
Swiftech MCR-QP 360
D-Tek Fuzion v1
Laing D5
D-Tek Fuzion GFX rev. 2
BIOSTAR TPOWER I45 UNOFFICIAL THREAD
BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
ABIT IP35 PRO HEATPIPE MOD
ABIT IP35 PRO BIOS FLASHING PROCEDURE
IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
I use the latest(?) beta-bios. I think I read somewhere that they are the same bios so I did not upgrade.
I just did a test with dryice on the NB. I gained another 5-7MHz FSB, not more. Atm moment I think my CPU need LN2 to be able to handle higher FSB. I know it can cause I have had it way over 500MHz with LN2 on another board.
I ran out of ice so I could not try the Kentsfield this time.
blossa can you post a iso bios of this beta bios?
you have porblems with onboard lan?
had a problem with the onboard lan too after a failed Overc tried to fix it by doing few things and nothing so i put a Lan card , not sure if the onboard is working now , its been awhile
[/SIZE][/COLOR]
man i hope abit adds more ram settings in the next bios release cant run 3x1GB 100% stable now = (
Q6600 | P35 DQ6 | 4x1GB Ballistix8500 | 8800GT 512 | PC P & P 750w | WC Mcp655, D-tek Fuzion, Maze 4, Bip3 |
E6600 | Abit AB9 QuadGT | 3x1GB D9GMH | 7900GTO | Silverstone Zeus 850W | Aircooled |
E2160 | Giga 965 Ds3 | 3x1GB D9HNL | 7600GS Silent |Seasonic s12 600w | Aircooled |
if you can't run 3 sticks maybe take it down to 2 sticks to see if that helps....if it does not then the overclock is probably excessive or you do not have enough voltage being suppled to support the overclock.
2 sticks have been running fine for a few weeks but found a 1024MB stick of crucial ram with D9GMH for 90$ = ) but cant get them stable together without pushing alot of volts or running real loose timings around 2.35v but with some more settings im sure they would do better.
Might try flashing the crucial stick with teamgroup spd.
I have never used LAN on that board.
This is where I got the BIOS from:
http://forum.abit-usa.com/showpost.p...0&postcount=89
I tried some overclocking with uguru in windows under one of the user settings so my default bios wouldn't get screwed up if the oc failed. what I found is that at 470fsb I can boot into windows and am orthos stable 8hrs, however if I jump to 477fsb everything is ok until I run memtest. It fails immediately. I have my memory at 4-4-4-12 2.3v in bios. I believe my memory is keeping me from going on. I thought the g.skill 6400 BHZ's were micron d9's? thought they could do ddr2 1000 no prob?
it stands to reason if you stress the memory controller hub with higher memory speed, you will most likely need higher vmch....NOW...how much all depends on your board, memory and cpu.
