XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > PhotoCHOP
Reply
Old 05-20-2003, 01:33 AM   #1
CCW
Guest
Posts: n/a
What do you think?
This is my first outing in photoshop to create a new signature, what do you think?
Thanks,
Craig
EDIT- How do I make text bigger, Ive been selecting the text then changing the size in tyhere but when I click OK it stays the same size, Im using photshop 5 btw
EDIT 2 - im trying to make the "CCW - XtremeSystems.Org" bit bigger
Old 05-20-2003, 06:49 AM   #2
stoopid
Guest
Posts: n/a
The compression's a bit too much, otherwise looks good.
Old 05-20-2003, 07:15 AM   #3
JBELL
Guest
Posts: n/a
where's the mouse cord?
Old 05-20-2003, 07:45 AM   #4
gobbo
gobbo's Avatar
Looking good, but like Pinky said you got compression on too high hence the pixelation on it.
__________________
"There is only one thing better than having a linebacker in your office, and thats having two linebackers in your office"
12.7Ghz folding for XtremeSystems
gobbo is offline   Reply With Quote
Old 05-20-2003, 10:06 AM   #5
CCW
Guest
Posts: n/a
Cheers for replys,
i wanted to make it smaller cos i didnt want to upload a big file to XS (bandwidth)
Old 05-20-2003, 12:16 PM   #6
Peckers
Peckers's Avatar
Send a message via ICQ to Peckers
Looks good CCW
The edges on nVIDIA img could use some improvement though.
Peckers is offline   Reply With Quote
Old 05-20-2003, 03:26 PM   #7
Peckers
Peckers's Avatar
You got me inspired CCW
first draft for my new sig:
Old 05-20-2003, 09:22 PM   #8
CCW
Guest
Posts: n/a
thats looks good, how did you round the edges please thats what i wanted to do! its my first time in photoshop and ive never reads anything bout it, just installedit and started to play around
Craig
Old 05-21-2003, 05:36 AM   #9
stoopid
Guest
Posts: n/a
Craig
Transparent gif I'd imagine allows for the rounded edges and the background color through (and the slight shadow effect, nice job ), rounded edges are sub-settings (somewhere) in the box creation tool.
Old 05-21-2003, 07:31 AM   #10
Twisted
Guest
Posts: n/a
i like it
Old 05-21-2003, 10:15 AM   #11
CCW
Guest
Posts: n/a
Originally posted by Twisted
i like it
thats good enough for me! nah, i dont like it but as ive never read books on photoshop, just opened it and started clicking im pleased with it, just ogtta round edges, work out how to make text bigger and not compress it as much once ive done al that
how do you make text bigger please anyone?
Craig
Old 05-21-2003, 10:21 AM   #12
wdd1040
wdd1040's Avatar
Send a message via AIM to wdd1040
When you select the text box, you must highlight the text, then type in the size you want and it will change. If you don't select the text and just click in the text box, it will do like what you said and not do anything.
__________________
<br>
wdd1040 is offline   Reply With Quote
Old 05-21-2003, 10:53 AM   #13
CCW
Guest
Posts: n/a
Cheers, will give it a try
Old 05-21-2003, 11:01 AM   #14
CCW
Guest
Posts: n/a
This better, still cant curve edges though
Old 05-21-2003, 11:16 AM   #15
stoopid
Guest
Posts: n/a
If I were home I'd jump into photochop and help, but alas, I'm in the uncool job place thing.
Old 05-21-2003, 11:41 AM   #16
Peckers
Peckers's Avatar
CCW: If you upload the .psd I'll see what I can do
Edit: I don't know how PS5 looks but from PS7:
http://130.236.239.34/skit/ccw_stuff.jpg
2: here you have some different styles to select.
3: Opens ImageReady where you can play around with more styles and stuff to make smooth edges etc..
Old 05-21-2003, 11:02 PM   #17
CCW
Guest
Posts: n/a
Thanks Iluvatar, mine unforutetly is substantially different
*strangles self with mouse cord*
heres what mine looks like:
Old 05-22-2003, 01:33 PM   #18
Peckers
Peckers's Avatar
unfortunately I'm not familiar with PS5 at all , but here you have a link with tutorials and stuff:
http://www.planetphotoshop.com/
Old 05-22-2003, 11:35 PM   #19
CCW
Guest
Posts: n/a
Cheers
Old 05-23-2003, 03:12 AM   #20
CCW
Guest
Posts: n/a
couldnt find a guide on what i was looking for so i will stick with it as it is for now, here is the final version
Old 05-23-2003, 10:37 AM   #21
ctgilles
ctgilles's Avatar
Send a message via ICQ to ctgilles Send a message via MSN to ctgilles
lookin' good
__________________
AMD Phenom II X4 955BE @ 3.6 24/7 - 2x Sapphire HD5850 CF @ 775/1050
Intel C2D E6400 @ 2.88
Intel C2Q Q6600 @ 3.0
ctgilles is offline   Reply With Quote
Old 05-23-2003, 11:02 AM   #22
CCW
Guest
Posts: n/a
thanks
Old 05-23-2003, 11:15 AM   #23
Peckers
Peckers's Avatar
Yeah, not bad at all, good job
Old 05-23-2003, 11:32 AM   #24
CCW
Guest
Posts: n/a
look carefully at the left bottom handside of the nf2 logo though i just noticed that
Old 05-26-2003, 03:56 AM   #25
antipop
Xtremely slow runner
antipop's Avatar
That's a good job for a starter, i've tried to do some photoshop in the past but it didn't looked great exept for one pic, i'll post some day
__________________
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Av by Frisch This is not a Lime tree
antipop is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
