XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 01-31-2007, 04:44 PM   #51
Pyr0
Pyr0's Avatar
Send a message via Skype™ to Pyr0
it's not a problem, the 680 boards just "tweak" the voltages of the 8800 cards for higher overclocks
naughtyboy, have you tested this yourself?
__________________
i920 (3838A505) @ 3.8GHz (181x21)
Gigabyte EX58-UD5 (Extreme F9p BIOS)
3x2GB Cosair Dominator PC3-12800 @ 1810MHz
Asus EAH4870X2+TOP BIOS & Dell 3007WFP-HC
Auzentech Prelude
OCZ Vertex's, Velociraptor & Sammy F1's
Corsair HX850W
Windows 7 Ultimate x64 RTM
Pyr0 is online now   Reply With Quote
Old 02-01-2007, 07:39 AM   #52
mit78
mit78's Avatar
hi
its 680i sli 100%,but asus fake the info,
Do you perfectly right,driver for 650i not function in this mobo,driver for 680i
still function perfectly.its a big fake,maybe in the future, a update of bios solve the problem,and show in cpuz "680i sli".i hope.
mit78 is offline   Reply With Quote
Old 02-01-2007, 07:50 AM   #53
xs64
xs64's Avatar
Can anyone post the pics how to meaure Vcore , Vdimm ..... ect in this mobo ?
I hear Asus has the terrible Vdroop
xs64 is offline   Reply With Quote
Old 02-03-2007, 01:41 PM   #54
roller11
The evga 680i boards all have a severe design bug...the cursor gets erratic
whenever a heavy load is put on the CPU, such as prime95, FEAR,
etc. For this reason, I want to get a asus but only if it does not have this
bug. Could someone please test for this as follows: run the Intel
Thermal Analysis Tool and put at least a 80% workload on both cores
(assuming you have a dual core, I tested with a E6600).
Then, move your mouse cursor around see if it fails to track and gets
fanthom mouse button clicks. This is a random problem, so
you might need to do this a minute or two to test. Also, upping
the CPU core voltage intensifies the prob, but
in all cases, a load must be on the CPU to cause the screwup.
Superpi and Prime95 running simulaneously will also trigger the problem.
Can someone run this test and report the results?
This prob is 100% repeatable, and happens on all evga 680i boards.
Finally, does the Asus 650i/680i mobos have 'smartfan' implemented
in the BIOS?
roller11 is offline   Reply With Quote
Old 02-03-2007, 02:33 PM   #55
xs64
xs64's Avatar
I installed Intel Thermal Analysis Tool but could not run it. It showed an Error !!!!
Old 02-03-2007, 03:22 PM   #56
roller11
Try running prime95 and superpi together. Or, just prime95 alone, but you'll
need to crank up your CPU core voltage to at least 1.45. Move your mouse around for awhile, you'll see what I mean. 100% repeatable.
Old 02-03-2007, 04:01 PM   #57
xoqolatl
Thrusters on full!
xoqolatl's Avatar
Send a message via MSN to xoqolatl
On non plus version there's no bug, and from what I know from a friend that has Plus there's no bug either.
__________________
Originally Posted by miahallen View Post
FurMark is a waste of time.....it's not ranked on HWBot
W3520 on Rampage II Gene | hardmounted TRUE + 2x 120mm push-pull | 3x 2gig of HCF0
Zombie GTX280 | look mom, i has no IHS | Thermalright HR-03 GT
Lian-Li PC-A70B | Brushed aluminium tank
MOA 2009 Poland #2
Test bench: Clarkdale, several AMD Confidentials
xoqolatl is offline   Reply With Quote
Old 02-03-2007, 04:04 PM   #58
roller11
You need to personally run the experiment.
Old 02-03-2007, 04:19 PM   #59
xoqolatl
Thrusters on full!
xoqolatl's Avatar
That friend of mine is an overclocker and he runs WCG, Orthos, SuperPi, Intel Thermal Analysis Tool every day and I am sure taht he would have spotted the bug if it was present. It's not like he bought the board pute E6600 into it and stay happily at stock volts and clocks, and using only Internet Explorer and M$ Office. He has put this CPU and motherdoabrd to evere possible sterss, trust me.
__________________
MOA 2009 Poland #2
Old 02-03-2007, 08:32 PM   #60
roller11
No. The test must be run as outlined in my post.
If you are so sure there's no bug, then why are you
so afraid to perform this simple one minute test?
Old 02-04-2007, 09:11 AM   #61
mit78
mit78's Avatar
hi
advice me,how overclok at 3,6ghz with this mobo.thx
Old 02-05-2007, 09:39 AM   #62
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Can anyone with this board peel off the sticker right above the blue PCI-E slot?
You might be in for a little surprise :
Here's some more nice info i found:
The Asus P5N32-E SLI PLUS is a revised version of the P5N32-E SLI and has been noted to solve some issues found within the P5N32-E SLI that some users are experiencing.
Changes:
* Changed Northbridge and Southbridge Chipsets (C55XE and MCP55XE to C55 and MCP55)
* Upgraded and updated capacitors (Tantalum+Electrolytic+Conductive Polymer capacitors to Tantalu+Conductive Polymer capacitors)
* Updated BIOS
* Added accessories to the motherboard bundle
Benefits of Changes:
* Tighter control and manipulation of voltages with lower vdroop
* Fixed issues in relation to chipset functions e.g. crackling onboard sound during SLI configuration use
* 3DMark06 bundled with the motherboard
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 02-05-2007, 09:55 AM   #63
zbogorgon
Slovenian OC Master
zbogorgon's Avatar
about Striker signature on PCB is kinda old news
about 3DMark06, i didn't get it with mobo
__________________
OC-Lab.si!!
zbogorgon is offline   Reply With Quote
Old 02-05-2007, 10:06 AM   #64
xoqolatl
Thrusters on full!
xoqolatl's Avatar
Cuz I dont have the board myself, I have P5N32-E nonplus. If you need it so desperately I can ask him to register and drop by this thread and perform this test you outlined.
greets
__________________
MOA 2009 Poland #2
Old 02-05-2007, 11:30 AM   #65
Fikkie
Fikkie's Avatar
I got a mail from Asus that it is my shop's fault that there wasn't a 3dmark06 included. So asus blames all shops and what so ever...
Fikkie is offline   Reply With Quote
Old 02-05-2007, 01:20 PM   #66
Desert Eagle
Desert Eagle's Avatar
Send a message via MSN to Desert Eagle
Its not! I've seen them open the major box with my mobo in it, and none of them got 3D06 inside!!
Mine is a P5N32-E SLI PLUS
Desert Eagle is offline   Reply With Quote
Old 02-05-2007, 01:23 PM   #67
xoqolatl
Thrusters on full!
xoqolatl's Avatar
AFter the false info about Plus chipset, and now this 3dmark thing, I smell growing tired of ASUS just like many P5B users did...
__________________
MOA 2009 Poland #2
Old 02-05-2007, 01:40 PM   #68
Naughtyboy
Send a message via ICQ to Naughtyboy
Guys I´ve been thinking about this 3dmark06 issiue to...and confronted my dealer about this...and he has been supsicious about this to. This is a guy I trust deeply...and if he says there wasn´t any 3dmark when they recieved the boards then I belive him. So either it´s Asus or the suppliers, somehow I don´t think Asus would do such a BS thing. It´s one thing to sell a mobo to early with bugs e.t.c ...but purly lie about the content of the package wich the mobo is bundled with, naaah sorry but I really don´t think so.
AFAIK it´s some of all the middle hands that are screwing us big time.
Now, this is just my opinion and thoughts...I have nothing to back this up with.
__________________
Originally Posted by Ugly n Grey
I was watching late night TV and this was rolling through my mind all night.....
"Why in the name of Papa Smurf would you put your d1ck in a hot apple pie?????????"
Naughtyboy is offline   Reply With Quote
Old 02-05-2007, 01:52 PM   #69
Tony
the jedi master
Tony's Avatar
in the BIOS?
I have the issue here, USB mouse cures it.
__________________
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Tony is offline   Reply With Quote
Old 02-06-2007, 07:39 AM   #70
Thomas Olivaux
Send a message via MSN to Thomas Olivaux
I still don't understand this mobo chipset.
I took a look to those mobos (removing heatsinks), sorry I've given the P5N32-E SLI to a friend :
- Striker Extreme = C55-SLIX16N-A2 + NF590-SLI-N-A2 (sold as 680i SLI)
- P5N32-E SLI PLUS = C55-SLIX8N-A2 + NF590-SLI-N-A2 (sold ?? 2x 16X)
- P5N-E SLI = NF650I-SLI-N-A2 + NF-430-N-A3 (sold as 650i SLI)
The 1st one is correct, it's a true 680i SLI (NF590-SLI-N-xx = MCP55). The 3rd one is correct too, it's a true 650i SLI (nForce 430 = MCP51). What about the second one? I asked nVidia, they told me that their were a 680i version without the additionnal third PCI-E 16X (wired 8X), is it the answer? I'm not sure.
Any input?
Tom
Thomas Olivaux is offline   Reply With Quote
Old 02-06-2007, 07:41 AM   #71
Thomas Olivaux
It looks like in the "PLUS" version, the C55-SLIX8N-xx is a 650i NB, intented to make one 16X or SLI 8+8X. They use 16X with this NB, and they use 16X from the SB.
Old 02-06-2007, 07:46 AM   #72
Thomas Olivaux
Well, nVidia just confirmed me that their were a second "lighter" version of the 680i SLI, without the third PEG port. So this explain how we can have a mobo with a NB looking like a NF650 + 680 goodies (EPP, linkboost...) and also how this mobo can be sold less expensive than the "non PLUS" version, with better caps.
The only "unknown" thing : why Asus do not write nForce 680i SLI clearly on the box and the manual?
Tom
Old 02-06-2007, 08:53 AM   #73
NiCKE^
NiCKE^'s Avatar
Send a message via ICQ to NiCKE^ Send a message via MSN to NiCKE^
You should start to use the edit button for sure.
Asus told my dealer (same as naughtys) that they replaced the non-plus due to bugs and such. He also told me that 3DMark06 was on the CD/DVD Asus includes with drivers and such, so the confusion maybe is that you think you will get a license for 3DMark06 and not just the install file for it.
__________________
Intel FTW!
Beanna
NiCKE^ is offline   Reply With Quote
Old 02-06-2007, 09:00 AM   #74
xs64
xs64's Avatar
No , i have here one P5N32E SLI Plus and dont have 3DMArk06
Old 02-06-2007, 10:09 AM   #75
Thomas Olivaux
NiCKE, the PLUS is not a replacement one, ask Asus. It's a sort of trick (or not?) with the chipset to produce a high performance nVidia for Intel board at a lower cost that what's imposed by nVidia with the 680i (please excuse my poor english).
About 3DMark06 : maybe it depends on the market? I have 3DM06 with both the P5N32-E SLI and the P5N32-E SLI PLUS.
Tom
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
