XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD > AMD Information And Support
Reply
Old 12-25-2006, 07:44 AM   #1
Wiggy McShades
Wiggy McShades's Avatar
Nf-M2 nview wont start
i just got an abit NF-M2 nView with a sempron 3000+ and im using 4 x 256mbs of corsair value select. now the problem is any time i hit the power it turns on for a few seconds and then turns off ive reset the cmos a few times and tried a different power supply. I tried the memory in another computer and it works fine so which is broken the cpu or the motherboard?
__________________
Wiggy McShades is offline   Reply With Quote
Old 01-01-2007, 12:45 AM   #2
JWilson
Refund RMA will fix the issue.
__________________
Biostar T-Power I45 Motherboard
P45AA918 BIOS
E8600 450x9 1.35V
Danger Den Water Cooled
2x1Gig Super Talent PC6400 5-5-5-15
EVGA 7800GS
WD SATA 120GB
Rosewill 750W
JWilson is offline   Reply With Quote
Old 01-01-2007, 01:30 AM   #3
NickS
I am Xtreme
NickS's Avatar
Yeah, sounds like a dead board to be honest.
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
