01-31-2007, 10:19 AM
#51
Originally Posted by couppi
After doing the mod, I'm getting 1.404v idle and 1.395v load with 1.4v selected in BIOS. Great success!
With 1.5v set in BIOS, I'm getting 1.498v idle, 1.486 load. The BIOS voltage reporting is waaay off. Asus probe tells me 1.44v idle, 1.33v load.
Hi couppi, two questions:
1. Is it possible to adjust the trimpot to get even lower drop?
2. Are you still experiencing that the drop gets even worse with higher voltage, have you tried with 1.6V?
__________________
Laptop: | HP Pavilion 1165 | Dothan 1.7ghz | 1gb Samsung PC2700 | 60GB HDD | 14" wide |
HTPC: | SS LC16M | A64 3000+ | Asus K8N-E Deluxe | 2x512mb Corsair | Radeon 9800SE | Samsung 400GB + 2x250GB + 200USB | Tagan EC 430W |
Bench:| X6800 | AW9D-MAX/P5N-E SLI | 2GB TEAM 6400 cl4 | 7900GTO SLI@EK WB| Raptor 74GB+32GB | Tagan EC 580W | Samsung SM 204B |
01-31-2007, 10:24 AM
#52
I am Xtreme
and what mod are you talking about, considering all talk of this mod has been nothing but speculation, what did you mod and please show pictures if possible.
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
01-31-2007, 02:39 PM
#53
I did the Vdroop mod. Before the mod I was getting .04~.06v drops at load. Now I only get .01v drop at load. Just connect these two points with a 1 mohm resistor. I guess you could do this mod by pencil if you penciled the resistance down to 105~110 kohms.
1. .01v drop was the best it would get. When I lowered the resistance any further, it raised both the idle and the load voltage.
2. I haven't tried that yet, but I will.
01-31-2007, 03:08 PM
#54
IT Engineer in the making
[/img]http://img145.imageshack.us/img145/1305/30fh0281848617xs1.jpg[/img]
[i]1. .01v drop was the best it would get. When I lowered the resistance any further, it raised both the idle and the load voltage. [/i[
I guess that the 1M resistor is too flaky in the lower regions (the trimmer's not linear and the low resistance range changes qickly). Try this: Connect a 500k trimmer in series with a 100k trimmer and use that. This way you get a total of 600k and 500k in 15-20 turns + 100k in the same number of turns. This increases precision dramatically. You could also just add a smaller trimmer in series to the 1M trimmer. Let's say a 200, 100 or even 50k and use that for fine tuning. You should be able to adjust it easier/finer then.
__________________
01-31-2007, 06:34 PM
#55
Thanks for being the first to test and confirm, Couppi!
My new multimeter was delivered this morning, but I still have to trek back to the electronics shop to get the right trimmer(s).
EDIT:
Ok, so the possibility of a pencil mod to fix the vdroop was mentioned, and I figured, "what the heck..."
I measured initial resistance, with the power off, of the resistor shown in the mod photo and I also got ~130k ohms.
So now I'm setting about to do the pencil mod...
I've not been able to measure the vcore directly from the motherboard because I'm not clear on how to do it. It's been 14 years since high school electronics, and even then we never got to tinker with computers. Looking at the VR-Zone page I see the mosfet leg to measure, but where should I ground out?
01-31-2007, 10:26 PM
#56
you can use any groundpoint you like on motherboard, easiest to locate is the mounting holes you use to fasten it in the chassis. Or you can use the third pin of a fan connector, where the black cable goes.
__________________
02-01-2007, 12:27 AM
#57
Thanks, Zeeke. Oh, and thanks a million Celemine for coming back to this thread and solidifying the vdroop mod for us!
My board measured different inital resistance compared to Couppi. I got half the original resistance he measured! I came in at 65k ohm. My meter is new so I tested it on another known resistance and it was correct. Soooo....
I went ahead and did a pencil mod on the resistor. Pre-mod, my board-measured vcore was 1.46 at idle, 1.40 at load. I dropped the resistance in stages, and found that 28k ohm was nearly ideal. Pre-mod, I set my bios at "1.38125v" to get those above voltages. But at 28k ohm, my idle voltage rose up to 1.49v. So, I dropped the bios setting down to "1.300000v" which gives me slightly more than 1.40v at idle and about 1.40v at load.
ORTHOS testing now, I was right at the minimum stable voltage for my clock rate before. I'm running an E4300 at 3256mhz (stable). However, pre-mod it would boot up at 3600mhz with lots of voltage, but ORTHOS would fail within seconds. Maybe it's time to try that again!
02-01-2007, 01:32 AM
#58
Redo the mod! The Droop-Mod is not there to increase idle volts.  It's just to adjust idle to load voltage. There should be no change in idle volts compared to a unmodded board.
__________________
02-03-2007, 12:45 PM
#59
Where do you measure vcore for this board? Ive tried the leg shown at vr zone with mb mounting holes for ground and I get 1.15v. I have 1.46 selected in bios and asus probe shows 1.41 at idle so 1.15 is not right. Ive tried 2 known good DMM that give correct readings for my video card and psu rails. Is there another point to measure vcore. Any help would be much appreciated.
__________________
E8400 @ 3.84Ghz 1.25v LOAD
ABIT IP35 PRO
4 GB G.SKILL F2-8000CL5D-4GBPQ
EVGA 8800 ULTRA 660/1110
PC POWER & COOLING 750 QUAD
THERMALRIGHT ULTRA 120 EXTREME
2 X SEAGATE BARRACUDA ES.2 ST3250310NS 250GB RAID 0
02-03-2007, 03:35 PM
#60
Use the fan connector (black wire) as ground. You'll get better result.
02-03-2007, 05:36 PM
#61
Thanks sbinh I tried fan connector ground but its still way off. 1.22v idle 1.17 load. I want to do the vdroop mod but I can't do it when I can't even get accurate vcore readings. Have you measured your vcore with dmm and if so what did you get?
__________________
ABIT IP35 PRO
02-05-2007, 07:24 AM
#62
Are you sure you're taking a reading for vCore and not the chipset or something else? Triple check your metering spot because nobody else has had a problem. If you're at the right spot, check your meter on a known voltage like a fresh AA battery which will read ~1.6v.
02-05-2007, 05:57 PM
#63
Im taking reading from the top leg of the mosfet shown in the vr zone guide. Ive checked meter with batteries and other known voltages and it reads exactly what it should.I don't know why I'm getting 1.22v.
__________________
ABIT IP35 PRO
02-05-2007, 06:47 PM
#64
These are what I just got .....
1st pic ... ground directly from PSU
2nd pic.. ground from motherboard ...
vcore in BIOS: 1.5375v .... speedfan: 1.47v ......
All vcore is at idle ... 400x9
When loaded, it drops down to 1.41v (in speedfan .. maybe 1.44v with DMM)
02-08-2007, 09:23 AM
#65
i did the vdroop mod now. tuned it so, that the difference between idle&load is minimal. 1.550V idle and 1.549V under orthos load or 1.443V idle and 1.442V under orthos with different voltage setting through bios.
now it's time to find new voltage settings for a stable OC with this mod. hope, i can drop the volts a bit
__________________
P35-DS3P | E4300 | 2*1GB Crucial Ballistix 5300, 2*1GB Crucial Value 4200 D9GMH | POV 8800GT | Audigy2ZS | water CPU&NB
02-11-2007, 08:39 AM
#66
After soldering a 50K for vmod......
BIOS set to 1.49375v ---
Speedfan (4.32 Beta) idle shows 1.50v ---
DMM idle shows: 1.542v ---
Speedfan (4.32 Beta) loaded shows 1.44v ---
DMM loaded shows: 1.490v ---
Edited: using wrong term .. it's should be vmod - not vdroop.
02-12-2007, 10:35 PM
#67
why did you solder a 50k for vdroop when you are supposed to use a 1M ?
__________________
02-13-2007, 01:30 PM
#68
Did the Vdroop mod today, got the drop pretty stable. But I can confirm that the idle voltage DOES rise at some point. Before Vmod idle volt were 1.58V, and load 1.54V, efter mod, idle 1.60V and load 1.60V-1.59V. Res is to low on my multimeter to adjust it any better.
Have to say that so far my system doesnt seem more stable thou ;( But I have to play around with it for a couple of hours before final judgement..
__________________
02-20-2007, 12:33 AM
#69
ok first off i have no clue what i'm doing but I did two pencil mods and now this mobo is running voltage solid as a rock. I used to have need about 1.52 to get the cpu stable at 3.3ghz now it only needs 1.42.
The first point I penciled was the point given in VR and that made the voltages i entered into the bios actually show up after i rebooted.
The second point I penciled was that point that couppi pointed out and that got rid of my vDroop completely.
I used a 4B pencil and did about 5 strokes on the 2nd point and about 30 on the first point.
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
02-22-2007, 10:14 AM
#70
Do you remember what the resistance was on the vdroop cap after the mod?
Or anyone know the resistance after the vdroop mod?
*EDIT*
ok, my vdroop cap measures 145k stock before mod. Gonna do some pencil surgery and report back...
__________________
e6600_ES 2.40@3.37 1.36v w/ vdroop mod
Asus P5N-E SLI Tuniq Tower 42 load
2gb GEIL DDR2 800@750 3-3-3-8 1T
8800GTS_320mb
02-22-2007, 05:44 PM
#71
OK .... I did play around with this board for almost 2 hrs .....
and try to vdroop using pencil (PaperMate 2 HB) ....
Decided to remove the vmod I did earlier and apply vdroop mod...
This is what I did
As you can see in my previous post, those are before vdroop (after vmod .. which is suck  )
This is what I got after vdroop:
vcore set= 1.500v
vcore in BIOS monitor= 1.47v
At IDLE
vcore in speedfan=1.47v
vcore in DMM=1.501v
At LOADED
vcore in speedfan=1.44v
vcore in DMM= 1.48v
I know, it is not the best yet (compare to what Couppi did), but I am happy with it ... Used to set vcore to 1.525v to run E6600@3.5GHz .. now, running same speed at lower vcore (1.5v) .. (which can be lower at least 1 notch)
02-25-2007, 07:51 AM
#72
Ok, big thanks to couppi for the vdroop mod.
Resistance was 145k before and 33.5k after
Here are my results:
Bios: 1.40v
Actual Idle: 1.44v
Actual Load: 1.43v
__________________
8800GTS_320mb
02-27-2007, 07:08 AM
#73
I've got a question regarding my meter readings. My vcore is incredibly stable now thanks to the mod, but I'm unsure what is my actual voltage.
With Vcore set at "1.375v" in the bios, the bios hardware monitor reports 1.39v. My meter set at "2000m" reports 1.342v, but my meter set at "20" reports 1.48v.
Testing the meter at the same settings on AA and AAA batteries doesn't show any discrepancy between the "2000m" and "20" settings. Further, all testing of the vcore was done with the same ground (fan pin header, fan set to 100%).
I also metered the Vchipset at 1.372v on "2000m" or 1.43v on "20". It's set at "1.393v" in the bios.
Vmem also couldn't meter at the "2000m" setting, but reports 2.12v at "20". It's set at "2.085v" in the bios.
Is this the result of voltage ripple? At which setting, "2000m" or "20" am I to believe the readings? Should I have spent more than $5 on a meter?
__________________
Asus P5N-E SLI (rev 1.01G / Bios 0401 / vDroop mod) -- STABLE!
E4300 (Q640A495) @ 3.3ghz (412.5x8) w/Scythe Ninja & Thermalright HR-05
2gb Super Talent DDR2/6400 @ 825 4-4-3-8 2T
Seasonic S12/430W power supply--with watts to spare.
"Evertop" nVidia 7900GS 670/1890 (volt mods & Zalman VF-900-Cu added)
Vcore 1.41 (meter) / Vdimm 2.013 / NB 1.208
02-27-2007, 10:56 AM
#74
i think you should spend a bit more on the meter and get 1 that can go down to 2
__________________
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
02-27-2007, 02:59 PM
#75
...Should I have spent more than $5 on a meter?
 :thumbsup:
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
