XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 12-03-2006, 06:53 AM   #1
Duniek
Duniek's Avatar
Send a message via MSN to Duniek
Duniek's Singe Stage's
hi
In this thread i will show my SS units
Compact SS
http://xtremesystems.org/forums/showthread.php?t=97579
Micro GPU SS
http://xtremesystems.org/forums/showthread.php?t=114665
this is my next SS (1/4HP)
I waiting for thermo
regards
__________________
NEW CNC POTS
CUSTOM WATERCOOLING STUFF P6T DLX FULLCOVER WATERBLOCK
MY 1ST ITX PC MY 2ND ITX PC
I reply for all private messages, if you dont get answer after 3 days, please send it again, sometimes I can forget to reply.
the fastest contact to me:
mail @ duniek1986@poczta.fm or MSN with the same adress
Duniek is offline   Reply With Quote
Old 12-03-2006, 08:14 AM   #2
wdrzal
I am Xtreme
wdrzal's Avatar
I looked over ever thing and the only problem that is prevalent and repeating is you need to put more effort in fabricating fan shrouds.
since a fan is round and a condenser is square or rectangular you need to fabricate a shroud so air is being pulled through the entire face area of the condenser.
A fin straightner can do wonders as they work well but you need the correct FPI (fins per inch) they sell individual fpi tools or some may have 5 or 6 fpi on one tool
Fins normally have small ridges in them to create turbulence within the condenser itself. This is good because turbulence causes the fins to reject more heat. But severely bent fins ,while causing turbulence they will have a negative effect as they will restrict or entirely block the air flow Thru that part of the condenser.
But the fan & fan shroud should be designed for no turbulence,this will allow higher air flow for the same differential pressure,Plus reduce fan noise.The shroud allow air to be pulled thru the condenser equally across the entire face. If measurement were taken the flow should be pretty even thru the entire condenser,even in the corners.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 12-08-2006, 06:00 PM   #3
Duniek
Duniek's Avatar
almost done
insulation and controller in progress
__________________
NEW CNC POTS
Old 12-08-2006, 07:15 PM   #4
m411b
Xtreme Lurker
m411b's Avatar
Looks really good! Clean and neat. GJ
m411b is offline   Reply With Quote
Old 12-08-2006, 07:26 PM   #5
jinu117
-100c Club Member
Yup... btw on the sleeve... just use electrical tape if you don't have heatsink...
My only complaint about that build
__________________
http://www.vapoli.com/Images/Forum/vapoli.jpg
Single Stage Work Logs
Originally Posted by killermiller View Post
Those ccb's will die if you look at them wrong.
heatware: jinu117
jinu117 is offline   Reply With Quote
Old 12-08-2006, 07:33 PM   #6
Asazman
Send a message via AIM to Asazman
impressive man
Asazman is offline   Reply With Quote
Old 12-18-2006, 01:51 PM   #7
Duniek
Duniek's Avatar
__________________
NEW CNC POTS
Old 12-18-2006, 06:46 PM   #8
martinjon666
martinjon666's Avatar
Looks good Duniek. What kind of temps are you getting with that and what gas are you using?
In the future you may want to space out your desuperheater a bit more to let the airflow help things out.
Lets see some loadedtemps huh
martinjon666 is offline   Reply With Quote
Old 12-20-2006, 11:03 PM   #9
JT from Russia
JT from Russia's Avatar
Send a message via ICQ to JT from Russia
In the case looks simply perfectly
JT from Russia is offline   Reply With Quote
Old 12-27-2006, 01:20 PM   #10
_HL4E_HalfLife_
_HL4E_HalfLife_'s Avatar
There's nothing wrong with his fan/condensor setup wdrzal. The fan hes using to me looks like its covering the whole condensor so theres no reason he would need a fan shroud. Some chilly1's units are the same way so they must work well.
__________________
My Rig:
Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
ATI X1950XTX 512mb DDR4
MSI 975X Platinum PowerUp Edition
2gb Kingston Hyper-X DDR2 667
Sound Blaster Audigy2
2 IDE HDD, 2 SATA HDD
LG DL16XDVD Writer,52X CDROM
OCZ 520Watt PSU 33Amp +12v
Thermaltake Xaser III case
Logitech Z560 4.1 400watt Surround Sound
3Dmark03-21112
3Dmark05-12154
3Dmark06-8054
_HL4E_HalfLife_ is offline   Reply With Quote
Old 12-27-2006, 11:44 PM   #11
Unseen
insomnia...
Unseen's Avatar
Send a message via MSN to Unseen
Where did you got the case??
Unseen is offline   Reply With Quote
Old 12-28-2006, 02:57 AM   #12
LukeXE
-130C Club Member
Send a message via AIM to LukeXE Send a message via MSN to LukeXE
From me I bought it from Raven, who bought it from you
LukeXE is offline   Reply With Quote
Old 12-28-2006, 04:07 AM   #13
Unseen
insomnia...
Unseen's Avatar
big chain...
Old 12-28-2006, 04:32 AM   #14
runmc
Admin
runmc's Avatar
I would suggest feeding the desuperheater from the top and then have the exit tube at the bottom run up to the condener. You may trap oil in it the way you have it now. I would also leave a space between loops for air cooling.
Nice cooler.
__________________
Worthy is the Lamb
runmc is online now   Reply With Quote
Old 12-28-2006, 05:12 AM   #15
johann
johann's Avatar
Nice cooler.
I agree, the exit should be at the bottom
__________________
My Phase change builds thread
johann is offline   Reply With Quote
Old 12-28-2006, 09:17 AM   #16
bazx
-100c Club Member
bazx's Avatar
nice clean work well done
bazx is offline   Reply With Quote
Old 12-28-2006, 09:47 AM   #17
Brettbeck
Brettbeck's Avatar
Send a message via MSN to Brettbeck
Nice unit Duniek!
lol !
Brettbeck is offline   Reply With Quote
Old 03-23-2007, 06:44 AM   #18
Duniek
Duniek's Avatar
new plexi case for single stage
__________________
NEW CNC POTS
Old 03-23-2007, 07:06 AM   #19
Barnsley-Bill
Barnsley-Bill's Avatar
Send a message via MSN to Barnsley-Bill
Wow Duniek that looks real sweet .
Barnsley-Bill is offline   Reply With Quote
Old 03-23-2007, 07:24 AM   #20
eR1k
The finish on that case looks excelent
__________________
eR1k is offline   Reply With Quote
Old 03-23-2007, 08:17 AM   #21
LukeXE
-130C Club Member
Insane !
Old 03-23-2007, 08:30 AM   #22
sacha35
sacha35's Avatar
Looks very nice, well done mate.
__________________
sacha35 is offline   Reply With Quote
Old 03-23-2007, 08:47 AM   #23
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
What do you use to cut the aluminum angle?
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 03-23-2007, 09:05 AM   #24
boshuter
boshuter's Avatar
Send a message via MSN to boshuter Send a message via Yahoo to boshuter
What kind of temp monitor or controller is that in the plexi case?
__________________
CPU's: E6700es, 950es (WR 6.1ghz) http://valid.x86-secret.com/show_oc?id=186415
MB's: Asus P5WD2 Premium, DFI 975 X/G
Memory: Corsair PC5400UL
Video: ATI X800pro, ATI X1800XT, ATI X1900XTX
boshuter is offline   Reply With Quote
Old 03-23-2007, 03:08 PM   #25
Duniek
Duniek's Avatar
In my friendly advertisment agency they hzve a special saw, which cut alu profiles on 45* , 90* and any diffrent angles.
it's elliwel ID961
__________________
NEW CNC POTS
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
