Check this out and tell me what you think...
E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
is it smileing at me?
wat a happy face hehehe
Pleas tell me what you think, first?Originally Posted by K404
Check out the size of the water block portion
You do realise that BFG have a preattached version.
http://www.overclockers.co.uk/showpr...odid=GX-037-BG
Im not entirely sure of its performance,though.
it smiles cause its wet...
Asrock Z68 Extreme4 Gen3
•i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
•G.Skill F3-12800CL9D-8GB
•ASUS 7850 @ 1250//5800
•Corsair TX650 V2
•Dell 3007WFP
•Win 7 64 Ult
I have dd water blocks for a pair of 7950 gx2's and I am aware of the dd/bfg solution as well...
Just throwing out something that may be better, I don't know yet
The water block flows more water, I think...but I'll know soon enough how it works.
Working on the sli solution at the moment...
So the channel walls are acrylic and not copper or are my eyes deceiving me?
Can you say "bad flow"?
why bad flow?Originally Posted by Mr. Popo
The picture is deceiving. the water channels are large and the walls are thin and made of polycarb.
It flows a lot more water than my dd gx2 wb
The copper plate is quite thin and should transfer heat to the water well.
The underside fits all the chips, gpu, etc perfectly, unlike the oem solution which uses some heat tape of some sort to make up for the clearance between the top of the chips and the aluminum fan base.
A test fit showed perfect contact with ALL the components.
Is there a GTS version?
That's not bad flow. This is the least restrictive block so far. Very wide channels and simple direction.Originally Posted by Mr. Popo
With the channels not being copper would effect heat disipation some.
It needs some pits or grooves in the copper channels to improve heat transfer and add surface area.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
my dd gx2 blocks are just a big open cavity, with some small raised copper fins only about an inch long in one area near a barb for flow direction I think.
the block on this one is much larger than the dd gx2 solution, but not sure when compared to their 8800 offering.
Also, the channels on this block are higher, and therefore it flows more water
if you look carefully at the channels, water that passes thru the shorter channels moves quicker than the water that flows thru the longer ones.
guess where the shorter channels are placed with respect to components on the board.
Bingo
Right over the gpu.
so it seems that as the gpu probably gets the hottest, its cooling water flows quicker than what is over the mem chips
This is also being looked at as a base plate to cover all components and possibly allow users to blot up their existing solutions, such as one or a pair of mcw 60's
the base needs to have the fins, and not the plastic.. also, change the plexi to delrin.
over the gpu, adding some more fins with half or quarter the thickness of the other channels.
I realize that more copper in the flow is better, but this may be suffiient, not to mention $$$
if you read , I said polycarb, not plexi.
polycarb is as good or better than delrin (acetal)
Yea, I suggest putting some fins or channels around the GPU area and the "smaller" GPU core.
Is it just me, or are the barbs on the wrong side?
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
!!! LOLOriginally Posted by D_o_S
________
Genetically modified food
maybe he just has a lian li case that mounts the mobo upside down
Intel QX8950
Asus P5K3 Deluxe Super WiFi
Cell Shock DDR3 PC3-3049504
2 x 2900XT 2GB Saphire
Antec 350W
Charles and Maxxxracer are right. The channels need to be copper, unless you're gonna use this as a chipset cooler...Originally Posted by MaxxxRacer
Formerly XIP, now just P.
I'd like to see copper, double the channels, and smoother channels for that matter. I don't think I will be water cooling this card anyways, but it's nice to see new blocks.
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
In the best case it will be worse than the stock cooler. In the worst case, and the most probably, the core will overheat. Let's hope thermal management works okay on the G80.
I'm sorry that I'm so negative, but you really need much more surface area above the core.
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
mill some groves above GPU area?
the front or back side with regards to barb placement would be nice addition to it
Thanks, everyone for the input
I am making changes
btw an mcw60 on this board runs at 53c full load (stock voltages)
