nTune that comes on the supplied CD...Originally Posted by Pt1t
When it's good it's really good...And when it's bad I go to pieces...
so why do i get 12k mb/s with singlechannel ddr800?^^Originally Posted by Pt1t
raiden
yes , but when apply , ntune needs to reboot ...Originally Posted by OldGuy
I never wrote singlechannel and ddr 800Originally Posted by Raiden Zero
it s dual channel and ddr2 @ 1150mhz 4-4-4
me , i cant go in this menu ...Originally Posted by Phil The Greek
I have been having hard time since yesterday I bougth this board.On default everything was fine.When it came to overclocking......oh man.In the begining I could not install ntune.I downloaded every last version(chipset drivers/ntune)and then instaled succesfully but it is not working(the problem above).I also can't run my memory @800-1T(memtest counts thousands of errors)when the same modules where running fine @1000 4-4-4-8 on 975x chipset.With 2T it seams to be ok but some short 32M spi runs I made,shows much slower times than 975x.Originally Posted by Pt1t
I was impressed by the Vr-Zone clocking of this mobo..real world end users are looking a nightmare..have you tried the 'P20' BIOS PTG?
______________________
Bugs in sigs suck.
Cheapen SSD drives (we're almost there!!) and bring back mobo fans!!!!
...remember kids,the Ipad is an incredible experience...
yesOriginally Posted by thebeast
1.6v is a lot on air...Originally Posted by metro.cl
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
Where did you acquire this bios might I ask? It is not yet available on eVga...Originally Posted by Pt1t
@thebeast...why the "real world nightmare" comment? So far the board is behaving nicely for me. I suspect after having the board for a few days and taking your time with it that most will agree it's not a bad board at all...Trying to slam home the highest OC you can get right out of the box is going to be met with lots of disappointment on any new board.
The board has a small learning curve and require fiddling to get it to optimal speed. One could spend a few days playing with memory timing and ratios alone.
They have done a great job for out of the box "auto" performance as well.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
Agreed...setup was a snap with this board. Figuring out "what" you want to do with the memory is going to be the most time consuming aspect. there is plenty to play with...Originally Posted by FUGGER
@ PTG...seemed fine right up to about 800mhz...can't say for sure on anything at this point though till I have it for a few more days. 6~8 hours is no where near enough time get a handle on this or any other board...
I dont even want to change motherboard if nobody can show that it performes the same clock for clock.Originally Posted by Phil The Greek
If not then it is just a STUPID hunt for Higher fsb without any performance gain.
Thus you pay more in power bill because you run 4.5 Ghz instead of 4. Ghz on a 975 but performance is the same????
does it natively support QUAD SLI??? (7950x2)
And would 7950 x 2 be competitive to 8800gtx x 2??
Higher FSB allows users with low end Conroe processors to reach a decent speed.
There are FSB holes above 400FSB, you need to jump out to 500FSB, try like 2020, 2040, 2060, 2080 bus speeds.
Dont over-volt, stick to around 1.5v on FSB, MCP, SPP
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Not sure yet Charlie, hopefully someone will test soon.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
Just tryed enything between 1780 to 2100.NO GO for me.And why my mouse pointer jumps around desktop when in high cpu clocks(sure under 3500Mhz).Originally Posted by FUGGER
Only good thing with this board is that can run my memory @3-3-3 but always on 2T witch still sucks in performance.I am missing my AW9D-MAX that could do 470+fsb
We accidentally set a 6300 CPU to 3300Mhz - 550 FSB x6 - while waiting for Pedro to pick up the mobo. Orthos stable.Originally Posted by wtkprol
Please forgive my stupidity, didnt take any pictures or screenshots.
This motherboard is the real deal. I'll have some registered results soon.
6600 @ P5WDHdlx, 2GB Gskill HK, 8800GTS 320MB, 41A @ 12v
American DadNo time to poop - I'll just do it on my way down the stairs!
...There are FSB holes above 400FSB, you need to jump out to 500FSB, try like 2020, 2040, 2060, 2080 bus speeds....
Is your ram running fine on 1T?
....Sorry to tell FUGGER but I feel disapointed.Can't boot under 440fsb and I can't adjust it from Windows.Also without 1T can't reach 975x performance.....
All these quirks dont make me feel that confident about purchasing this board.
The 'learning curve' sounds more appropriate than 'nightmare' i must admit,but ive come from sending back 3 x ASUS' (2 P5B deluxes and a P5WDH)
and i dont want to mess around so much for an overclocked, stable platform again.
>shrug< i do want this board..i'll just hang back and see how the idiosynchroses pan out.Good luck.
Bugs in sigs suck.
Does clockgen work with this mobo?
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
on intel you always run 2tOriginally Posted by Phil The Greek
