Results 1 to 6 of 6
Thread: Container
    May 2005
    POLAND/Cracow
    Container
    base thick 20mm and 60mm diameter (0,514kg)
    25cm brass pipe 50x1mm
    if you want one PM me
    -150c Club Member
    May 2005
    Northeast, USA
    I hope you added alot of surface area to that base cause the brass I dont think is going to help you at all.
    If you have a cooling question or concern feel free to contact me.
    I am Xtreme
    Dec 2002
    whats the base look like inside, is it just flat?
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    You have a top mounting bracket or no?
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Nov 2005
    The Netherlands
    the base is too thick.
    10mm is perfect , 20mm is too much
    Mar 2005
    estonia , tallinn
    Quote Originally Posted by n00b 0f l337
    just remember , base cools the cpu not the tube
