Results 1 to 24 of 24
Thread: XtremeAudio vs XtremeGamer vs XtremeMusic
    Jun 2005
    XtremeAudio - $65
    XtremeGamer - $90
    XtremeMusic - $110
    If all i'm doing is gaming, will the XtremeAudio do the job, or is there reason to get the ExtremeMusic? everyone keeps saying how much better games sound on the X-Fi, but do I need the high-end stuff or can I get the same results with the XtremeAudio for $65?
    retired AMD64 Opteron 170 Toledo CCBBE 0615EPMW 3.1GHz 1.52V with removed IHS
    Intel Q9650 L827A 4.2GHz (467*9) 1.288v
    G.Skill 8GB F2-8000CL5D-4GBPQ
    ASUS P5Q Deluxe BIOS V1406
    eVGA GeForce 8800GTS SSC 512MB
    3x Western Digital 640GB Black RAID 0+5
    Creative SB X-Fi XtremeGamer
    Swiftech H2O-220 Compact 35C/58C
    Cooler Master Real Power Pro1000 RS-A00-EMBA 1000W
    Dell 2405FPW 24" WUXGA
    Antec Twelve Hundred
    Heatware iTrader eBay
    Jul 2006
    guess it also depends on what you connect to the soundcard, speakers/ headphones, how good those are as well.
    i think saying your speakers should cost the same as your soundcard sounds reasonable.
    Jun 2005
    i have the old altec lansing ATP3 but the sound is still pretty good.
    http://www.amazon.com/Lansing-ATP3-3.../dp/B00004XRED
    i just want to get the most out of my games, like BF2. I'm guessing the entry level X-Fi will do the trick?
    Jul 2006
    i don't know nuch of the two new versions but since you said gaming so i'ld say the xtremegamer, that's if you can justify the extra 25 bucks over the entry level.
    Jul 2005
    So. Cal
    XtremeGamer is like the fatality...just a bit better components. Xtrememusic is just fine.
    Jun 2005
    Quote Originally Posted by Reinvented
    yeah, but xtrememusic is the most expensive and the xtemegamer is so close in price to the xtrememusic
    i was hoping someone would say just get the entry level one and i'll be fine, but it sounds like i need to fork up and get the gamer or music version.
    Xtreme Recruit
    Sep 2006
    I have the XtremeMusic it is really good for games. I stepped up from an Audigy 2 and I could hear a significant difference in EAX/sound quality. When I was on Creative's site I was looking at the comparison for the xtemegamer and xtrememusic and the specs looked the same.
    Jun 2005
    Quote Originally Posted by kimbo
    funny you mention checking the specs. i right away went to compare the xtremeaudio against the other two and they don't display the specs on the audio version. hmm...wondering if that's because they don't want to show you it's the same as the other two, just for less cost
    Jun 2005
    i found this exact thread on creative's forum, but still unclear on which to buy. the platinum is looking attractive as they're offering a $50 rebate!
    http://forums.creative.com/creativel...ssage.id=78388
    Xtreme Recruit
    Sep 2006
    I think functionally that they are all basically the same card aside from the various software support offered for each type of card. BUT there are ways to get around that.
    Mar 2006
    I would not buy a super high end card unless you:
    A. Have eg. HD600 headphones or a nice hi-fi systems to hook it up to.
    B. Want the special outputs like coax or whatever.
    $60 would be a good price to pay for normal stuff.
    Jun 2005
    I think I'm gonna get the XtremeGamer. I put the specs side by side. the only real difference I see is the X-RAM, but from what I keep reading, only games can natively use it, not XP and not Vista, and hardly any games are designed to take advantage of it. knowing this, I don't see the reason behind spending the extra money to have something that I might never use. that leaves me with the Music and Gamer versions, and side by side, the specs looks almost identical. so, i'm going Gamer for $90 and save myself a few bucks
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    never seen the x-fi gamer or x-fi audio in canada yet.
    seems the only difference between the two is the x-fi audio has HD EAX 5.0 disabled via drivers.
    EDIT: but if they are trying to sell the x-fi music for the same price as the x-fi gamer,(like on their shop) take the x-fi music, better quality board.
    looks like creative may be trying to make a few bucks by replacing the x-fi music with the x-fi gamer, since the music would be significantly more expensive to produce.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Jun 2005
    So the XtremeMusic is just a slightly better version of the XtremeGamer?
    According to that comparison there isn't much difference.
    How much of a difference would xram actually make?
    Jul 2006
    All X-fi's below fatal1ty are the same just changed by drivers. The fatal1ty is the same but has x-ram, the elite pro is the only one with changed dacs
    May 2006
    any hack firmware or something? :P
    Jul 2006
    Most likely somewhere on the net.
  18. #18
    Oct 2006
    Suffield CT
    Rule the Xtreme audio out, leaves sound processing up to the cpu = bad will drop framerates, xtreme audio is not for gaming...
    Either the Xtreme music or gamer. On newegg theres only a 2$ price difference, the xtreme music is only 92 and also has a 20$ rebate
    e4300 @ 3.2ghz 1.38v (lapped) | Gigabyte DS3R | 2x1gb of Micron D9 667 @ 712 5-4-4-12-2t @2.1v| Sapphire HD3850 256mb 775/1044 | OCZ StealthXStream 600w
  19. #19
    Sep 2005
    Quote Originally Posted by Teratism
    This is right.
  20. #20
    Oct 2006
    Netherlands
    Quote Originally Posted by Hey_Its_Cole
    This is right.
    except for the newly release xtreme audio & xtreme gamer
    my buddy, Lian Li A70:
    * Asus P6T Deluxe & Intel Core i7 920 @ 4.2 + HT, stable @ 1.3875v & 6GB OCZ PC3-12800 Triple Channel Low Voltage & 1X Hitachi Deskstar 1TB
    * DELL 30"WFP3007-HC & 2x 4850 CrossFire & X-Fi Fatal1ty Pro & Sennheiser HD595
    * SilverStone Zeus 750W
    my liquid setup:
    *cpu EK Supreme Acrylic *rad TFC Xchanger 480QUAD *pump DDC-2 + XPSC reservoir top
    *tubing Tygon B-44-4X 1/2"ID - 3/4"OD + all Feser compression fittings
    MY LIAN-LI A70-480QUAD WORKLOG - KAOZZ.COM
  21. #21
    Oct 2005
    Ottawa, Canada
    gamer and music are basically the same
  22. #22
    Oct 2006
    Netherlands
    If were talking about the same card, Xtreme Gamer, it might have the same features but:
    - the PCB is totally diffirent
    - soundchip is diffirent
    - no connector for expansion bay
    The Xtreme Gamer Fatal1ty Pro however is the same as the, Music, Platinum & Fatal1ty. Only with added xram.
    If you look at the pics of the card itself and not at the specs it all becomes clear
    my liquid setup:
  23. #23
    Jul 2005
    Richmond, VA
    I'd advise the XtremeMusic.
    [-AMD Opteron 165 @ 3.0Ghz-]
    [-DFI LAN Party UT uNF4 Ultra-D-]
    [-AData 4GB (4x1GB) DDR484-]
    [-eVGA Geforce 8800GTS 640MB 320-Bit-]
    [-Creative Sound Blaster X-Fi XtremeMusic-]
    [-Seagate 160GB & 250GB 16MB Cache SATA300-]
    [-OCZ GameXStream OCZ700GXSSLI-]
    [-DELL 2005FPW LCD Monitor via DVI-D- & Westinghouse 22w3 LCD Monitor via DVI-D]
    [-Windows Vista Ultimate x64-]
  24. #24
    Oct 2005
    On the XtremeMusic, there are 3 different modes you could use.. Is it a must to switch to Gaming Mode before gaming, or leaving it in Entertainment Mode is fine (I use Entertainment as my default because I like to 'duplicate' my front channels to my rear channels when listening to music - like the 'Stereo x2' mode in Audigy 2)?
    OT: For the higher-end models, do I need to switch to Gaming Mode to utilise the X-RAM, or leaving in Entertainment/Audio Creation mode is fine assuming the X-RAM utilization is by the game coding?
    TIA!
