10-03-2006, 02:25 PM
#1
I am Xtreme
1.1ns sammy ram need cooling?
My EVGA GTOs came today so the first thing I did was tear off and remount both the HSF and the vreg sink with ceramique. Turns out unlike my past 3 evga cards, the stock cooler will only contact ram with thermal pads, which are now lumped up in the trash. Am I ok running the ram bare with a 120mm fan over the cards?
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
10-03-2006, 02:34 PM
#2
xtreme member
I'd say no. tried running the x1800xl w/ 1.4ns ram 'sink-free, and now i've just bought 2 of those GTO's to replace the now artifacting pile of crap. Took abt 4 months before it was a problem tho
10-03-2006, 02:52 PM
#3
I am Xtreme
Well we'll see...
In other news my 230 dollar foxconn board apparently DOESN'T include RAID drivers so I can't install windows. Probably just going to run one drive.
Also, I reseated the vreg heatsink with ceramique, used lots because the row to the left just happens to be lower than the rest of them, and now the back of the vreg area on the pcb is BURNING hot. Is that safe?
__________________
10-03-2006, 02:56 PM
#4
xtreme member
is the ceramique touching the pcb as well? Don't got mine yet, so i cannot answer that, but i'll look for it when my cards arrive tomorrow.
10-03-2006, 04:40 PM
#5
I am Xtreme
They get hot as hell... Are these refurb broken GTXs?
__________________
10-03-2006, 04:47 PM
#6
xtreme member
i think so. Bought 'em anyway...EVGA lifetime warranty sounded good to me...if they die, i'll get another two.
10-03-2006, 04:51 PM
#7
Xtreme
Were they hot before applying ceramique?
I remember using small metal squares between RAM and GTX heatpipe cooler on 7800gtx since I didn't like the idea of thick layer of ceramique
__________________
10-03-2006, 04:58 PM
#8
INTEL inside
overclock results ?
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
10-03-2006, 05:05 PM
#9
I am Xtreme
Between the cooler and the RAID I just got running an hour ago. Have a few tests tomorrow to study for. Plus I've been told those vregs are the same problem on most dead 7900s so I'd rather NOT kill the cards off before my cod2 match tomorrow night.
__________________
10-03-2006, 05:12 PM
#10
They must be refurb. I bet thats why they're clocked so low for GTX.
-Satan
__________________
10-03-2006, 05:16 PM
#11
I am Xtreme
Just sink them and run stock. You don't "NEED" to OC with SLi, but of course you will  . Who wouldn't?
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
10-03-2006, 05:17 PM
#12
X.I.P
200% of GTO are recall card hehehehe
but who cares!!
cheap and lifetime warranty!
the reason for recall is ram problem just let you guys know about it
10-03-2006, 05:22 PM
#13
I am Xtreme
So just don't mess with mem clock?
__________________
10-03-2006, 05:26 PM
#14
I am Xtreme
Yeah
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
10-03-2006, 05:28 PM
#15
I am Xtreme
Just looked at the box... GTX on top and GTO on the front is fishy right? Closer look and I figured out that the GTO is a sticker. Started to pull it off and it's really a 7900GTX box. These are refurb cards probably run at 1.9vdd instead of 2.2 (I think that's what it is?) so that they don't die.
__________________
10-03-2006, 05:32 PM
#16
xtreme member
 As soon as there was news of "stolen" cards, i knew what was up.
10-03-2006, 05:40 PM
#17
I am Xtreme
These aren't stolen though... Those were the GS cards.
__________________
10-03-2006, 05:49 PM
#18
xtreme member
...Probably bought as refurb's, and then sold as not. THAT would be stolen.
Just made me think about what was going on...then remembered the dying cards @ release...
10-03-2006, 05:50 PM
#19
Well, if these cards all are refurb'd they have a hell of a lot of them. As well, EVGA has a lifetime warranty so... go nuts? :p
#20
I am Xtreme
Failvidia @ it once again..
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
10-03-2006, 06:05 PM
#21
Xtreme Cruncher
Originally Posted by Supertim0r
overclock results ?
Mine is running 700 / 1600 right now - 3DMark scores are better than what I got with my 7900 GTX. I'm not going to pull the heatsink or do anything to the card - don't want to void warranty or kill step up program. I don't care if it IS a refurb 7900GTX - I got a GTX for $250. Should hold me over for a while. Oh - and th thing is dead silent.
__________________
Bloodrage || 920 || TRUE Black
3x 2GB HyperX 2000 ||
2x 300GB WD VR Raid 0 || 1TB Samsung F1
2x Samsung SH-S183L DVD/RW
MSI 4890 OC || LG 246WP
Sonar X-Fi || Klipsch 5.1
Lycosa || DeathAdder || Exact Mat
CM ATCS 840 || Seasonic M12D
Vista Ult x64 - Win 7 x64
10-03-2006, 06:20 PM
#22
Xtreme Cruncher
695/1600
i need to flash to 7900gtx bios, but dunno how
__________________
Heatware: bail_w
10-03-2006, 06:35 PM
#23
xtreme member
Only question that remains is how long they last at those speeds.
10-03-2006, 07:01 PM
#24
Xtreme Guru
why not buy some ramsinks and sink them? I mean even with alu ramsinks you should see a noticeable improvement. I don't use the adhesive backing but epoxy/as5 mixture instead. Works wonders...
__________________
10-03-2006, 07:22 PM
#25
INTEL inside
my MSI card came doa  (it's a GTX too  )
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
