Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Danfoss NL11F inside pics !!
    -100c Club Member
    Apr 2004
    Portugal
    Ok, to the ppl who never saw an hermetic compressor insides this will be an interesting thread, also to the NL11F users there will be usefull info.
    Received a broken prommy some time ago to repair. Compressor was making strange noises.
    So for looking at the picture below why is it broken?
    Lets see who gets the correct answer heheheeh
    (Walt, Detroit and ppl in trade are not allowed to play this game )
    Oct 2005
    Sugar Land, TX
    Liquid refrigerant entered cylinder (due to underload), "hydrolocked" it, and snapped the connecting rod?
    Lack of oil?
    Excessive operating pressures?
    Quote Originally Posted by A HVAC friend of mine
    If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her evaporator coils.
    -150c Club Member
    May 2005
    Northeast, USA
    Becuase someone cut the top off it.
    If you have a cooling question or concern feel free to contact me.
    Dec 2005
    heh, heh...I can see it now, the next big thing in modding...compressors with windows.
    Dothan FTW!
    Jun 2004
    London, UK
    that would be awesome, but the extreme pressures, temperatures, and vibration in compressors would probably blow out most windows.
    .:MeltedDuron:.
    Aurora - i5 7600K@4.2GHz- Zotac GTX1070 Mini - 16gb Corsair Vengeance DDR3-3000 - Asus Prime Z270M - Fusion ioDrive Duo 1.2TB - 2x512GB Samsung Evo 970 Plus - Seagate FireCuda 2TB - HGST 4TB - Fractal Design Define Mini - Win7 and OSX 10.12
    Lenore - Xeon L5430 - Gigabyte G33M-DS2R - 2x2GB HyperX 6400 - Sapphire Radeon HD5450 - M-Audio Delta 1010 - Adaptec SCSI - 256GB Firestorm SSD - 1TB Samsung F1 - 2U rack mounted - WinXP and OSX 10.6
    Delilah - Pentium E5800 @ 4.2GHZ (VID mod) - Asrock Conroe865PE - Radeon 9800 Pro - 2x512MB GeiL Blue PC3200 - 30GB OCZ Vertex - 160GB Seagate - 2U rack mounted - Win98SE and Win2k
    Jezabel - Athlon XP 2800+ Barton @ 2100 (200*10.5) - ATi FireGL X1 256MB - Asus A7N8X-E Dlx - 2x512MB OCZ EL PC3200 - OG Antec Case - Win98SE and Win2k
    Mysti (WIP) - Pentium II 350MHz - Abit BX6 Rev2 - 4x256MB PC100 SDRAM - ATi Rage Fury Maxx - Diamond Monster 3D Voodoo2 8MB - 20GB IBM DeathStar - Still looking for the right case...
    Mar 2005
    houston TX USA
    Quote Originally Posted by MeltedDuron
    get teh right kina plexi glass, and your good xD
    anyways, that silverish piping on top looks kina out of place?
    emptiness
    Jan 2006
    Quote Originally Posted by Rockhammer
    Lol compressors with windows...
    Apr 2005
    Nth QLD, Australia
    Quote Originally Posted by INJViper
    Nah, that'd never work, it'd constantly crash on you for no reason at all
    Jan 2006
    Sheffield, UK
    Is the problem visable on that picture? Or is it an internal problem?
    Btw, is it that lump of metal that clunks against the sides when you move it around, or is it something inside that?
    Steak for Breakfast
    Dec 2005
    N.Vancouver, BC, Canada
    Pretty cool stuff lol, first time seeing a compressor's guts.
    Does it have to do with that rectangular piece under the silver pipe, it doesn't look secured.
    Dec 2005
    I was joking guys!
    Jan 2006
    Sheffield, UK
    Quote Originally Posted by Thrilla
    look secured.
    Me too . Must admit I didn't expect it to look anything like that...
    Feb 2005
    Smurf in My Loop
    Didn't even know what a compressor looked like inside. Can you even repair one?
    MSI Big Bang XPower
    Core i7 930 @ 3.38 Ghz
    6 x 2GB Patriot DDR3 1600
    XFX Double D 7850
    Therltake Toughpower 1200
    Thermalright Ultra 120 Extreme
    OCZ Revodrive 3 120GB
    Corsair 700D
    Dell 2405FPW
    W7 Pro 64 bit
    May 2005
    Portugal
    internal leak ?
    Mar 2005
    houston TX USA
    Quote Originally Posted by qdemn7
    i would assume so, but you need to know how to weld atleast in order to get the top back on.
    emptiness
    -100c Club Member
    Apr 2004
    Portugal
    yes, of course it could be welded on if it was a minor repair, not the case here
    Well congratz to Star882, he was right on the 1st answer.
    Yes the connecting rod its snapped as you can see on the lowsy picture below. The connecting rod connects the piston to crankshaft just like in a car.
    The piston and cylinder are also damaged.
    This probably happened by liquid refrigerant entering the cylinder, this is what can happen when you see ice reaching the compressor and hearing "watter in hot fry pan" noises.
    On the pic below, in white, you see the suction tube to the cylinder. It was the 1st time i saw a compressor with suction so close to port, this means this compressors are quite prone to damage if you let liquid refrigerant reach the compressor, if you use that suction port.
    Also noticed that the cap tube on this mach2 ST was modded increasing it by 80cms, poor compressor really had a rough short life. Stock cap tube is 2,4mts, adding 80cms will make it 3,2mts
    It must have had very high high side pressures for long periods of time which also lead to premature death. The cap increase might have lowered the no load temp but reduced dramatically the capacity and ppl trying to make it to hold load probably overcharged it so much that liquid refrigerant was reaching compressor ending on the compressor failure.
    Some more pics
    Xtreme Legend
    May 2003
    Portugal
    @ some time that cappilar mod are usualy, cpus now are to mutch hot.
    3dmark addict
    phase-change addict
    dirty benching addict
    tits lover
  18. #18
    Xtreme Cruncher
    Feb 2006
    Emmaus, PA, US
    looks cool, thanks for sharing
    |Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
    (12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
    (12:16:19 AM) OC3D NoL: RAWRRRR
  19. #19
    Xtreme Mentor
    Sep 2004
    my pants
    Quote Originally Posted by aussie_guy00000
    ROFL
    French Duron Poof
    Every time you lap a swiftech block a kitten dies
    "Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
    HEAT
  20. #20
    Aug 2005
    Pretoria, South Africa
    I cant see how anyone could make a capillary tube 0.028 3.2m on a NL11f.
    As blaster say, it will kill the compressor. Poor NL11F. I hope the poor owner did not pay to get his unit downgraded like that. He sure is paying now to get it repaired
  21. #21
    Feb 2004
    Netherlands
    longer cap tube doesn't raise discharge pressure!
  22. #22
    Jun 2006
    Northville, Michigan
    Quote Originally Posted by Unknown_road
    Very good Unknown_road! Yup he's right, the system is a closed loop, if you restrict the low side by way of the expansion device, the mass flow will go down. Less mass flow = less capacity = lower discharge pressure
    If it was then overcharged to try to compensate (increasing the subcooling), like Blaster guessed, then the discharge pressure could be just about anything, could be higher or lower depends on how much overcharge.
    Excellent thread Blaster, very educational!
    You see what you did there? You got between me and the coffee, now this creates a SITUATION!
  23. #23
    Xtreme Legend
    May 2003
    Portugal
    if that promy is portuguese, probably that mod was done by me or by an a/c tec @ some years.
    my first mod on my mach1 was done by an a/c man on my city, making what the xtremesystems a/c "boss's" of that time have told-me, somthing like: add 0.8 or 1meter of cappilar and add r404a until it gets @ 1" off compressor
    i'v gone with some friends and her promys to that guy, we test only r404a and the cappilar add, and it gets some degrees better with the extra cap, the cpu's load on that time aren't the same we use now.
    that compressor must have some years of working
    3dmark addict
    phase-change addict
    tits lover
  24. #24
    May 2005
    Sugar Land, TX
    Quote Originally Posted by star882
    Lack of oil?
    YGPM
  25. #25
    Aug 2005
    LOL!
