My E2180
On 775Dual-VSTA Motherboard.
No volt mods
So far booted @310FSB
Stable @300FSB
Cpu-z voltage average 1.28
Water cooling it but that should not make any difference at this speed.
Guy’s please contribute and share put in the specs that work best for you.
BIOS 3.00
CPU Configuration
Overclock Mode [CPU,PCIE Async.]
CPU Frequency (MHz) [300]
PCIE Frequency (MHz) [100]
PCI Frequency [33.33MHz]
Spread Spectrum [Disabled]
Boot Failure Guard [Enabled]
Ratio Active Value 10
Max CPUID Value Limit [Disabled]
No-Execute Memory Protection [Disabled]
Chipset Configuration
DRAM Frequency [266MHz (DDRII533) ]
Flexibility Option [Disabled]
DRAM CAS# Latency [5]
DRAM Bank Interleave [Auto]
Precharge to Active (Trp) [5T]
Active to Precharge (Tras) [15T]
Active to CMD (Trcd) [5T]
REF to ACT/REF to REF (Trfc) [Auto]
ACT (0) to ACT (1) (Trrd) [Auto]
Read to Precharge (Trtp) [Auto]
Write to Read CMD (Twtr) [Auto]
Write Recovery Time (Twr) [Auto]
DRAM Bus Selection [Dual Channel]
DRAM Command Rate [2T Command]
Advanced Memory Configuration [Untouched]
DRAM Drv DQS [Auto]
DRAM Drv CS [Auto]
DRAM Drv DCLKA,B [Auto]
DCLK Output Duty Ctrl [Auto]
CLKBUF DDRA group delay [Auto]
CLKBUF DDRB group delay [Auto]
CLKBUF FB_OUTA delay [Auto]
CLKBUF FB_OUTB delay [Auto]
CLKBUF DDRA Drv [3x]
CLKBUF DDRB Drv [3x]
CLKBUF FB_OUTA Drv [4x]
Advanced Host Configuration
Pipeline DRQCTL [Enabled]
GTL Control [Auto]
3V66 group delay [Auto]
DRAM Voltage [High]
AGP Voltage [High]
Primary Graphics Adaptor [AGP]
AGP Mode [8x]
AGP Fast Write [Enabled]
AGP Aperture Size [256MB]
AGP Staggered Delay [Auto]
AGP GADSTB Output Delay [Auto]
AGP 3.0 Calibration [Auto]
AGP 3.0 DBI Function [Auto]
DBI Output for AGP Trans. [Auto]
DBI Output for FRAME Trans. [Auto]
V-Link Speed [Fast]
PCI Delay Transaction [Disabled]
IDE Drive Strength [Normal]
PCIE Downstream Pipeline [Auto]
OnBoard LAN [Enabled]
OnBoard HD Audio [Enabled]
Front Panel [Enabled]
CD-In [Enabled]
Bus No. [Enabled]
Echo TPR Disable [Auto]
Have since done the BSEL pin mod, Bios recognises it as a 1066 MHz CPU, Automatic overclock.
As per picture in post 29 of below link.
http://www.xtremesystems.org/forums/...=134550&page=2
