Results 1 to 18 of 18
Thread: Asus P5B with GSKILL memory setting instructions and discuss thread
    Jul 2006
    Portugal
    when I came to this thread I was hoping to find some usefull help.
    then I saw this picture:
    well, its ok that the most part of this forum users doesn't know how to set memory subtimings, but wouldn't expect that from a gskill technician.
    the sub timings for the gskill HZ 6400 should be:
    3
    10
    5
    13
    hope this information helps.
    they are not timings that i got by myself. they're really the sticks default value.
    Cumps,
    Remo
    G.Skill USA Tech
    Sep 2005
    thx for the info
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Sep 2006
    WA, Australia
    I have DRAM TRFC at 25, and it has been Orthos stable for 13hours. Should I revert to 42 as per your recommendations? Or leave it?
    No cheese!
    G.Skill USA Tech
    Sep 2005
    for Micron chip Trfc is ok to set under 42, but other IC might not even boot with TRFC 41
    Nov 2004
    Portugal
    No more developments ?
    My System
    » ASUS P6T Deluxe V2 (CF w/0006 bios) | Core i7 930 3002A879 @ 4.20GHz (21x200) | Corsair Dominator DDR3 6GB TR3X6G1600C8D @ 1603MHz 8-8-8-21-1N
    » ASUS ENGTX460 TOP 1GB @ 900/4000MHz | SB X-Fi Titanium PCI-E | C:\Intel SSD X25-M G2 80GB | D:\Samsung F3 HD103SJ 1TB | E:\Plextor PX-716SA
    » Corsair HX620W Modular | CoolerMaster Stacker custom "All Black" | Samsung LED XL2370 23" Full HD
    » WC 3/8": Apogee GTZ + BI GT Xtreme 240 + Koolance Nozzles + Station 600 + Silver KillCoil
    G.Skill USA Tech
    Sep 2005
    what development?
    Nov 2004
    Portugal
    developments = recommendations/tips
    My System
    Dec 2006
    I'm putting together a system based on P5B. I have a Core 2 E6600 installed and a set of F2-6400CL5D-2GBNQ DDR2 800 5-5-5-15. So far I have been unable to make it run full speed at 800MHz. If I do so, either on BIOS auto settings or following the directions from this thread with manual settings, the system becomes extremely unstable, but if I lower the speed to 667MHz, so far I haven't seen a single issue, but, of course, it's a waste... What am I doing wrong? Is it possible that the memory I got is bad?
    Thanks!
    G.Skill USA Tech
    Sep 2005
    have you try to increase voltage a bit to 1.9v or 1.95v?
    also do this on subtiming
    4-42-3-11-7-13
    D-m.o.s.t
    Jul 2005
    The Netherlands
    got some fine g.skill 8500Hz on my p5b deluxe but the only annoing thing is it will only boot at the 4-4-4-5-4-35-3-10-5-12 timing's or something near that.
    stock spd 4-4-4-5-5-42-10-10-10-10 or in safemode of the board won't boot.
    somebody got an answer for that? its realy anoing when it comes to overcklocking.
    when it runs on the above settings it can run 600 4-4-4-5 stable.
    G.Skill USA Tech
    Sep 2005
    10-10-10-10 is actually P5B's own setting, not SPD rated.
    the standard is 3-11-7-13 for all DDR2 800 ram.
    i recommend for tigher timing is 4-9-5-9, but don't quote me
    GST
    Dec 2006
    Thumbs up It worked!!!
    Quote Originally Posted by G.S Technician
    4-42-3-11-7-13
    I'm sorry for taking so long to reply. My system was in pieces and I had no way to try the memory settings you were suggesting.
    Now the system is finally back together and I hope it will stay this way.
    I looked at the voltage settings and I did try 1.9V last time when it was very unstable.
    The next setting would be 2.0V, which for some reason is shown by the BIOS with highlight and red text.
    I decided to give it a try with the same voltage (1.9V) and use the timing you suggested and so far I had no problem at all, which is promising.
    The system booted as usual, I ran a few benchmarks, played a game, all seems to be just fine this time .
    One confusing thing for me at the moment is how the memory settings are reported by CPU-Z utility.
    When I go to Memory tab, it shows Frequency of 400 MHz. Is this normal?
    Sep 2006
    Quote Originally Posted by jvfff
    Yes, that's normal. 400MHz x 2 (DDR2=double data rate) = 800MHz.
    Dec 2006
    Quote Originally Posted by Buffalo2102
    Thanks for the boost of confidence, Buffalo2102.
    I thought it should be something like that, but not being an expert in the field left me wondering...
    Feb 2007
    Does anyone know the max stable overclock on a 2.1v (ram/memory) with a p5b?
    Intel C2D E6300 1.86Ghz L629A244 @ 3.78GHz
    Asus P5K-E Wifi/AP Rev.1.02g
    Thermalright Ultra Extreme 120+ 2x 120mm
    ATI x1900 GT Rev.2 256mb 513/657
    G.Skill 2x1gb Hz--540MHz
    Apr 2004
    Israel
    F2-6400CL4-1GBHK on P5B Deluxe, 1219 BIOS . Speedstep ON.
    Voltages are either auto. 2.15V mem and 1.375V CPU (Vdroop)
    485 (970) 1:1
    4-4-3-5-5-35-10-10-10-11
    cool temps and safe hardware are the important factor.
    Any suggestions ?
    What is Static Read Control ? (auto now)
    P5B Deluxe 1.03g, Bios:1219, T< 35C / E6300 L629A40x + HomeBuilt WC. 450/1.3625V 24/7, SpeedStep ON / 2x1Gb Gskill F2-6400CL4-1GBHK 1:1/2.15V, 4-4-3-5-5-35-10-10-10-11 / Sapphire HD4870 @Defaults/2x36G Raptor RAID0 + Barracuda 7200.10 320GB + WD1200JB 120Gb + more / Samsung 22" LCD T220P / Liberty 400W PSU / Antec Sonata1 w/AcoustiPack kit, homemade AirDucts / Rosewill Laser mouse , Genius SlimStar 310 KBD
    Gigabyte M912M Netbook
  18. #18
    May 2007
    Portland, Oregon
    Quote Originally Posted by tuanming View Post
    I ran 24/7: 4x1GB 6400 HZ (2:3) at 538MHz 5-5-5-15 at 2.1v
    e6600 at 3.24Ghz
    vNB: 1.55
    Asus P5Q Deluxe (P5QD1406) || Q9400 at 3.4GHz || 2x2GB Mushkin Redline PC2-8000 || HIS HD 4870 1GB w/ Scythe Musashi (silent) || 501GB Samsung HD || Zalman ZM850-HP || Antec P182 || Windows 7 x64 RTM
