Page 211 of 340 FirstFirst ... 111161201208209210211212213214221261311 ... LastLast
Results 5,251 to 5,275 of 8487
Thread: ASUS P5W DH - Problems + Fixes Thread
  1. #5251
    Xtreme Enthusiast k0nsl's Avatar
    Feb 2005
    Scandinavia
    Yes, of course. I could just force a flash using the DOS utility.
    Who else can't set Vcore?
    When you were born, you were crying and everyone around you was smiling. Live your life so that when you die, you're smiling and everyone around you is crying.
  2. #5252
    Oct 2006
    Norway
    Quote Originally Posted by happ View Post
    Your GTX blow hot air directly to mobo temperature sensor which is situated just below GTX fan. So the sensor is hot, not entire mobo. This is the same situation with my XFX GTS 320. My mobo temp is some 45 °C on idle.
    Ok, I hope you have right...
    My comp...
    Maximus II Formula | E8400 @ 4Ghz @ 1.31V load - LINPACK STABLE | Xigamatek Dark Knight cooling | 2x 2gb Mushkin eXtreme 1066 | ATI 4870x2 | RaptorX + 350 | ODIN GT 800W | X-FI Extreme Gamer Fatal1ty + Z5500 | Samsung 245B 24" 5ms full HD -
    MSI P45 Platinium | E6600 @ 3.0 1.28V | TRUE 120 extreme | 4gb Ocz Reaper | XFX 7950GT 512mb | 2x 500gb, 2x 320gb, 1x 300gb, SATA2 16mb | MIST 600W| ANTEC P190 | Samsung 2032BW |
  3. #5253
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by sbinh View Post
    Temp inside has nothing to do with mobo ....
    Oh my bad, the motherboard is in its own little space with its own air supply then... Yeah. Jeeze, go learn some (seriously) basic physics..
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
  4. #5254
    Jul 2007
    Minsk, Belarus
    Quote Originally Posted by k0nsl View Post
    ...Who else can't set Vcore?...
    I even can't enter the menu item to do that with 2205. So you're not the only one.....
  5. #5255
    Feb 2005
    Scandinavia
    Quote Originally Posted by AndrewSh View Post
    OK, well I can sometimes - but when I set the Vcore and save the changes and return there again, its back on "auto" with no options available. Hilarious.
    The 2205 bios seems to like to disable the onboard sound too.
  6. #5256
    Xtreme Cruncher
    Jul 2005
    London - UK
    Well I said it was a bios a week or so ago...
  7. #5257
    Nov 2005
    UK
    Just looking for some advice. Is there any consensus on which is the 'best' bios for a B3 q6600 1066 quad core? Its currently on 1305, has been for ages and rock solid at 400, I'm reluctant to change it as it works so well.
    According to Asus support the G0 step is only supported in 2205.
    i7| EX58-EXTREME | SSD M225 | Radbox | 5870CF + 9600GT
  8. #5258
    May 2006
    Seeing how Asus states that the Commando needs BIOS 1404 for G0 support and how another guy who didn't know that, installed and ran a E6750 just fine on his age old 0803 BIOS dating from Jan 07 - I would just go ahead and try out the G0 chip on the old BIOS 1st and see if it runs OK.
    With all the bad feedback of 2205, update as needed else leave it alone.
    'He is no fool who gives what he cannot keep to gain what he cannot lose' - Jim Elliot
    Click on the pic to download a free pdf sample of the bestselling book!
  9. #5259
    Nov 2004
    Norway
    A long shoot, but it seemed to work for me:
    Important:
    This must be done ON THE VERY FIRST BOOT AFTER FLASH
    -Disable Enhanced C1 Control
    -Disable CPU Internal Thermal Control
    -Choose a Vcore (other than 'auto').
    -Hit save and reboot.
    ASUS P5K Premium 2.00G/A02 - Bios 1101
    Q9650 @ 4.0@1.30 - 24/7
    Corsair 4 x 2048 8500 C5
    ASUS HD 6950 2 GB.
    Cooling: PA 120.3 w/ shroud. (CPU / GPU / NB)
    Mist 800W
    Lian Li PC-A7010
  10. #5260
    Mar 2007
    SoCal
    I officially hate asus. Support sucks big time. I've sent in the mobo 4 weeks ago, and the replacement arrives today, and it's one rev. down. They can't do anything because the stupid b!tch on the phone claims that they have received rev1.02 when I've sent in rev1.04 (got 1.03 as a replacement). The document I've received with the replacement states that both mobos are 1.04g. What bunch of lying assh0les. I will never buy another asus, ever. At least, when I sent in my old abit mobo, they had the decency to replace with the same gen mobo and not some old junk. Asus, burn in hell and die.
    Sig is under construction
  11. #5261
    Sep 2006
    Silicon Valley, CALIF
    P5WDH; 1.02g; 66M0AG; BIOS 2205; Qx6700 @ 3.0g
    - disable Enhanced C1 and EIST
    - vCore set to 1.25vdc and 1.275vdc in separate tests
    - no issues found
    - vCore setting stayed over multiple reboots
    RESULTS:
    vCore = 1.25vdc; 201w (idle); CoreAvg: 124f/51c
    VCore = 1.275vdc; 205w (idle); CoreAvg: 129f/54c
    EIST only: 219w (idle); CoreAvg: 136f/58c
    Enhanced C1 only: 192w (idle); CoreAvg: 120f/49c
    AMB: 76f/24c - (booo summer, below AC "on" temp)
    CURRENT: (mild OC)
    P5W DH Deluxe Rev 1.02G/66MOAG (BIOS: 2602); CPU: Q6700 (G0, wk 23) @ 3.0G; FSB: 300
    MEMORY: OCZ OCZ2G11002GK 2x1gB or 4x1gB PC2-8800; vDIMM = 2.15vdc; 500mhz; 3:5; 5-5-5-15/18; 6113/6093
    HSF: Thermalright SI-128 w/120mm; LOADED TEMPS: CPU: 121f/49c; Cores(avg): 143f/62c; MEM: 102f/39c; AMB: 72f/22c
    GFX: AIW 2006 Edition PCIE; PSU: Seasonic S-12+ 550W; FANS: 4 x 120mm; 2 x 80mm (all low RPM, low noise)
    DRIVES: 7200.10 250G (x2); 7K500 500G (x1); 7200.10 400G (x2); 7200.10 250G (x1); ADDED Controller: Adaptec 1430SA PCIE
    AUDIO: X-FI Elite MOD: http://www.esnips.com/web/X-FIOpAmpandCapModification OPTICAL: LiteOn: DH-20A4P, LH-20A1H; BUILD LINK: http://www.esnips.com/web/ConroeReady
  12. #5262
    Mar 2007
    North Yorkshire
    Quote Originally Posted by anzial View Post
    Anzial - nice to hear from you again. You haven't had a lot of luck with your P5W - I thought you have binned it ages ago -lol !. I liked mine but it didn't like the 2x2GB gskill PQs I bought to run vista X64 so I bought dare I say it an Asus P5K deluxe. I have found it very flexible running with FSB settings way above 450 and the BIOS has the memory settings we all want in the P5W BIOS - so to make the most of it I ebayed the RAM for 4x1Gb Ballistix 8500C5 and am waiting for an E6850 to play with. I have high hopes to go up and beyond with this setup. The P5K Deluxe is a nice board with the usual few Asus badly placed slots etc but it really performs like no other I have used.
    Q6600 - L729A959
    VID1.2625 @3.72GHz (465x8) 1.4625v(BIOS)
    P5K Premium (0702 BIOS)
    Win7 Ultimate x64
    Ultima-90
    4x1GB Ballistix 8500C5 @ 1166 5-5-5-12 2.2v
    MSI 5770 Hawk 1030/1330 - 1.25v
    2 x Hitachi T7K500 320MB - Matrix RAID 0/1
    Hiper Type R 680w
  13. #5263
    Jul 2007
    Hey Everybody, I just wanted to say thanks for this thread. I'm about 1/8th of the way through it (man it's huge) and just wanted to thank everyone for the vast amount of information.
    So far I have been testing the board a lot. I knocked the Multi down to 6X and the Ram is only running at 750 (rated and tested for 800 successfully). I have gotten stable at about 350 FSB on my E6400, but 355 is always unsuccessful within 5 minutes. I have tried everything to get it stable at higher FSB frequency, but am stuck. I hope the answer is present in the last 7/8ths of this thread, but I figured I'd post and see if anyone had any ideas.
    Oh, and I have tried the suggestions available in the first post (HP3, SPD, etc).
    Bios: 2004
    Ram: GeIL 6400 Ultra
    Rev: 1.02G
    Thanks for the 200+ pages of information
  14. #5264
    Mar 2007
    North Yorkshire
    Quote Originally Posted by ae804 View Post
    Bios: 2004
    Rev: 1.02G
    To help more detail is required e.g your setup,psu etc and all your current Bios settings.
    Q6600 - L729A959
    Win7 Ultimate x64
    Ultima-90
    Hiper Type R 680w
  15. #5265
    Jul 2007
    United States
    Is it worth it to update the bios if you are running on 1707?
  16. #5266
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    Quote Originally Posted by wreckage View Post
    If everything is running fine, then NO.
    "You'll find happiness once you accept the inevitable or at least you won't be too pissed off" -- Me
    [SIGPIC][/SIGPIC]
  17. #5267
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    So nobody is using S-ATA DVD drive with this mobo?
    http://mato78.com - Finnish PC Hardware news & reviews
    BulldogPO @ Twitter
  18. #5268
    Mar 2007
    North Yorkshire
    Quote Originally Posted by BulldogPO View Post
    I bought a NEC AD-7170s a few month back cos I didn't want to use the IDE connections any more especially the Jmicron one. It runs very nicely connected to one of the Ich7 sata ports. Why do you ask?
    Q6600 - L729A959
    Win7 Ultimate x64
    Ultima-90
    Hiper Type R 680w
  19. #5269
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    Quote Originally Posted by sesdave View Post
    I have a NEC AD-7170s cos I didn't want to ise the IDE connections any more especially the Jmicron one. It runs very nicely connected to one of the Ich7 sata ports. Why do you ask?
    What port did you use for it?
    I have NEC AD-7173S.
    Bios says on boot:
    Master Drive: ATAPI Incompatible.
    Drives are recognised like this:
    1- master 320GB S-ATA Western Digital
    2- slave 320GB S-ATA Western Digital
    3- master: not found (not instaled)
    4- slave NEC AD-7173S
    NEC is found as master if I put it in S-ATA port 1.
    Nothing works on that weirdly placed S-ATA connector near CPU.
    I tried AHCI and IDE settings in bios and no matter what select, every time in post/boot I have to hit F1 to resume boot.
    BulldogPO @ Twitter
  20. #5270
    Mar 2007
    North Yorkshire
    Connect boot drive to RED sata port1- next drive to black sata port 3 beside RED port and DVD to second black sata port 4 below the first one. Disable Jmicron in BIOS if you arent using it. Set Sata to IDE in BIOS. U need to reinstall windows and drivers if u want to use AHCI mode.
    Q6600 - L729A959
    Win7 Ultimate x64
    Ultima-90
    Hiper Type R 680w
  21. #5271
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    That is jus like I did, boot drive is at red and second drive is at black and DVD rive is below that.
    And bios says something about master drive missing...
    DVD drive is recognised as master only if I put it in that red conector.
    BulldogPO @ Twitter
  22. #5272
    Mar 2007
    North Yorkshire
    Check you boot drive priority and sequence settings under boot in BIOS.Sound like its picking up the wrong SATA hard drive for boot.
    Q6600 - L729A959
    Win7 Ultimate x64
    Ultima-90
    Hiper Type R 680w
  23. #5273
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    It still boots Vista, it only says about that non present master drive and I have to press F1.
    But Vista´s device manager has exlamation mark on that NEC and it does not work.
    BulldogPO @ Twitter
  24. #5274
    Jan 2004
    uk
    an update, the xifi is moved and I also tried moving my pata drive from jmicron to the ICH7.
    Result is sound is clearer so the sound card move is beneficial but videos stil stutter very badly, I am backing up some stuff now and will hopefully be running XP on normal IDE mode within 24 hours.
  25. #5275
    Feb 2005
    Scandinavia
    I have the same problem after installing a IDE drive without that little plastic bit which indicates whether or not its set as slave or master...
Tags for this Thread
