XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems > Microsoft Windows
Reply
Old 06-14-2002, 02:26 PM   #1
Dramen
Dramen's Avatar
Adding Linux to your W2k/XP Boot Menu.
This is how to dual boot W2k or XP & Linux and add Linux to W2k/XP Boot Menu:
1. Install W2k or XP. Partition part of it for W2k/XP (either NTFS or FAT32 will work).
2. Install Linux (any distribution).
You have to follow the following two steps exactly:
a. When asked where to install LILO, DO NOT install LILO in the MBR (Master Boot Record), since this will overwrite Windows OS Loader and you may have to reinstall W2k/XP. Instead, install LILO in other partition (superblock of the root partition of Linux drive).
b. Create a Linux boot disk. For now, this will be your only way of booting up to Linux.
3. After you have finished installing Linux, boot up to Linux (use the Linux boot disk).
4. Dump Linux boot sector to a file. Type the following:
dd if=/dev/hda2 of=/bootsect.lnx bs=512 count=1
If your linux boot partition is not in the hda2 partition, change if=/dev/hda2 accordingly (use df to get the correct partition).
For example, if your linux boot partition is in hda3, change the command to:
dd if=/dev/hda3 of=/bootsect.lnx bs=512 count=1
Once you run this command, you will have bootsect.lnx file in "/" (root) directory.
5. Mount a DOS formatted disk. Type:
mount -t msdos /dev/fd0 /mnt
6. Copy the bootsect.lnx file to the diskette:
cp /bootsect.lnx /mnt
7. Boot up to W2k/XP (by removing the Linux boot disk).
8. After booting up to W2k/XP, insert the DOS disk, and copy the file A:\bootsect.lnx to C:\ drive.
9. Edit C:\boot.ini. Usually this file is not visible. Start notepad, then open file C:\boot.ini. Add the following line to the bottom of the file:
C:\BOOTSECT.LNX="Linux"
10. Now reboot, and you will have the option to boot either to Windows or Linux.
Below is my Boot.ini, which is set up to boot XP, XP cmd console, Mandrake and RedHat.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(3)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Micro soft XP Professional"
C:\CMDCONS\BOOTSECT.DAT="Microsoft Recovery Console" /cmdcons
C:\BOOTSECT.LNX="RedHat Linux"
C:\BOOTSECT.LUX="Mandrake Linux"
Dramen is offline   Reply With Quote
Old 10-18-2002, 08:07 PM   #2
IFMU
Administrator
IFMU's Avatar
Send a message via ICQ to IFMU Send a message via AIM to IFMU Send a message via MSN to IFMU Send a message via Yahoo to IFMU
To bad that makes absolutely no sense what-so-ever to the linux newb that I am.
__________________
Please donate to Xtreme Systems!
Give up some help to the best site on the web!
IFMU is online now   Reply With Quote
Old 10-18-2002, 08:19 PM   #3
Kurupt
Guest
Posts: n/a
Well I just got linux "redhat 7.2" talk about a fun little day I had trying to get the internet settings working =/
-chris
Old 04-08-2003, 03:47 AM   #4
dropadrop
dropadrop's Avatar
Great advice! Too bad I did'nt find it earlier...
I have redhat running on my server, but it's not dualboot, and I did'nt have the need to study the boot up. I installed redhat next to win2k on my main machine, and managed to completly mess up the mbr. The next time I did the floppy thing, but used a very bad floppy that would never boot...
dropadrop is offline   Reply With Quote
Old 01-05-2004, 12:30 AM   #5
piercedandtatto
piercedandtatto's Avatar
Send a message via AIM to piercedandtatto
Im already duel booting xp and win2k3 enterprise....will this work if i tried a tripple boot? Been thinking about playing around a little with linux but i dont want to get rid of either of my other operating systems
__________________
E8400@ 4.0
SUNBEAM|CR-CCTF
ASUS P5Q PRO
4GB G-Skill
MSI HD 4850
Vista 64bit
piercedandtatto is offline   Reply With Quote
Old 01-05-2004, 06:03 AM   #6
sjohnson
X. I. P.
sjohnson's Avatar
The same process will work for triple booting.
At one point, I've had DOS 6.2, WFW, Win98, Win2k and Linux all bootable on the same rig.
This method takes the most time but is the "safest" way to multi-boot for someone whose primary O/S is windows - because it doesn't mess with the windows way of booting.
__________________
The plural of "anecdote" is not "data."
sjohnson is offline   Reply With Quote
Old 02-28-2004, 02:58 PM   #7
Darkfold
Darkfold's Avatar
Grub seems to be good at holding my boot options sane. Got redhat 8, suse 9 and xp all loading from it without any trouble (on a laptop)
__________________
Probably not a good idea that...
Darkfold is offline   Reply With Quote
Old 01-28-2005, 06:19 AM   #8
gkirilov
question.
i HAD a dual boot - winXP and Linux. But. What happens if you re-install WIN XP. The MBR is erased and no Linux in the boot menu.
Any ideas? /exept using third party tools to have a boot menu/
gkirilov is offline   Reply With Quote
Old 01-28-2005, 07:50 AM   #9
smokey
smokey's Avatar
Send a message via AIM to smokey Send a message via Yahoo to smokey
Umm... if you follow the guide, then you wouldn't have that problem. You are currently somewhere between steps 1 and 2. Continue as usual. Wash, Rinse, Repeat.
__________________
"Usenet is like a herd of performing elephants with diarrhea - massive, difficult to redirect, awe-inspiring, entertaining, and a source of mind-boggling amounts of excrement when you least expect it." - Gene Spafford, 1992
"Black Holes are where god divided by zero." Steven Wright, 1995
"Arguing on the Internet is like being in the Special Olympics... even if you win, you're still retarded." - From an Online Forum
smokey is offline   Reply With Quote
Old 05-20-2006, 08:34 PM   #10
Eliatamby
Another way if you have mulitple disks is to make your linux disk your primary boot device. Install grub/lilo on there, and set up the config as needed. Then, if you need to boot to Windows with linux removed, set the Windows disk as the primary boot device
Eliatamby is offline   Reply With Quote
Old 06-15-2006, 10:26 AM   #11
2Fast4U2
Keep in mind, this install procedure will NOT work with Vista!
Vista's new bootloader (BCD/boot.mgr) will disappear after installing Grub/Lilo and a repair will be needed to get Vista back which will subsequently make Grub/lilo disappear................
A new bootloader will be released soon by Pro One which will make this easier to do, but, for now the easiest method is to boot Linux from a floppy..............
2Fast4U2 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
