E8400@3.6ghz 1.11v |Asus P5E3 deluxe bios 1001| 2 giga Cellshock DDR3 12800@1696mhz|Samsung Syncmaster 2232BW 22' | Asus 8800 GTS² 512 TOP|Western digital sata 500 SE16 | Blu Ray LG GGW-H20LRB| Creative X-fi platinum|Nexus 600W | case Coolermaster 1000 "Storm"
Xeon E3110@3.6ghz 1.15v|Asus P5K premium "blackpearl" bios 503|2 gigas Cellshock DDR2 8500 |Twintech 9600 GT|nec 1970 GX|Gigabyte 3D aurora case
E8400(Q804A249) valid@ 4.8 ghz 1.56v
Xeon E3110 (Q746A534)valid@ 4.79 ghz 1.59v real bios AIR /superpi 1m@9.968 .. under vista
My Ibanez 540S " Saber "overclocked with Di Marzio and Sperzel
My cousin on drums Hi Brian !
yes webwilliOriginally Posted by webwilli
without success ,maybe my chip cause issues ?
My bios is 0065
CPU is a A-Sample ....
Stepping 1
I think for this CPU it´s a verry good result
CB
i thought boards are sopposed to go over 400 fsb. and btw what volts are you using on that chip ,type of cooling temps? .i might get the 6400's
Asus p5n-e sli
E6300 stock heatsink
2 x 1 ddr667 supertalent 5-5-5-13 2.1
X1800xt 256mb
Enermax liberty 620
nice results still
Thank you all
I'm satisfied with these results and that chip though I have some issues with usb devices .
Would be nice to break fsb wall , have to see what's wrong
My rig is very stable at 3.00 ghz and it was my goal
Very found of G skill
tvdang7 saidthis bios ( 0065 ) allows 450fsb ,maybe should I relax G skill timingsi thought boards are sopposed to go over 400 fsb. and btw what volts are you using on that chip ,type of cooling temps? .i might get the 6400's
Vcore is 1.4 V and temp 35° idle with my Noctua NH U12
Have to find some extra fan for NB ( 46° mb temp idle ) as FCG told me
VMCH is 1.65V
Vdimm is 2.1V
The case is a gigabyte 3d aurora with antec smartpower 2.0 500 Watts and my XFX 7900 GT is modded@1.5V (520/1500@660/1700 stable 45° load with VF900 Zalman - 700/1700 cause issues under 3Dmark 06
Can't boot to windows , I only have the loading screen and after system freeze and rebootsWebwilli said what happen when you set a higher fsb?
By the way Webwilli , are you able to lower multi with your bios ? Mine is locked to x 8 ,that's my big pb cos I'd have tried to go with x7 and a higher fsb
3ghz is great. i want this or the 6300.
Asus p5n-e sli
X1800xt 256mb
Enermax liberty 620
Yes ,nice chip ! see also Webwilli results with his 6300 ..Originally Posted by tvdang7
I booted to windows at 3.2 ghz ( 8x400 fsb ) with Vcore 1.5V but got issues with benchs
Really need to have more cooling on Nb ?
Have you disabled Hyper-Transport, and hten tried raising the FSB?
Can you drop the Multi's and see if the cpu boots at a Higher FSB?
CPU : E8400
Motherboard : Abit IP-35 Pro
Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
Graphics Card : Palit HD4870 Dual Sonic
Display : Dell E228WFP
Storage & OS : 1TB | Windows 7 64bit
Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
Case : Coolermaster ATCS 840
PSU : OCZ GamerXtreme 700W
Assume you mean hyper threading? Which conroes don't have anyways and you can only drop multi's on the x6800 chips so far as i know. Sadly intel haven't followed AMD's good idea to allow anyone to drop multipliers as much as they wantOriginally Posted by goldenfrag
My chip is locked at x 8 can't lower to x 7 neither x 6Originally Posted by goldenfrag
FCG 'advice is to change bios and try 0502 - Does anybody know if it solves that pb ?
What do you mean by HTT ? I used to care about that with AMD rig ...
Yes it is with 4Mo L2 but my multi is locked at x 8Originally Posted by Sir-Gillespie
Don't know why ( should try another bios )
is yours too ?
They should be unlocked downwards, so it has to be some sort of bios-problem
wait the 6400 has a version with 4 mb l2 cache?
Asus p5n-e sli
X1800xt 256mb
Enermax liberty 620
The 6400ES has 4mb, the retail version will have 2mb
very nice that you can actually hit 3 with this, what kind of cooling did you use? only thing i didnt like is hw it gets pwned by the 6600 although its still a great dual core
Intel Core 2 Duo T5500
2GB DDR2 667
120GB 5400 HD
Intel GMA 950
XP MCE
(^Laptop)
YesOriginally Posted by ZeroX
Air cooling with Noctua NH U12 which fits fine , but you only have one way to do that on that board because of the height of the chipsetOriginally Posted by kais
See the pic in my previous post
Hey mate, which G.Skill is that? Presumably it's PC6400 but is it ZX or HZ? Or something else entirely?
Conroe E6300 ES
2x1gb Ballistix PC8000
Asus P5W DH Deluxe (1705)
Manli Geforce 7950GT 512mb
Hiper Type-R 480w
Samsung SP250
"What did the quantam duck say?" "Quark Quark"
It is HZ with micron D9Originally Posted by don_vercetti
Darn. I ordered some ZX over the weekend. Hopefully it'll come close to that.
Conroe E6300 ES
Hiper Type-R 480w
Samsung SP250
do yall think of this ddr667 ram
http://www.newegg.com/Product/Produc...82E16820231051
im getting it in a trade . i know many prefer ddr800 do give me your opinion. i want to pair it with this cpu or the 6300
Asus p5n-e sli
X1800xt 256mb
Enermax liberty 620
