Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 60
Thread: Help with vdimm & vcore mods for ASUS M2N-SLI Deluxe, please.
  1. #26
    Jun 2006
    Israel, Middle East.
    Hey, I've got a question, which RAM Do you use for your rig? I'm considering to buy a Asus M2N-E for my AM2 rig and a Corsair TWIN2X2048-6400C4 pair of sticks [800mhz, 1gb * 2 sticks] but im reallllly afraid of compatability issues... and I won't even be able to RMA it if it wont work, this is a one try thing........ can't affored to go wrong, so any advice would be appreciated, i'd like to stay within the 250$ budget range for RAM too.
    -Jo.
  2. #27
    Xtreme X.I.P.
    Dec 2003
    So I finally got around to vdimm-modding my board. There's vcore-mod left to be done, but that will happen a bit later... Just wanted to drop by and add couple photos here:
    I have only started testing it, but so far got some nice results with 2.70v Thanks again for help, guys
  3. #28
    Dec 2002
    Portugal (EU)
    Nice thread
    I was wondering what should be the resistance values I should have to have my M2N-E (max 1.95v vdimm) offer UP to 2.3v
    Thanks in advance
    Ever stop to think, and forget to start again?
  4. #29
    Xtreme X.I.P.
    Dec 2003
    Quote Originally Posted by Rudzer
    Nice thread
    Thanks in advance
    Well, you can use exactly the same 20k trimmer. In this very thread ^don.k's^ did this vmod on his M2N-E. Just preset it at 20k before soldering in and then reduce resistance to raise volts.
  5. #30
    Sep 2005
    Belgrade, Serbia
    persivore's pictures disapier? Someone saved them maybe? if someone have save it, pliz attach it?
  6. #31
    Sep 2005
    Slovakia
    hi guys, can you please tell me to what you have connected the other wire from the resistor? i cant see it from the pictures.
    And second note, i cannot boot with vdimm higher than 2.4V but its stable at 2.3V ad ddr2 520 (Corsair ddr2 667 2*1GB ram)
    anyone with same problem?
    My Rig X6 1055T|Crosshair IV Formula|8600GT|2x2024MB@1800|436GB storage
  7. #32
    Sep 2005
    Belgrade, Serbia
    Quote Originally Posted by bachus_anonym
    Soldering pad on the top dosn't working, i will try pin7 later. For the M2N-E owners, the vcore spot doesn't exist, there is only 3 phase not 4 phase like on SLI version, the 4th choke doesn't exist so it can not be the measuring point. Use 3th choke.
  8. #33
    Xtreme X.I.P.
    Dec 2003
    Quote Originally Posted by Misko82
    I have not done vcore mod myself yet, but have you also looked at the 1st pic that ^don.k's^ added in post #22. The top soldering pad I marked on my pic was the one I was not sure about. I was waiting for someone to confirm that since ^don.k's^ marked the very very top one. Now,that I think about it, the soldering pad he marked is the correct one...
  9. #34
    Sep 2005
    Belgrade, Serbia
    I tried and nothing happend:
  10. #35
    Sep 2006
    hello
    i was wondering if a 50k resistror wud work. so if i set the voltage to jus say 1.8v, the acctual voltage wud be sumthing like 1.95v depending on the type of resisitor used. can sum 1 confirm plz. THIS ONE: http://www.maplin.co.uk/Module.aspx?...50k%20&doy=2m9
    or wud this one be better as its 22K and wud this work. http://www.maplin.co.uk/Module.aspx?...ia=22k&doy=2m9
    and Wat bout this 25K: http://www.maplin.co.uk/Module.aspx?...ia=22k&doy=2m9
    plz reply
    thankz
  11. #36
    Sep 2006
    hello
    i was wondering if a 50k VR wud work. and if i set settings in the bios to 1.8v, wud the actual voltage be like 1.95v depending on the resistor i use.
    wud this 50K work: http://www.maplin.co.uk/Module.aspx?...2201&criteria=
    or this 25k: http://www.maplin.co.uk/Module.aspx?...6499&criteria=
    or what about this 22k
    which one s the best. i wud like to have a min of AT LEAST 1.9v becoz that is my rams rating
  12. #37
    Sep 2005
    Belgrade, Serbia
    Here is correct spot for vcore mod:
    And the reading spot for vcore is also bad, the another leg of choke is the right one (Asus M2N-E)
  13. #38
    Mar 2005
    Spain
    Sorry, i didnt tested the vcore mod myself, i marked the points that were the same. I think my error was that i marked pin #8, now that attached pics of persivore has gone, i dont know exactly. My fault
    Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
  14. #39
    Sep 2006
    vdimm mod gone bad
    i did the vdimm mod earlier today and it screwed thing up worse than before. i did everything as had been metioned in the thread and all i got was random crashes, any ideas
    thanks
    adam
  15. #40
    Sep 2005
    Belgrade, Serbia
    hmmmm, vdrop is 0.04V in idle-load amp (if I set 1.75V vcore in load I will get ~1.71V, measured by voltmeter), any suggestion how to resolve this?
    p.s. Power supply isn't responsable, 12.3V is knocked in case idle-load, for PS, idle load is the same (OCZ Power Stream).
  16. #41
    Sep 2006
    South-Western Australia
    did the vdimm mod quite a while ago with a bit of help from ^don.k's^ and i have just found my camera (moving house) so ive taken a pic of the finished product works great btw
    system specs are:
    athlon X2 4200
    2gig of supertalent pc6400 ram @ 4-3-4-8 800mhz 2.3v
    powercolor x1900xt 512mb
    and of course the asus M2N-E, bios flashed to 0304
    Hiper type R 580w modular PSU
    bunch of hard drives and a dvd burner
  17. #42
    Dec 2005
    Hello folks... I'm trying to set up a 1gb stick from Advance Modules on a M2N-E but it won't even post, "long beep + short beeps", at first I thought was vga related but reading about the mobo I now think its the vdimm too low to boot. Unfortunately I don't have another stick around for testing...
    I thought about just raising voltage a notch to see if it boots (supposedly the latest bios helps with memory stability), I just want to update the bios and see if it handles the memory at default (customer board, cant send it modded)
    Would a "temporary mod" work? Is it possible to do it without soldering the chip leg? (remembering it would be only for a few minutes)
    Last minute: what resistance necessary to get around 2.1-2.2V ?
  18. #43
    Jun 2006
    Spain
    i have the same question as nobre,
    what resistance is recessary for 2,2v more or less?
    Parkie, what resistance did you use for getting that 2.3V?
  19. #44
    Jun 2006
    Spain
    ok, sorry, my answer is here
  20. #45
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    Hi, the Vcore point won't work here, don't know why.. Should i try it on the missing cap?
    Vdimm works fine!
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
  21. #46
    Aug 2003
    Germany
    Quote Originally Posted by funkflix
    Vdimm works fine!
    On the cap i can't measure anything too. Any ideas out there? I really need it, bcs. i have some strange Vcore "problems" with new 65nm Singlecores.
    Thanks a lot in advance.
    (If u need more pics, just say it)
  22. #47
    Sep 2005
    Slovakia
    the place for Vcore IS exatly vhere the pix shows it, i had that board and it was measurable at that point. Just place one leg to ground and anothe on the base of that coil, but be carefull to touch the coil, coz near the end its covered by some insulation crap...
  23. #48
    Aug 2003
    Germany
    Thx, but normally i know how to mesure.
    But i can't get anything from this leg, don't know why.. Vdimm mesuring works fine. Already tried to get the insulation off the leg, but there was none.
    Will try it one more time, but i think it's pointless.
  24. #49
    symphy
    Guest
    Try to measure the voltage at the backside of the board; some coils are really very good insulated...
    I bet that will work
  25. #50
    Aug 2003
    Germany
    Quote Originally Posted by symphy
    Good idea, will try to get to the backside.
