XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 08-01-2003, 08:24 PM   #1
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
Thumbs up A very simple and Perfect Solution to using Waterblocks on the NB of a P4 Board
loooking over bladerunners website (the master of watercooling ) I came across this picture, that simply blew me away for it's simplicity and effectiveness for using waterblocks on the northbridge of a P4 Chipset with them little hook things...
soooo I promptly emaild Bladerunner to ask for his permission to post this Pic elsewhere, in which he gladly obliged and gave me the green light to post his work here on this post.
(thanks blade)
I am definatly redoing my solution, as mine was alittle more difficult to use for the sheer size of my solution.
I love this idea so much, I just had to post it here, and hopefully other watercooling guys can appreciate this solution as much as I did
__________________
Kunaak is offline   Reply With Quote
Old 08-01-2003, 09:53 PM   #2
sjohnson
X. I. P.
sjohnson's Avatar
Nice! Simple, effective and puts those hooks to good use. :thumbsup: to bladrunner for the idea and reposting generosity!
__________________
The plural of "anecdote" is not "data."
sjohnson is offline   Reply With Quote
Old 08-02-2003, 12:16 AM   #3
Teus
Teus's Avatar
Send a message via MSN to Teus
where can I get that kind of hooks, or what is it normally used for?
Teus is offline   Reply With Quote
Old 08-02-2003, 12:54 AM   #4
Kunaak
Kunaak's Avatar
you just find a solid small piece of metal and a bolt and nut.
the rest is pretty simple
__________________
Old 08-02-2003, 04:01 AM   #5
FragMagnet
That one looks like a mounting plate from an add-in card ? Old NIC, ISA sound card, etc. should do the job.
__________________
EVGA X58 Classified 760
W3520 @ 4410 HT 24/7
Lapped TRUE 2x 110 CFM Scythe p-p
6Gb Corsair XMS3 1600 7-7-7-20-1
XFX 5870 1Gb
PC Power and Cooling 750 Crossfire edition
CoolerMaster 590
XtremeSystems: Welcome to the Prommie Land !
FragMagnet is offline   Reply With Quote
Old 08-02-2003, 06:08 AM   #6
LardArse
Moderator
LardArse's Avatar
I've come up with a few nice working solutions too.
A screw, aluminum rod and brass rod cut and bent to shape.
2 aluminum bars and screws and nuts and a spring for centralized pressure.
The second method doesn't work on the P4P800 due to the postion of a cap so I used brass rod extensions.
Anyways Kunaak, I read your thread over at overclockers.com, what happened to that vapo on your NB
I also went over to Intel recently and am chilling my NB with a 172 watt peltier cooled with -36c liquid. Seems we are always up to the same mischief, first the dry ice and now the NB cooling
LardArse is offline   Reply With Quote
Old 08-02-2003, 06:16 AM   #7
Marci
XIP - thisoneisonus.org
Marci's Avatar
Zipties. That's what we always use.
Marci is offline   Reply With Quote
Old 08-02-2003, 04:22 PM   #8
Kunaak
Kunaak's Avatar
My vapo on the NB is just a short term solution for high OC sessions. day to day use is just plain old watercooling, to ease my Power bills and save on space.
my full benchmarking set up is pretty insane.
the R404 vapochill goes on the videocard, my waterchiller does -35C, that cools the NB, with a Prometeia on the CPU.
but my day to day is alot smaller, just watercooled videocard and NG, with a prometeia.
nothing fancy, but it's nice on my wallet, and maintains high OC's well, been running 3.6 ghz for a week now.
I was running 3.7 ghz before, then I started to find, I was crashing out of games too much.
3.6 seems to be the sweet spot for 1.575 volts.
heres my NB cooling solution that I came up with.
but I definatly like Blades better.
__________________
Old 08-02-2003, 05:46 PM   #9
NyCUndaGrounD
NyCUndaGrounD's Avatar
Send a message via ICQ to NyCUndaGrounD Send a message via AIM to NyCUndaGrounD
This pic looks like a playground swing!
__________________
E6600 SL9S8 Malay
ASUS P5W64( no mods )
Mushkin (2 x 1GB) XP2-6400
ATI x850xt
2 x 150GB WD Raptor RAID
Thermalright Ultra-120
SilverStone ST56ZF 560W
NyCUndaGrounD is offline   Reply With Quote
Old 08-02-2003, 06:08 PM   #10
Nohto
Nohto's Avatar
What ratio of Anti-freezze to water are you using?
Nohto is offline   Reply With Quote
Old 08-02-2003, 08:25 PM   #11
LardArse
Moderator
LardArse's Avatar
I have about 15L of ethanol, 2L of antifreeze, and about 12L of water in there.
Old 08-02-2003, 09:16 PM   #12
Kunaak
Kunaak's Avatar
90% Winshield washing fluid and 10% acetone here
__________________
Old 08-02-2003, 10:53 PM   #13
JeffPH
JeffPH's Avatar
Send a message via Yahoo to JeffPH
nice guys
this will help a lot of peeps
__________________
JeffPH is offline   Reply With Quote
Old 08-05-2003, 03:33 PM   #14
RaZoR
Danger Den announced yesterday, (8/4), a new NB water block for some 875p/865p mobos. Pictures on the DD site. Very much like Kunaak's soulution, but integrated into the block.
__________________
Abit IC7-G P4c 3.0 GHz @3.3 1:1 ratio
Audigy 2 sc, GF FX 5900 Ultra vc
2 X 512mb Mushkin Level 2 PC3500
2 X WD Raptor's Raid 0
Maxtor 80gb HD IDE 1
Lite-On DVD & 48/24/48 CDRW IDE 2
RaZoR is offline   Reply With Quote
Old 08-06-2003, 05:47 AM   #15
SpicyHuevos
Damn i thought i was the watercooling masta!
SpicyHuevos is offline   Reply With Quote
Old 08-06-2003, 06:08 AM   #16
CCW
Guest
Posts: n/a
Seems Im not the only one recently to be getting permission to post his pics places! He does some awesome stuff.
Craig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
