XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 02-16-2004, 06:32 AM   #1
DaBit
DaBit's Avatar
Send a message via ICQ to DaBit
Vacuum as an insulator.
We are all doing a tremendous amount of effort to insulate our evaporators with Armaflex, expanding foam, whatever.
But the best insulator ever is still a vacuum. With all the CNC machines around here, did anyone ever think about making a stainless steel 'shell' around the evap, braze it on, and pull a deep vacuum in it? With the tight tolerances a CNC machine can maintain, making such a shell sounds like a trivial task.
Would this work?
__________________
My -100C R507/R1150 cascade
DaBit is offline   Reply With Quote
Old 02-16-2004, 08:33 AM   #2
Ragnarok
Ragnarok's Avatar
Send a message via ICQ to Ragnarok
umm the surface of the evaporator would have be exposed, and hence u cannot completely cover it ?... am I missing something here?
Ragnarok is offline   Reply With Quote
Old 02-16-2004, 08:47 AM   #3
nas
humm , it will be braze to the evap = it will cool aswell
nas is offline   Reply With Quote
Old 02-16-2004, 09:01 AM   #4
iboomalot
iboomalot's Avatar
this might be a better solution
http://www.aerogel.com/products.htm
__________________
i7 920 @4.305 ghz (205*21 HT on) Prime stable@ 1.312v (Batch# 3844A717) your results may vary
i7 920 @4.410 ghz (210*21 HT on) 1hr Prime stable@ 1.39v (Batch# 3844A717) could push more but no reason too
Enzotech Heat Killer SCW-REV.A (very nice block 73c / 79c per above voltages)
GA-EX58-UD4P (Bios ????),, 6GB- OCZ3P1600LV6GK (7-7-7-20 @1640 mhz) 1:1
XFX-5870 with Swiftech nickel block
Water Cooling - TFC X-Changer 480 and 6-Scythe SFF21E fans @1000 rpm , Vario 655
Raid 0 velociraptors 600GB,, ZM1000-HP (powerfull and silent)
Mitsubishi 22" CRT
(old school ,,no input lag , no slow response times , true color reproduction & blacker blacks) its deep but so what
iboomalot is offline   Reply With Quote
Old 02-16-2004, 08:37 PM   #5
tennvols_69
Send a message via MSN to tennvols_69 Send a message via Yahoo to tennvols_69
wonder whereyou could get someof that from? also a vacumm would work greatbut you couldnt braze it to theblock you wouldhave to create a seal of some kind that would sealto yhr mobo
__________________
DFI NF4 Ultra D/3800 x2 @ 2.5ghz/2x512 BH-5/ EVGA 7800 GT /OCZ 600W PowerStream
tennvols_69 is offline   Reply With Quote
Old 02-16-2004, 09:46 PM   #6
chilly1
HVAC/R Engineer
chilly1's Avatar
A thermos jug is made entirely out of glass it does connect with the outside but still conducts little heat. If nothing at all wouldnt this reduce the area we need to insulate and also make our evaps run cooler due to the reduced heat gain... And how about a copper box, it only needs to be sturdy enough to support itself...
And maybe a neoprene gasket seal like an o ring and nylon bolts to hold it together,,, and a small vacume pump to maintain the vacume or maybe an inert gas at a partial atmosphere?
__________________
heatware
chilly1 is offline   Reply With Quote
Old 02-17-2004, 02:17 AM   #7
DaBit
DaBit's Avatar
To use vacuum as a good insulator you need a pretty decent vacuum (in the range of 1-10 microns).
And sure, stainless steel conducts some heat, but not that much. Maybe plastics could be used.
__________________
Old 02-17-2004, 03:29 AM   #8
G H Z
Champion
G H Z's Avatar
When your building the third stage of your -175 cascade which runs Argon, just build a sealed box and pressurize it with some Agon as well.
That might be easier than pulling and maintaining that much Vaccum. It's what they fill the expensive double pane windows with.
G H Z is offline   Reply With Quote
Old 02-17-2004, 04:19 AM   #9
Tweaked!
Guest
Posts: n/a
Actually I'd recommend filling the void with Nitrogen, after trying to pull down to a vacuum. You'd have to use something with a little bit of wall thickness to it though if you're wanting to leave it in a slight vacuum.
Old 02-17-2004, 04:21 AM   #10
Tom Holck
Moderator
Tom Holck's Avatar
Arrow Insulation
When I use my -112 C Cascade the hole MOB is frozen. Even the Ram is about -2 degree. The cooling is going in the cubber on the MOB.
The idea is good, we have to bouild the hole MOB in a sealed box with some gas or with dry air.
The problem is also on the AGP and the Radeon XT also condensation here from the GPU cooling.
__________________
Best OC Regards
Tom Holck
Denmark
The Homeland of nVentiv and Asetek
Tom Holck is online now   Reply With Quote
Old 02-17-2004, 04:24 AM   #11
DaBit
DaBit's Avatar
I already use the sealed box idea for ages. Works fine so far. But of course you want to reduce heat leakage into the evap as much as possible. After all it's the cpu which needs to get cold, not the mainboard.
__________________
Old 02-17-2004, 06:04 PM   #12
chilly1
HVAC/R Engineer
chilly1's Avatar
I have a solution for this problem I will post pictures as soon as we finish testing... The problem with a vacume on the whole mb is that we could have heat build up on other components on the mobo.
__________________
heatware
Old 02-19-2004, 03:30 PM   #13
pythagoras
Here to help
pythagoras's Avatar
If you used a modified version of this cpu enclosure, you could pull a vacuum in there:
Regards
John.
(thats a 1998 kryotech cpu enclosure BTW)
pythagoras is offline   Reply With Quote
Old 02-19-2004, 04:11 PM   #14
DaBit
DaBit's Avatar
I was more considering the use of a vacuum as a replacement for Armaflex, neoprene, etc.
A small layer of reflective aluminium (could be aluminium foil) and a thin layer of vacuum should work much better than a thick layer of insulation. The dominating heat transfer modes are still conduction and convection, so if you can stop that by pulling a vacuum, you are doing a good job already. Aluminium foil reduces heat transfer by radiation already quite a bit.
It could be doable to put this straight into the evaporator design. For the material: stainless steel still seems the most practical material. It can be joined with copper, it is machineable, and it's heat conduction is fairly low. It also can maintain the vacuum, something rubber rings cannot.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
