Results 1 to 3 of 3
Thread: Best mix for coolant ?
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I've been running water/anitfreez mix in my system and I'm currious if a mixture alcohol and antifreez would offer any cooling benifit.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Unoriginal Macho Energy
    Dec 2002
    For normal H20 cooling (no pelts, etc.) the best liquid is water. Antifreeze will actually raise your temps - very bad at heat transfer. Anyway, I would only use antifreeze for corrosion protection (if you have copper and aluminum) but if you run all copper, water and water wetter or purple ice or Hy-per Lube would be best.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Thanks for your advice, I found some other forum posts that suggest the same thing. Defiently alcohol is out from what I read.
    I have to make some of my lines longer and just wanted some advice b4 refilling.
