Results 1 to 20 of 20
Thread: duron 1300Mhz unlock.
    Aug 2002
    Belgium (Aarschot)
    If I remember correctly, it isn't enough to just connect the l1's.
    do I have to change the multiplier 13 first on the cpu? or does just connecting the l1's does the trick?
    thnx in advance
    You will find as you look back upon your life that the moments when you have truly lived are the moments when you have done things in the spirit of love !
    I am lame
    Dec 2001
    Yeah, all you have to do is connect the L1 bridges.
    Aug 2002
    Belgium (Aarschot)
    nope I have to disagree. it doesn't work. I had to maually change the multiplier I changed it to 11.5 by following the athlon xp guide. afther that I had to connect the l1's .
    actually the same method like the xp2100+
    everything works like a charm now
    Xtreme Cruncher
    Aug 2002
    Michigan
    they r all the same(except the 2200), u just have 2 connect the L1's and that will unlock it so u can change the multi... if its not unlocked the u cant change the multi first..
    Aug 2002
    Belgium (Aarschot)
    seems like you guy's don't get it. most people have trouble with cpu's with a 13 multiplier like this one because of bios/motherboard incompatibility.
    so the usual unlock doesn't work. I had to lower the multiplier first on the cpu itself by altering the bridges config, when I did that, the unlock worked. but befor that it wouldn't work. my pc somethims even refused to post.
    but everything is solved now.
    Xtreme Cruncher
    Aug 2002
    Michigan
    ahh i see what ur sayin but i cant say i've ever heard of that problem b4.. glad u got it 2 work.
    Aug 2002
    Belgium (Aarschot)
    thnx
    I am lame
    Dec 2001
    Whoops. Didn't get it at first I guess. Sry.
    Glad you got it running.:thumbsup:
    Aug 2002
    Belgium (Aarschot)
    hehe, also thnx to you.
    I will get to push it some more when I got my corsair xms3200 from ctgilles. previously it was mine but we kind of swapped our systems
    I will borrow that stick to see how a duron performs with a +200Mhz fsb :smileysex
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    I've had the same problem as well. I didn't change the multiplier on my Duron 1.3 to 11.5x like ripper did, because I didn't know how to cut the bridges.
    Duron's and 2100+'s must be changed manually to a diff. multiplier, as well as the L1 unlocking.
    Please before you post know 100% what you have to do. kthx.
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Aug 2002
    Belgium (Aarschot)
    I used an old at powersupply, I have used 2 wires to connect to the 12v and wrapped the other side around 2 needles. so I blow the bridges by short ciquit them. It looks like it's done in the factory
    Jun 2002
    OMG! Now how about that for an idea! Holy crap!
    Aug 2002
    Belgium (Aarschot)
    well, the idea is not new you know
    I read about many users who did this. I also did this before on my thunderbird 1400 and my duron 600 so I knew it worked without a big risk
    I avtuall think that If I would have to return my cpu for warranty if it dies, they actually would not see it and give me a new one
    Jun 2002
    Yeah that's leet man! I'm gonna do that if ever needed for sure!
    I am lame
    Dec 2001
    Uhh. not all durons have to be unlocked in that manner. I have 2 older ones here that only have to have the L1's connected.
    So, I could regard you to do the same. thx.
    Aug 2002
    Belgium (Aarschot)
    I stated that I used an 1300 all cpu's with a 13 multiplier suffer that proble:
    so actually you have to voit their warranty bu cutting other bridges
    Overclocking Guru
    May 2002
    SoCal, USA
    All you need to do is the wire trick on the the pins, then connect the L1s and you should have an Unlocked 1300.
    OPP
  18. #18
    Jun 2002
    Duron 1.3s? I don't think so. The reason I said that was this was a specific case (cus of the 13x mult), which is why he asked.
    In any case, let's not bicker.
  19. #19
    Aug 2002
    Belgium (Aarschot)
    OPP
    argh, darn. IF I knew this earlier I didn't had to void my warranty by cutting those bridges
  20. #20
    Overclocking Guru
    May 2002
    SoCal, USA
