Graphic card
gpu cooling Prommy M2 @ R507
highest gpu oc so far: 350
memory cooling: nothing, prommy is keeping it cool enough
temp of water/gas: -79
highest memory oc so far (w / wo artifacts) 280 wo: 258
vgpu: upto 2.8
vddr: upto 3.8
vref: upto 3.5
mods(describe the mods you did): Vddq, both Vgpu mods
highest score(madmark link):
highest score(futuremark link): 9605 (http://service.futuremark.com/compare?2k1=7444345)
CPU
cpu: AMD A64 3000+
cpu oc: 2430 Mhz
cpu cooling:AMD A64 Boxed air coolor
vcore: 1.650
Main board
mainboard: ASUS K8V Deluxe
fsb oc: 243 Mhz
chipset timings (cpu interface enabled/disabled for example): N/A
nb cooling: original ASUS heatsink
sb cooling: N/A
mosfet cooling: N/A
chipset voltage: 2.6
Memory
memory: Corsair XMS3200LL
memory oc: 480 Mhz
memory timings: 5-2-2-2
memory cooling: N/A
memory voltage: 3.0V
PSU
12v: 12.05V
5v: 5.1V
3.3v: 3.8V
Software
operating system: Windows XP Pro
sp: SP1a
driver: 3.08
ocing utility: ClockGen / SiS Util
Temps
roomtemp: ~20c
casetemp: no case
cpu temp: ~40c idle; ~50c load
Pictures
Other comments
Card died once and came back alive :?
