Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: folding has slowed
    Oct 2003
    Albuquerque,NM
    folding has slowed
    i use to fold at a decent speed. now it takes me a long time to finish the 500 projects. heres what happened i was folding a project that was 2500 almost done then it started a new project ever since then my folding has been going horridably slow any ideas how to speed it back up?
    May 2003
    Re: folding has slowed
    Are you using any switches (-forceasm, -forceSSE, -advmethods, etc)?
    If you aren't, run the console/gui with -forceasm -advmethods for client 3.x, or -forceSSE -advmethods for client 4.x. Just a warning, it will push your computer harder, so if your computer is unstable, it may crash and you may need to remove -forceasm. If your computer is stable, it will help your production quite a bit.
    Oct 2003
    Albuquerque,NM
    i belive i used -local -advmethods -forceasm and thats it. my system is stock now and is stable. can you run all the listed switches? and is it better to run in console then in the graphic?
    DFI NF4 Ultra D/3800 x2 @ 2.5ghz/2x512 BH-5/ EVGA 7800 GT /OCZ 600W PowerStream
    Tweaked!
    Guest
    There's no real speed difference between the console and the graphical versions. But yes you can run as many switches as you like, although some might defeat others. But I have noticed that some of the newer 10xxs are really slow. On my duallie running xp2100s @ 2325mhz, they are taking around 20 - 25 minutes a frame.
    Got a hold of some 917s yesterday that were flying though, only taking around 6 minutes a frame.
    Xtreme X.I.P.
    Dec 2003
    Ohio
    Re: Re: folding has slowed
    i'm kinda new to folding... where do you set these switches?
    Jun 2003
    E-town, The Neths
    right click a shortcut to the console and then:
    | R3dRUM |
    | K8V max 3 | 2x160GB sata spinp's | A64 3000+ @ 220x10 1.550v | SLK-948 & 3412ngml | 2x 512mb Tw/WB Bh-5 | Schmuk3d Radeon 9700 | ZM80-HP| SbLive! Plat (pre 5.1) | Pioneer DVD-121 & DVR-107 | ZM400-apf |
    | Quintaro |
    | SB61G2 | 120gb 7200.7 sata | P4C 2.8 @ 250x14 1.60v | 2x 256mb HyperX 3200 Bh-5 | 9800seAIW@pro | SD-161 |
    | Illustrious |
    |Cuv4x-D| 600BB & 1200JB |2xP3 866mhz | 2x Igloo 2320 | 2x256mb Nanya PC133 | G550 32mb | Yamaha 4416s | 2940b | Pioneer 106s | SB128 | Topower 370w TriFan |
    FSB FAN Press any key UBCD! OpenOffice
    Xtreme Mentor
    Nov 2002
    Delaware USA
    Seems like my points keep dropping and dropping. And every rig is up and running.
    Dont even ask where i've been!!!
    X. I. P.
    Jul 2002
    Sioux Falls, SD U.S.A.
    Ditto. Nothing changed on my end. Discouraging
    Xtreme Mentor
    Nov 2002
    Delaware USA
    I've even probably added another 8ghz within the last 5 days with customers computers @ xmas, I know they are on. hooked them up to Comcast cable myself!!!!
    Dec 2003
    Brisbane.Australia
    if your running V4 make sure its got...
    -advmethods -forceasm -forceSSE -local
    i use all but -local *cuz i dont need it* so yeah, give that a whirle..
    -Matt
    Folding@Home For Overclockers Australia. - www.overclockers.com.au/folding/
    Folding@Home as l00b3r, 55000 Point Milestone, 3000ppw club
    H20 Wh0re, and Generalised Spam God.
    Hardass
    Guest
    My duals do those in just over 8 min a frame, at 2250MHz? If your oced to much on some of these it really slowes them down.
    Hardass
    Guest
    We seem to have to go through this lost points deal about once every six months or so. I see on the f@h forum they have been having some server problems. Lets hope that is all it is.
    Xtreme Cruncher
    Jun 2003
    Belgium
    If i add the switches he keeps saying that the link is invalid
    Core i7-920 @ 3,8GHz 24/7 1,30v watercooled
    Gigabyte X58 UD5
    3x1GB G.Skill DDR3-1333
    MSI 7900GTO
    Corsair HX520W
    Hardass
    Guest
    Are you running the grapic or console?
    Sep 2003
    Are you missing a dash - in front of the argument ?
    OR have you added a space between the dash and the argument ?
    Xtreme Mentor
    Nov 2002
    Delaware USA
    space before you put the switches in. then -advmethods -forceasm -forceSSE
    no spaces between the "-"
    Xtreme Cruncher
    Jun 2003
    Belgium
    i run the console and i did it just like on the screen in this thread, not working.
    Gigabyte X58 UD5
    MSI 7900GTO
    Corsair HX520W
  18. #18
    Jul 2003
    Michigan (College), Alaska (Home)
    try this...
    "C:\Program Files\Folding@Home\FAH4.00-Console-Pre2.exe" -advmethods -forceasm -forceSSE
    Change the path to where ever you have the client. Put the quotes around the path and leave the switches outside of the quotes.
    P4C 3.2ghz @ 4ghz w/ Vapo LS
    Mush Level2 3500 2-2-2-5-8 @ 250 1:1
    Asus P4C800-E Deluxe
    ATI Retail 9800p 128 510/396
    Dual WD Raptor HD's on RAID
    3DMark01 - 24,090
    SiliconSauce.com
  19. #19
    Xtreme Cruncher
    Jun 2003
    Belgium
    Originally posted by neyoung
    try this...
    Hmm thanks man, now it works
    I tried allot of things but didnt think of that one
    Gigabyte X58 UD5
    MSI 7900GTO
    Corsair HX520W
  20. #20
    X. I. P.
    Jul 2002
    Related to slowing down, my problem of successful WU completion followed by nothing happening is back on all my folders.
    Log snippet:
    [17:31:44] Completed 250000 out of 250000 steps (100)
    [17:31:46] Writing final coordinates.
    [17:31:47] Past main M.D. loop
    [17:32:47]
    [17:32:47] Finished Work Unit:
    [17:32:47] - Reading up to 422856 from "work/wudata_01.arc": Read 422856
    [17:32:47] - Reading up to 375880 from "work/wudata_01.xtc": Read 375880
    [17:32:47] goefile size: 0
    [17:32:47] logfile size: 155672
    [17:32:47] Leaving Run
    [17:32:50] - Writing 961856 bytes of core data to disk...
    [17:32:50] ... Done.
    [17:32:50] - Shutting down core
    [20:15:21] + Working...
    So, the WU gets done, it writes core data to disk, shuts down the core then does nothing except reporting "+ Working..." every two or three hours.
    Quitting the client and restarting it causes the fold to repeat itself. I might fold the same WU 3-4 times before I get a send and new WU.
    I think it's a routing issue - if the client connection errs on it's first attempt to talk to Stanford I get this behavior. My routing stinks at times, but the client doesn't seem to ever re-try to send the WU or get another to fold.
  21. #21
    Dec 2003
    Gun Range
    I just added -forceasm today. Previously had -forceSSE -advmethods.
    Does -forceasm really help at all? I guess I will know shortly
    "I won't predict where we will end up" - Geforce4ti4200
  22. #22
    Sep 2003
    For Intel cpus with SSE, the flags are not neccessary.
    For V3.xx clients and AMD , forceasm = SSE
    For V4 and AMD, forceasm = 3DNow
    forceSSE = SSE
    If you are using V4 and AMD, it just gives you more choice and there is no need to have both flags.
  23. #23
    Tweaked!
    Guest
    To narrow it down even more, the 1022s are the ones I've been getting that take 20 - 25 minutes a frame. I'm not sure about the rest of the other 10xxs.
  24. #24
    Apr 2003
    Belgium
    forceSSE = SSE
    with one is the best for amd processors??
    the forceasm or forceSSE ?
  25. #25
    Sep 2003
    If you have NO issues with frequent hanging or early_unit_end, then forceSSE is fine.
    Processing a WU with SSE is abt 20-30% faster than using 3DNow but there have been many reports of pc hanging with AMD procs/SSE in the past, though palomino seems to be free from this problem. I have no problems with SSE but none of my pc are o/c.
    Many AMD users with this problem can however use 3DNow to finish the WU. It depends on your procs so it is a matter of speed vs stability/convenience.
