Just can't make up my mind about it, my head hurts. My problem is i got to get some new mem fast, my sticks are dying fast. I would like to wait for DDR600.
What do you guys recommend ?
with good sticks & luck adata pc4000 & geil pc4200 can hit ddr600
Best memory for me : mushkin PC3500 Level II
Best Value : Geil PC 4000
For intel
Q9550 EO @ 4.1
Asus P5Q Deluxe
4 Gb DDR2 Gskill
2xVelociraptors 300 gb Raid 0
Sapphire Vapor 4870 1Gb
PCP&C 750w silencer psu
Buying memory is pretty much buying memory chips (DRAM chips) + company support/reputation. Since no memory company actually manufacturers their own chips (except Crucial/Micron, and some GeIL) the performance between similar chips will be about the same, depending on how they treat their chips (some sand it down, ect.).
Memory chips currently used (in some esteem) are:
Winbond BH-5 - Arguebally #1; Becoming Harder to Find
Hynix D43 "B" - Used in Most PC4x00
Winbond CH-5 - Newer but Worse then BH-5; Most Common in PC3200/PC3500
Hynix D43 "B" memory is used in OCZ PC4x00, Corsair XMS4000 PRO, Mushkin PC4000, GeIL PC4x00 Ultra, and most other PC4x00.
Winbond BH-5 memory is used in Muskin "Black-Level 2" PC3200/PC3500, Buffalo PC3700, and Kingston HyperX3000 and HyperX3200 (NON A; check for Product Codes of KHX3200K2/1G NOT KHX3200AK2/1G).
Winbond CH-5 memory is used in most Corsair XMS3200/3500, Kingston HyperX 3200A/3500, Mushkin "Black-Level 1" PC3200/PC3500, OCZ PC3200/PC3500 EL, and many others.
If you want high FSB (260-300) - and you don't have a Socket 754 processor - you will have to suffer with high timings (3-4-4) and will probably need to put in high voltage still (2.9-3.2V) to get DDR600.
Or, since you have a i865/i875 mobo I presume, could best with (price no object as you say) Mushkin BL2 PC3500 with your FSB running at a 5:4 ratio. This will allow you to get high processor speeds (high processor bandwidth) while still being able to get tight timings (2-2-2).
if money ain't an issue buy 4 - 8 sticks of each type of memory, testing them all and keep the best 2 - 4 sticks
Wrong, Geil uses their own process and chips, not Hynix for their 4000.Originally posted by Speed_Mechanic
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
GeIL does produce some of their own chips, but the chips found on the GeIL Ultra Platinum-Series are usually from outside companies. While GeIL hasn't confirmed any use of Hynix D43 in their PC4000/4200 it is speculated that they do. Nevertheless, performance between GeIL's use of chips and Hynix D43 are very similar.Originally posted by Soulburner
Geil is Hynix as is corsair and OCZ and everyone else running ddr500 or higher, its just we(OCZ) have a better PCB
OCZ3500LE is BH5 based and cheaper than the mushkin, it also clocks as well.As soon as i have the modules here I will push em with 3V and see what they do.
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Or, since you have a i865/i875 mobo I presume, could best with (price no object as you say) Mushkin BL2 PC3500 with your FSB running at a 5:4 ratio. This will allow you to get high processor speeds (high processor bandwidth) while still being able to get tight timings (2-2-2). [/B]
This is the only way to go IMO, my experience with OCZ PC4000
Gold has convinced me that PC4000 and its slack timings are a waste of money. Guaranteed to limit your cpu overclock for sure too. Stay away from ALL PC 4000, get the Mushkin PC3500 L2
P4C800-E Deluxe
P4 3.0c 30 capper @
280x15,5:4;4200MHz
2x512 Zeus BH5
Radeon 9800 Pro
2 Raptors,raid 0
Prometeia Cooled
I Never Sleep
I just tested 2 sticks of mushkin pc3500 l2 and 2 of buffalo pc3700. Both performed right about the same which is expected since they're both bh-5. Buffalo is alot cheaper but I suppose you can prolly also get yer replacement sticks from mushkin alot easier too after you fry them from the insane voltage you tortued them with
P35-E / e8400 / 2x1GB Ballistix / 9600GT
Chaintech AV710 / Panasonic XR55 / AV123 X-LS & Senn HD595
Heat - SoulEdge || Ebay - Newpaypay
Thank you guys for replying.
Since most of you recommend the Mushkin 3500L2, i tested to see how far my 2.4C would go with my Corsair 3500C2 1x512mb which maxes at 200 on my IC7 @ SPD settings and 2.8v. Using 3:2 it booted up to 313fsb, barely. Let's say that my cpu/mb would be stable @ 313fsb, 5:4 = 250, 3:2 = 208, go with DDR500/533 @ ~2.5-4-4-7 or Mushkin 3500L2 @ ~2-2-2-6 ?
If you go with the Mushkin you will have to run the 3:2 divider at that FSB speed unless you plan on doing a vdimm mod to give your RAM 3.5v.
If not, PC4000 is a waste, get OCZ 3700 Gold as it will run 250-260mhz with better timings than the 4000's.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
which model buffalo?
DD466-S256/WB($62) or
DD466-S256($58)
Dell Studio XPS16... no desktop
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
intead of makinf a new thread, ill use this:
whats the best AMD memory thats cheap?
im looking to dump my ch-5 hyperx3500 and get soem bh-5 sticks of some kind. any suggestions? i wanna be able to trade, or sell for same price as my current ram for said bh-5 sticks.
also where will i get the to be mentioned sticks? (ie newegg is HIGH on mushkin lvlII, excaliber doesnt have em, so where.. just an example.)
Running at 3:2 does have a little premium of a performance hit over 5:4, where the performance hit is little to none on i875/i865 boards. If you do give your BH5 memory some extra juice (2.9-3.2V - big differance between the 2 ) you may get it going above 230MHz (DDR460) at 2-2-2 timings. You will then be able to run your FSB above 290MHz (~3.5GHz on 2.4C) while running 5:4 FSB:MEM ratio.
For lowest prices of Mushkin (which is found cheapest at Newegg) and other BH5 memory, check this updated list (at OC-Forums).
dont suppose anyone knows of any shop in the UK that has anything (cheaper the better, i.e. twinmos?) with guaranteed BH5 chips on it?
i can get corsair 3200 but i dont know if they all have bh5 or not and i dont wanna risk ending up with kak ch5 chips.
I have 2 x 256 HyperX PC3200, I checked the codes and they're KHX3200K2/512. So does that mean I have BH-5 chips? And if I do, how come the dont perform aswell as I thought they would, could it be my mobo? >_<Originally posted by Speed_Mechanic
1700+ DLT3C @ 2.4 Ghz (220 x 11)
Abit NF7-S rev.2.0 with modded NB cooling
Sapphire ATI Radeon 9800XT 256MB
PC-3200 2 x 512 Corsair XMS
Western Digital 120GB 8MB HDD
"Framerate is Life!"
I've tried the pc4000 and 4200 crap, screw those slack timings. My kingston and geil both have bh-5 sticks, And i havnt found better.
Dont even ask where i've been!!!
What the KHX3200K2/512 designation really refers to is that it's an earlier revision then the current (currently being produced that is) KHX3200AK2/512. Like the Corsair XMS 3200 rev1.1 and rev1.2. Earlier Corsair XMS3200 used both Winbond BH-5 and BH-6 chips, and switched revisions due to Winbond's switch over to CH-5. This is the same thing that happened with Kingston. Although Kingston must have had a rather large stockpile of BH-5, as they seem to be still shipping these older revision memory along with their newer A-revision. This means that is very likely you have BH-5 chips, although it's not entirely a given.I have 2 x 256 HyperX PC3200, I checked the codes and they're KHX3200K2/512. So does that mean I have BH-5 chips? And if I do, how come the dont perform aswell as I thought they would, could it be my mobo? >_<
Performance may be lacking for several differant reason. Chipset limitations, processor limits, bad modules, or simply interferance might require a raise of voltage. Giving higher voltage may require a VDIMM mod on your motherboard, but BH-5 memory thrives with high voltage.
.......I agree. Mine does 250ddr at default settings Cas2 3-3-7 and when running 5:4 I know I'm safe up to 315 before I need to raise it to Cas 2.5 3-3-7 which its does to 260ddr...........Originally posted by Soulburner
P4C800-E Dlx
2.4c @ 3.5+ ghz
Slk-800u w/T.T. Smart fan II w/ T.T. Ducting mod
2x256 OCZ EL-Gold 3700
2 x 37gig-Raptor in Raid O
ATI 9800XT
Antec TrueControl 550
Yup those are the good ones. K2 just means dual channel kit.Originally posted by Vanrick
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
Man memory prices are shooting up and up again for the good stuff!!! dammit, getting close to Xmas i guess like always!!!!
OCZ - 3500Platinum vs 4000Gold vs 4200EL
I think i'm gonna go with the 3500 Platinum.....
Do you guys think the Platinum would oc like the Gold and EL or a little bit more ?
Mushkin PC3500 L2...by far. Very high clocks with very tight timings!
System:
Opteron 165+ @ 3140mhz @1.5V aircooled
DFI NF4 Ultra-D
4X 512mb Speedpremium PC3500 new BH5
MSI 7900GTO 512MB @ GTX
2x WD 80GB raid 0 + 2x 300GB Maxtor
Channel Well Tech 550W
OCZ PC3500 EL Platinum (Limited-Edition) (OCZ3500LE) uses Winbond BH-5 chips, just the same as Mushkin PC3500 Black-Level 2. OCZ3500LE was just announced earlier this month, so it may be a bit hard to find. Whichever is cheapest, I would go with.
