Looking for input from anyone who has tried the new 10.11 bios. I am running the 10.10s with no problems I'm also running a raid 0 using WD Raptors. Thanks for the input.
I have found the 1010's to be one of the worse BIOS around
Try the 1007 Finals or the 1007.012 BIOS instead
I have tried the 1011 series & they gave me lots of problems, although they oced pretty well.
I have even asked OPP what BIOS he uses & he uses the 1007.012
And what about the P4C800E? the same stands too?
Right now I'm with the 1011.006 beta and still can't get it to post above 1.6000V.....
Mollov,
Runnin' a 700MHz SlotA Thunderbird...
HardwareSight.com Owner
I am not sure about the -e
About the BIOS I cant help. But can you tell me your opinion about the Raptor. I have 2 raptors in raid 0 in the same board. I'm impressed by is performance. But I hate the noise. They make a continuous whistle. Do you have the same thing going on? What your opinion.Originally posted by shogan191
Sorry for staing out of the subject from this thread.
CoolerMaster Stacker l OCZ 550W l Asus P5B Dlx l Q9450 l 2X2GB Gskill l WD Raptor 74GB l 6600 GT
Proud Portugal@Folding member
But do you have that kind of a Vcore problem anyway?Originally posted by Amoeba Assassin
Mollov,
check if the case is vibrating a little, if yes try to put some gum between the drives and the mounting.About the BIOS I cant help. But can you tell me your opinion about the Raptor. I have 2 raptors in raid 0 in the same board. I'm impressed by is performance. But I hate the noise. They make a continuous whistle. Do you have the same thing going on? What your opinion.
No, I don't have any vcore problems that I know of
OK, got the newest 1011 BIOS, now I got 1.525 - 1.6V and 1.7V up..... that's something better
Eventhough @1.7V set in BIOS I get like 1.58V under load.... a way to fix that? MOSFETs cooling maybe.... eventhough they don't heat that much...
Mollov,
thanks for all the replies everyone. Metro I like the raptors just fine. No noise problems here. I did notice that initially there were a couple of times I heard them. My system is relatively quiet so I would be checking the mounting on yours. If your still having noise then I would take them back. Is it just one or both?
Guess I'll switch back to the 1007. I think I have a copy on disk somewhere. Thanks I'll let everyone know how it goes. I've been stuck as far as ocing for a while. Not able to move up. Mabye this will help.
saaya:
I dont have any vibration. But I will do it. I thing the noise is from the rotation of the disk. I hate the noise they make.
shogan191
I also have a quiet system. I have revised the mounting a few times. I will follow the advise from saaya, but I dont thing it will works. Take them back? Here were I live is not a very easy task. I have whait for it a eternity.
Didn't think I was going to make it back. I tried the 1007s again, and the 10.11. The 10.11s almost did me in. Couldn't get rid of them and couldn' get the10.10s back on. All is fine now. So much for never being happy. I'm happy now. for a while.
1002 bios still owns thou (atleast as far as 5:4 or 3:2 performance goes)
There was actually a POST about a mod to stabilize the vcore and I'm surprised that no one took an interest in it.Originally posted by TodB
Intel E6700 @3700
Asus P5W64
Kitty Litter Water Coolertm
2 x 1gb G.skill 6400 HZ
"Some people couldn't get a clue if they smeared their body with clue musk and did the clue mating dance while sounding the clue mating call in a field full of horny clues at the height of clue mating season."
Damn, that's not very good though..... soldering just to get stable Vcore output... what a shame....
Mollov,
I always thought the 1007.012 & the 1007 finals where betterOriginally posted by macci
have tried them both?
This bios is working good for me, benching today @ 4.2Ghz raising my scores a bit with a new unmodded card. horrid memory on this 5900, maybe after mem mod it will pull up to 1Ghz
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
Memory mod on these ultras is borderline worthless and has an extreme mortality rate.
dont encourage himOriginally posted by SpicyHuevos
Digressing ever so slightly, I'm using the 1011 bios for the Asus P4C800-E and I'm very happy with it. No obvious problems - running my L311 3.0C @ 4.2ghz. Has anyone tried the new beta? I'm not sure how it is different from this release.
I'm using the 1011 final. It's actually given me 3 extra MHz FSB stable with this 2.4C (290 to 293).
C2Q Q6600/Scythe Ninja Plus/Asus P5B DLX WiFi/2048 MB OCZ DDR2 PC2-6400 Gold XTC/EVGA e-GeForce 8800 GTS SC 320 MB/Tagan 580W TG580-U22
I'm also running 1011 bios on my P4C800 non deluxe and haven't had any probs with performance or stability.
Well it just shows how different everyones rig is. I went back to the 10.10s with a stop off at the 1007.12s along the way. I sure appreciate the 10.10s.
All this dicussion and already a new 1012 beta is out on the Asus ftp server. No information on it as yet.
Intel E6700 @3700
Asus P5W64
