Anyone know anywhere I can get info on volt modding 3.3v , 5v e 12v my antec trupower 550w?
Thanks.
Thanks.
me too, id love to figure it out
abit nf7-s 2.0
a xp2500+ M @ 2.7
WaterCooled
Chaintech vnf3-250
a64 2800+ @2.5
1 gig ocz rev 2 platinum
Have a look here
http://www.xtremesystems.org/forums/...threadid=16050
Silverstone Sugo SG01B
Biostar TForce 6100-939 (Bios A12)
Opteron 148 (CAB2E BPMW)
Saphire X800 GTO2 @ X850 XT
Gskill 4800 FF (1 of only 50 in the World)
Geil One TCCD (Max: Testing)
Geil Ultra-X PC3200 (Max: 287 2.5-4-4-8 2T @2.75v)
Enermax Liberty 500W
TFT HP 2035 20"
I have the same psu as you mentioned "SPL" and "LazyTech".
I was running some low rails until I did a vmod to it. Now it runs these readings...I used a meter to check them and not the bios as it can be off by quite a bit:
3.3v = 3.65
5v = 5.6
12v = 12.75v
You will have to look at the ATX connector and then the wires that are Orange (3.3), Red (5V), and Yellow (12v). There will be a thick wire and a thin wire. The thin wire is the "sense" wire for the psu, this is one you add a resistor to.
Just grab a 10k-20k VR from your local radio shack. Snip the sense wire and solder the VR to it. The VR should have 3 legs. Use an outer leg and the middle leg, but do NOT use the 2 outter legs. Solder the screw side of the VR pointing at the psu, then solder the middle leg of the VR to the wire thats running to the ATX connector.
I recommend this:
But not this:
The big pots can get in the way with this type of mod. I used a series for my mod, but a single VR will work nicely. I would cut the end leg (end with no screw) off so that it doesnt get used by accident.
This is a simple vmod to do.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
Hëll ‡ Fîrë
Will this work on any PSU that has the thin sensing wire? Thanks, nice mod!
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
Hunter S. Thompson (1939 - 2005)
Dale it SHOULD work with any PSU that actually uses the sense lines to regulate the rails. On some cheap PSU IMO the sense lines are not used. Also on some PSU's the 3.3v rail is actually taken from the 5v rail, so adjusting the 5v rail with this mod would probably adjust the 3.3v as well.
The TP550 uses seperate regulation for the 3.3v, 5v, and the 12v rails so it should work well with this psu. I'm going to do this mod to my TP550 in the next couple of days and I'll post the results.
24/7 Work & Play Rig
Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
Thanks Major,
I have to check my power supplies to see which ones have them...aside from my TC550 on which all are adjustable...it may allow adjustment on the TTGI rails that lack pots and I think I have an Antec TP 430 with no pots at all that has lagging rails.
How come in the other thread they use a fixed resister too?
I did it and made no difference and I'm using a 10k vr should I try a 20k vr??? Whats the resistance that you guys have when the vmodd is done?
A64 4600+ X2
DFI Ultra D 11/14/05
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
Any PSU that actually uses the 3.3 sense wire should work with this mod. I've used 10k pots. I've modded Enhance, Enermax and some no-name POS PSU to work with this.
You start with 0 (zero) ohms and slowly increase the resistance 'til you get your desired volts. Multi-turn cermet (ceramic-metallic) potentiometers are best - they allow for both fine-tuning and since they increase the voltage slowly they guard against blowing boards and/or PSU's.
The plural of "anecdote" is not "data."
I'm using a antec 550 true control right now and tried a 10k vr and it did nothing and same with my PC power and cooling 400w. I know I have the right wire its the small one thats next to the 3.3v at the atx plug but some how I get no change at all.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
PCP&C supplies may be using different circuitry on the 3.3 sense than lesser supplies. Have you checked with the PCP&C staff as to how to tweak your unit? BTW, wish I had one, nice!
sjohnson,
I finally broke down and ordered a 510 PCPCooling PSU.....tracking says it will be here tomorrow. I wish I had bought nothing but these from the start as anything less is really a waste of money in the long run. Ahhh....hindsight...sigh
The Sherman tank of all PSU's. Great choice
Actually the PC power and cooling 400w model has very low lines and tryed to talk to PCPAC about that and they said there's no adjustment for that model so that kinda sucks.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
The 510 is a lot different than the 425. I talked to a tech there named Larry for 45 minutes. He was very helpful and convinced me to go with the 510.
Ohh ya I'm not saying the 510 sucks at all Dude, I just said the 400w model isn't so great. I wish I could afford the 510 and I would take one in a hurry the 510 deluxe is my dream PSU.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
Got her working, thanks guys.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
What did it take corrupt?
Same as everyone else, I was trying another way just using a 10k vr in line with the vsence line and it no worky. So I tryed a 10ohm resister and a 1k vr and it works perfect. Goes up to 3.60v for the 3.3 line but I think thats alittle silly,lol.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
Nice job corrupt!
Thank you Dude, hey have fun with the 510 let me know how it is, and btw did you get the one with the external pots?
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
Yes corrupt! Good to hear you figured it out
I got the regular 510....pots are internal...I don't expect to need to adjust them, but I'm comfortable doing so if need be. BTW You can drill 3 holes in the PSU case of the regular 510 and adjust pots with a screw driver.Originally posted by corrupt
Thats definatly good to know. Hey by any chance have any of you guys did the memory v modd for the 9800pro I know how to do it but just wondering what was to much voltage is like 3.00 volts ok????Originally posted by TheDude
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
