XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 06-11-2003, 11:25 PM   #1
caater
caater's Avatar
r9600pro first results & pics
i got this powercolor radeon9600pro for testing yesterday.
i was kinda surprised it wasn't using the glued-down hsf like
reference boards did.. but rather it looked like radeon 9700.
in fact - it has the same ram as 9700pro.
but.. 0.13 process is simply amazing.. the core is sooo tiny
and no shim this time
guess they don't give a **** bout us crushing cores on el cheapo cards :P
and to be honest - it's oc results are rather disappointing.
max with def cooler was 465core/330mem.
with h20, 485core was ok, but it at 500core it did
hang right away.
but the card's soo incredibly cool.. i measured max 46C
at the backside when overclocking and running 3dmark..
r9700pro was ~65C w/ def cooler.
when watercooled, temps are like 30-34C. and that's like 10-15C
lower than 9700pro w/cooled.
so, according to temps - this is not a cooling issue. baby needs some voltage.
Anyone knows what def vgpu is for r9600pro?
first testresults with 2.8c proc and 465/330 rad were:
3dm2001se - 13165, 3dm03 - 4022
i'll look for w/cooling max and then bench with full cpu power
and.. ready to roll
caater is offline   Reply With Quote
Old 06-11-2003, 11:41 PM   #2
Estide
Estide's Avatar
*wow* he's very small...thats right
But only 13XXX Points @3dmarks2001?!?
But 4XXX Points @ edmark2003 is like an (bad) 9700Np
Thx for Information
Estide
__________________
www.hardwareluxx.de (estide2002)
Nethands
Please don't kill me, I'm German
Estide is offline   Reply With Quote
Old 06-11-2003, 11:44 PM   #3
caater
caater's Avatar
stock r9700pro was 16k points at 2001SE with that cpu.
unfortunately i don't have a 9500 :/
Estide
Old 06-12-2003, 12:05 AM   #4
Estide
Estide's Avatar
The The 0.13µ prozess makes the card cooler (like palomino 0.18µ and t-Bred 0.13µ )
330 Mem with the Samsung 2.86NS chips isn't very high?!?
http://www.xtremesystems.org/forums/...threadid=14039 here is a thread to Mod 9600
Estide
__________________
Nethands
Old 06-12-2003, 12:14 AM   #5
caater
caater's Avatar
this card unfortunately doesnt have a semtech vrm.. but i'll search
teh net tonite
but 330 ram isnt too shabby, i have to admit it.. it artifacted like hell at 345 and eventually locked up..
so i think that reference 9600 boards definately had higher voltages.. and with voltmod.. agp power is the limit
and ofcoz.. as far as i can see, external powerconnector mod
looks also possibility
Estide
Old 06-12-2003, 02:38 AM   #6
antipop
Xtremely slow runner
antipop's Avatar
That's not a really good score in 3dmark, what is your benching system?
__________________
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Av by Frisch This is not a Lime tree
antipop is offline   Reply With Quote
Old 06-12-2003, 02:55 AM   #7
caater
caater's Avatar
p4 2.8C + aopen ax4c max + 2x256megs corsair @
dual ddr400 2 2 6 2.
as i stated before.. r9700pro w/def clocks 2001SE score was 16000... +- 10 points
and default 3dmark03 was 4800.. if that matters.
Old 06-12-2003, 05:07 AM   #8
jmke
jmke's Avatar
the high score in 3Dmark03 is due to the R9600 supporting more DX9 features then its older brother
but performance wise it still less then the R9500
anybody using the 3Dmark03 bench is just looking at some pretty pictures, because the endscore means nothing , thanks to Futuremarks greed for $$ and nvidia/ati's greed for market domination.
yippikajee
__________________
Belgian Hardware Testers & Overclockers Wanted
Belgium's #1 Hardware Review Site and OC-Team!
support guru
jmke is offline   Reply With Quote
Old 06-12-2003, 05:19 AM   #9
Estide
Estide's Avatar
yippikajee
Youre right, but i Think that 3dMark is good to compare the different cards. To see what performance have your card is another thing.
estide
__________________
Nethands
Old 06-12-2003, 05:50 AM   #10
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
the core is smaller because the 9600 only has 4 pipes afaik, less transistors...
about ocing, ati lowered the gpu voltage a lot to reduce the ocability of the cards. they probably want to have some room left to release an updated rv350 in the future that will run faster.
only 13K with that system oced and all? fck thats low... thats slower than a ti4200 i hoped it would perform better : /
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 06-12-2003, 05:51 AM   #11
jmke
jmke's Avatar
if the compared cards use the same driver and are from the same "nest" (ATI/nVidia/SiS/etc.. etc)
that way you don't have to worry about any unfair optimalisations!
__________________
support guru
Old 06-12-2003, 05:55 AM   #12
caater
caater's Avatar
or those darn OEMs didnt stop whining bout high power
consumption on low end cards..
and bout voltage.. i think they (ati) did the opposite way.
increased voltage of press cards, so they oc high and look good.
Old 06-12-2003, 06:06 AM   #13
saaya
Xtreme X.I.P.
saaya's Avatar
yeah good possibility... or they only send cards to people like Kyle and the pre samples didnt oc any better
__________________
Old 06-12-2003, 06:44 AM   #14
antipop
antipop's Avatar
ROFL even with a 30MHz over stock core he would call that a great oc'er. He could help nvidia :smileysex
__________________
Old 06-12-2003, 07:28 AM   #15
saaya
Xtreme X.I.P.
saaya's Avatar
roflmao but he has an affair with bfg tech it seems
__________________
Old 06-12-2003, 07:47 AM   #16
wierdAl
Xtreme Recruit
em... did you try to up the voltage on the gpu?, becouse i think it could do better... it's 0.13 micron.... it has to go higher...
__________________
nf7srev1.2
2500+@3200+
1gb twinmos /w ch-5
80gbWD8Mb
radeon9500pro
wierdAl is offline   Reply With Quote
Old 06-12-2003, 09:34 AM   #17
caater
caater's Avatar
i'll up my cpu just as my water can handle and then benchmark it..
and then.. start lookin for voltmod possibilties :p
i have one 10k pot lying around
Old 06-12-2003, 12:23 PM   #18
caater
caater's Avatar
i ran 3dmarks now with ~3.6ghz proc.. not too shabby..
3dmark2001se - 14337
3dmark03 - 4168
i'll measure some voltages.. etc..
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
