Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Need a volunteer to confirm some test results for me....
    Technician
    Jun 2002
    Merseyside, UK
    I need to waste an hour of some kind souls time out there .
    If anyone with the following spec is reading this and fancies lending a hand plz could you pm me .
    Nf-7S v2.0
    Bios 10 (original shipping)
    Non vmodded board (or mods disconnected)
    Capable of running 200FSB plus at a 12x multiplier with dual channel.
    Knows how to use memtest, sandra, 3dmark.
    It should really take less than an hour - ive done all the groundwork and really only need another set or 2 of reported results. Nothing complicated .
    Thx,
    PiLsY.
    Jun 2002
    LAS VEGAS
    Pilsy I have a v1.2, but not a 2.0. I'm headed out the door right now, but I will be back in about 4 hrs and I could run it for you then.
    Jan 2003
    NYC
    well, im planning to buy a rev2 board this week so in about a weeks time i can help ya out
    just curious, but what for?
    Technician
    Jun 2002
    Merseyside, UK
    Nothing groundbreaking, but im not willing to spill the beans until I know im right .
    Nate - that would make it 5am here when you get back - ill be ordered off to be by she-who-must-be-obeyed far before then m8 . Im really after rev 2.0 owners, but sure if you want to try then it would give me a chance to see if what ive found is specific to the rev 2.0 or happens across other NF7 revisions as well. I could really do with confirming on someone elses NF7 v2.0 to make sure what ive foundisnt just specific to my board though. All very vague and mysterious, but you know me . Wont speak at all until I know for sure that im not speaking out my arse .
    PiLsY.
    Technician
    Jun 2002
    Merseyside, UK
    Thx Mickey .
    PiLsY.
    Jun 2002
    chicago
    I've got nothing better to do right now.
    Cursed be the ground for our sake. Both thorns and thistles it shall bring forth for us. For out of the ground we are taken for the dust we are and to the dust we shall return
    Heat
    Xtreme X.I.P.
    Jun 2002
    Belgium
    PiLsY :
    check your PM.
    Oct 2002
    London
    PiLsY
    Drop me an e-mail/PM and i'll get to it.....
    NF7-s V2.0 .... two of them actually.
    All above criteria ok.
    Cheers
    Jan 2003
    hmm.. i've got a v2.0 but with bios11
    /dev/zero
    Nov 2002
    Germany, Berlin
    Talking S**t. I mean... what a pity.
    My rev2.0 is being rma-ed cause I could not do same cpu as on my rev1.1, what means 250Mhz less.
    And then testing samsung CTL dual (ran 230 2,5-5-3-2 at 2,8V stock on 1.1) didn't indeed led me to over 200 stably.
    So this board must be exchanged (no answer though from rma dep)
    Oh I am so bored...
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
    Technician
    Jun 2002
    Merseyside, UK
    Thx for all the offers guys . Ive pmed jupiler with instructions, so we shall see what he comes up with. If his results confirm mine ill create a new post outlining what ive been playing with and the pm I sent him so you can all give it a try .
    Thx again,
    PiLsY.
    Nov 2002
    Plano, TX
    PiLsY,
    Even if Jupiler's board doesn't show it, what if it's something that does affect some boards but not others? Shouldn't you just let everyone know so you can get results from a larger sample size?
    Even if it doens't affect anyone's board but yours, I don't think anyone minds if you end up, as you say, talking out your arse...
    Epox 8RDA v1.1 | Athlon XP 2100+ AIUHB 0301 @ 2205 mhz (200x11) @ 1.8v | Radeon 9800 NP @ 378/324 | 2x256 MB of Corsair XMS PC3200 CAS2 | Maxtor 80gig 5400 HD | Linksys LNE100TX | SLK-800 w/42.5 cfm Sunon 80mm fan | Antec SX830 w/Antec SL400 PSU
    Oct 2002
    Offtopic - that just cracked me up bigtime here, BrainStorm!
    Technician
    Jun 2002
    Merseyside, UK
    lol fair enough and a point well made .
    Pasted below is my PM to Jupiler from earlier today . Try it if you like, report results up if you do.
    Paste below :
    I think ive found something weird with the mem timings and just need it checking out. Ive got all the important bios settings written down - i'll copy them in below so you can set to match.
    Memory in dimm slots 2 and 3. Twinmos w/twinmos chips.
    Softmenu 3
    12 x 202FSB
    66mhz AGP
    1.7vDD
    1.8vcpu
    2.9vddr
    1.5vagp
    FSB/Dram 6/6
    CPU Interface enabled
    Over temp 100c
    Advanced Bios features
    Apic enabled and MPS version 1.4 set.
    Advanced Chipset Features
    System bios cacheable : disabled
    video ram cacheable : disabled
    AGP Aperture size : 128mb
    FSB Spread spectrum : disabled
    AGP Spread spectrum : disabled
    CPU Thermal throttling : disabled
    Enhance PCI performance : Enabled
    AGP Transfer rate : 8x
    Fast Writes : Enabled
    Integrated Preipherals
    Onboard IDE : All Auto/Enabled
    Onchip PCI : USB Disabled / Audio Enabled / Lan Enabled / Boot Rom Disabled / IEEE1394 Disabled
    Onboard PCI : SATA Disabled
    Init display First : AGP
    FDD Controller : Enabled
    Serial Ports and Parallel ports all disabled
    Power management
    ACPI - S3
    Button : Instant Off
    PCI Wake : disabled
    Ring wake : disabled
    Alarm wake : disabled
    Power On : Button Only
    AC Power Loss Recovery : Power Off
    PCI/IRQ Resources
    Update ESCD : Disabled
    Resources to manual
    IRQ Resources all set to PCI
    PCI/VGA Palette snoop : disabled
    Assign IRQ to VGA : Enabled
    Assign IRQ to USB : Disabled
    PCI Latency Timer : 32 Clocks
    PIRQ_0 : 7
    PIRQ_1 : 5
    PIRQ_2 : 3
    PIRQ_3 : 11
    PC Health
    CPU Shutdown : Disabled
    CPU Warning Temp : 80c/176f
    Shutdown on fan fail : Disabled
    Now I dont doubt most of those are already set as I have them set, but I have to be thorough with this really. All I really need are memtest bandwidth results, but sandra buffered/unbuffered and 3dmark would be helpful too if you have time. The memtest stuff is the important one anyway.
    Now what ive found in testing is that lower Tras isnt always better. Infact when youre set to cas 2 /trp 2 / trcd 2 settiong TRAS to 5 drops your bandwidth in memtest by some 150mb/s compared to higher values.
    If you could set your ram timings to 2/2/2, then start at Tras 4, and work all the way up to tras 15, booting into memtest and writing down its reported memory bandwidth that would be enough to confirm my results. My results are below for compare.
    Timings 2/2/2 @ 12 x 202. Variable Tras.
    Tras 4 : 1508mb/s
    Tras 5 : 1508mb/s
    Tras 6 : 1558mb/s
    Tras 7 : 1583mb/s
    Tras 8 : 1583mb/s
    Tras 9 : 1583mb/s
    Tras 10 : 1610mb/s
    Tras 11 : 1610mb/s
    Tras 12 : 1639mb/s
    Tras 13 : 1610mb/s
    Tras 14 : 1583mb/s
    Tras 15 : 1583mb/s
    Ive found out that where the bandwidth peaks is down to many, many factors. Settings affecting where your peak bandwidth arrives are :
    Vcore
    vDD
    vDDR
    CPU Multiplier
    FSB
    Dimm slots in use.
    timings of other settings (trp, trcd and cas)
    Lots that affect it. Once youve sorted the results out for me have a play and see if you can grab a bit of extra bandwidth. Sandra doesnt report much difference (30mb/s unbuffered and buffered), but 3dmark does. Ive seen a 300 point spread between tras 4 and tras 12.
    Anyway, get back to me if ive confused you on anything, im anxious to hear what results you get .
    PiLsY.
    X.I.P.
    Oct 2002
    Australia
    PiLsY,
    I noticed that too (Tras bandwidth effect), but didnt record the results
    I could simply be that the mem timings are more "matched" to the instruction sequence (and prefetch pipeline depth) that memtest uses.
    Setting the Tras low defintely gives better performance on real world apps ... just try pifast @ 3-2-2-2 & compare with 7-2-2-2 timings.
    I think that the importance of bandwidth measures are really overrated. Latency is far more important for application performance.
    Jul 2002
    UK
    i posted in another thread earlier the same thing but my test used sandra unbuffered. http://www.xtremesystems.org/forums/...313#post134313
    i found i scored higher with 8 than i did with 4. didnt bother to test anything else. this was at 219fsb DC 222.
    Technician
    Jun 2002
    Merseyside, UK
    CodeRed - pifast times go up, seti times go down, folding times go down, 3dmark goes up, dvd ripping time goes up, super pi stays the same.
    Its very much a trade off. Apps which are relying on pure memory speed tend to go down, whereas apps relying on constant data feeds benefit. The like sof seti, 3dmark et al rely on a constant rate of data, rather than speed of delivery. Stuff like pifast and dvd ripping is all about speed of delivery rather than quantity. I suppose its best to match it to what your pc does most of.
    PiLsY.
  18. #18
    Nov 2002
    Plano, TX
    PiLsY, very interesting. Do you really think it's confined to NF7-Ss? Have you tried with an Epox board, etc.?
  19. #19
    Nov 2002
    Plano, TX
    I was just repeating what PiLsY said in his second post in this thread...
  20. #20
    Aug 2002
    NJ
    I've also noticed this on my 8RDA+.... When testing the stability of my system with Memtest86/Sisoft2003 my bandwith score would drop when I went CAS 2-2-3-5 over CAS 2-2-3-6....
    I figured it must have been my RAM crapping out and not liking that tight of a timing but guess I was wrong... :p
    Intel i5 3570k || Sapphire HD 7870 OC CrossFireX || Asrock Z77 Extreme4 || 8GB DDR3 G.SKILL || Seasonic X750
    Intel Core2Duo E8400 || PowerColor HD 5450 || Gigabyte P35-DS3L || 4GB DDR2 G.SKILL || Enermax 431W
  21. #21
    Nov 2002
    Plano, TX
    I screwed around briefly with my 8rda with the following results at 203x10:
    4-2-2-2........3079/2888
    6-2-2-2........3082/2893
    8-2-2-2........3082/2900
    10-2-2-2......3089/2905
    12-2-2-2......3089/2905
    14-2-2-2......3085/2904
    So at least in sandra, 10-12 did the best. Too tired to try other benchies tonight.
  22. #22
    Xtreme X.I.P.
    Jun 2002
    Belgium
    I'm still benching and testing. I hope to have results by this evening. But it takes a lot of time.
  23. #23
    Member
    Dec 2002
    Leics UK
    I couldt be arsed testing many settings, but 13 was higher in sandra than 5.
    Just shows what a POS sandra memory is :P
  24. #24
    Nov 2002
    what effects ram stability the most. I'm having problems with 225fsb and 6-3-3-2 timings and maybe this will be able to help me without loosing performance. Is it tras or the other two values and how do they effect performance. I will take a look at some results using v1.2
    EDIT: I just did some tests but using my bios settings and 2.1v at 220fsb
    tras(4-13) 1754mb/s for each one and a drop occured above 13.
    14-1722
    15-1692
    Sorry with my board and settings this theorey diddn't work out. Or maybe the diff was so small that it didn't show up. I was hoping for some nice scores though
    xp2100+@2550mhz 2.03v 210fsb
    Abit nf7-s v1.2
    ATI R9700
    2x512mb Cprsair pc3500 c2
    Dual Channel!!!!!WOOT
    SATA raid on 80gig maxtors
    highest 3dmark 19300
    3dmark2k1
  25. #25
    Sep 2002
    UK
    Hmmm, I've just tried this on my v1.2 and I think you want to be careful about Memtest86 bandwidth results. I saw no difference in tRAS settings 4-12, but sometimes I would get a result of 1551mb/s and other times 1612mb/s (@ 200 DC) with the SAME tRAS setting...
    Abit NF7-S v1.2
    1700+ 0310WMPW @ 12.5x211 (2645MHz)
    Maze3 CPU + GPU watercooled
    2x256MB Corsair XMS3500C2
    Connect3d 9800 Pro @ 466/371 3dMark2001 - 20719
    Leadtek GF4 Ti4600 @ 351/770 3dMark2001 - 17497
