XtremeSystems Forums
Reply
Old 05-10-2006, 12:32 PM   #1
JoeBar
Xtreme Mentor
JoeBar's Avatar
Talking Finally finished!
After a very long and tiring day, my work is done!
What do u guys think?
Thanks again to all of u who helped me!
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 05-10-2006, 12:34 PM   #2
ReD.SkY
XS_THE_MACHINE
ReD.SkY's Avatar
Send a message via ICQ to ReD.SkY Send a message via AIM to ReD.SkY Send a message via MSN to ReD.SkY Send a message via Yahoo to ReD.SkY
Schweet!
__________________
Asus P5B-Deluxe 0614
Conroe E6400 @ 2.56ghz
Team Xtreem DDR2 2x1GB @ 900
ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
Hitachi 80gb | Hitachi 80gb | Seagate 320gb
Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
Corsair Hx620
Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
ReD.SkY is offline   Reply With Quote
Old 05-10-2006, 12:38 PM   #3
Serra
Xtreme CCIE
Serra's Avatar
Nice job.
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Sitting on top of motherboard box.
PSU: Cooler Master UPS900
OS: VMWare ESXi 4.0... so... "various"
GPU: N/A
Display: N/A - Accessed via network
Serra is offline   Reply With Quote
Old 05-10-2006, 12:41 PM   #4
creidiki
Xtreme Guru
creidiki's Avatar
Send a message via AIM to creidiki Send a message via MSN to creidiki Send a message via Yahoo to creidiki
Nicely done mate, glad youre all setup now.
A little too flashy for my tastes, I have to say
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
creidiki is offline   Reply With Quote
Old 05-10-2006, 12:41 PM   #5
el rolio
el rolio's Avatar
Send a message via AIM to el rolio Send a message via Skype™ to el rolio
very very very nice indeed. a good day's work! love the way you mounted the rad. what type of screws did you use? thread/diameter/length? i would love to know for some changes i need to make to mine!
nice with the what looks like rubber cylinder standoffs too. and how is your pump fixed/mounted to the case?
__________________
Apple Macbook Pro º 2.4GHz Intel Core 2 Duo º GeForce 8600M GT 256MB º 2GB 667MHz DDR2 º 15" TFT LED backlit display // Dell 2407WFPHC // Xbox360 // Ek + Swiftech blocks in storage
r3vo+PC Fall_06 Build
Spring Customer Build
el rolio is offline   Reply With Quote
Old 05-10-2006, 12:44 PM   #6
JoeBar
Xtreme Mentor
JoeBar's Avatar
Thanks for your nice comments guys!
A couple more.
__________________
Watercooling setup:
Old 05-10-2006, 12:49 PM   #7
JoeBar
Xtreme Mentor
JoeBar's Avatar
I used 4mm diameter and 5cm length screws.
The standoffs are plexy. I grabbed them here but used different screws.
The pump just seats in two pieces of soft pads.
__________________
Watercooling setup:
Old 05-10-2006, 12:53 PM   #8
OCme
OCme's Avatar
nice work
__________________
Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
-monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
-monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
OCme is offline   Reply With Quote
Old 05-10-2006, 12:58 PM   #9
Jupiler
Administrator
Jupiler's Avatar
Looking very nice, congrats.
What are your load temps ATM?
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman View Post
I've got Supermicro boards that lasted longer than one of my marriages!
Jupiler is offline   Reply With Quote
Old 05-10-2006, 01:02 PM   #10
JoeBar
Xtreme Mentor
JoeBar's Avatar
I'm getting 33'C idle 43'C load with 24'C room temp. 940 @ 4.52ghz with 1.45v.
7900GTX's temp is 34'C idle, 41'C load but still on stock, hadn't time to oc it.
__________________
Watercooling setup:
Old 05-10-2006, 01:12 PM   #11
creidiki
Xtreme Guru
creidiki's Avatar
thats pretty nice for that oc on a P4, considering the TIM hasnt cured yet
__________________
Old 05-10-2006, 01:20 PM   #12
JoeBar
Xtreme Mentor
JoeBar's Avatar
I'm really happy with my temps. If i had kept ,my 920 temps would be lower. That 940 is really hot...
__________________
Watercooling setup:
Old 05-10-2006, 04:56 PM   #13
-aDaM^
Banned
Looks awesome dood I love that modded 350, is that the Radiical top?
-aDaM^ is offline   Reply With Quote
Old 05-10-2006, 05:06 PM   #14
Visioneer
Visioneer's Avatar
yep looks very nice, I like the case alot too
__________________
E 6600@ 3.71 1.28v
Asus P5N32-E
Crucial Ballistix PC 8000 4 4 4 12 /800
Raptor 150GB
EVGA 8800GTS 630/1050
Hiper 580W
Swiftech Storm│Dangerden Maze 4│MD20│BIX III |DD Heatercore│1/2 ID Tygon Tubing |
Mountain Mods U2-UFO
Visioneer is offline   Reply With Quote
Old 05-10-2006, 09:11 PM   #15
npk
very good job indeed, and the temps aren´t bad either
npk is offline   Reply With Quote
Old 05-11-2006, 02:31 AM   #16
JoeBar
Xtreme Mentor
JoeBar's Avatar
Yes it is. I've ordered mine from Alphacool though.
__________________
Watercooling setup:
Old 05-11-2006, 03:02 AM   #17
haste
haste's Avatar
nice joebar.
glad to see someone else with a external top mounted rad on the armor
__________________
Opty165 CCB1E0609FPMW@2.96ghz 1.4v on UT SLI-DR
MSI/EVGA 8800GTX / TwinX2048-4400 PRO
1x 150gb Raptor / 2x 750GB Spinpoint F1s
1x Maxtor 320gb / LG Blu-ray /
Thermaltake Armor / Galaxy 850w / Creative X-Fi / MCR-220, MCP655, Apogee GT
haste is offline   Reply With Quote
Old 05-11-2006, 03:03 AM   #18
JoeBar
Xtreme Mentor
JoeBar's Avatar
Originally Posted by haste
nice joebar.
Mine is actually the Kandalf with the front door removed...
Looks slicker than those of the armor in my opinion.
__________________
Watercooling setup:
Old 05-11-2006, 03:07 AM   #19
haste
haste's Avatar
close enough
internals are exactly the same.
__________________
Old 05-11-2006, 03:14 AM   #20
JoeBar
Xtreme Mentor
JoeBar's Avatar
Since the day i bought it (a year ago) i haven't really found a case to upgrade...
Really love it.
__________________
Watercooling setup:
Old 05-11-2006, 03:20 AM   #21
haste
haste's Avatar
yes, it is a nice case. it is every so slightly cramped inside for me though. other than that its wonderful. it can hold a mega amount of things, thats for sure.
not sure if you have seen my case or not joebar. check it out here:
http://haste.4saken.org/pics/Armor/finalbuild/
__________________
Old 05-11-2006, 03:35 AM   #22
JoeBar
Xtreme Mentor
JoeBar's Avatar
I've seen it. Looks really nice!
If u change your res to a bay one u'll gain one whole lot of space. I know cause my previous kit had a res mounted next to the pump and it was very crowded.
With your setup u need a case with a down mounted psu.
__________________
Watercooling setup:
Old 05-11-2006, 03:39 AM   #23
delas52
delas52's Avatar
Nice job!
__________________
Gigabyte 965P - DS3
Intel C2D E6400 @ 2.8Ghz
eVGA 8800GTS @ 675/1025
G.Skill 2GB DDR2-800
Ultra XVS 700W
Creative Audigy 2 ZS
delas52 is offline   Reply With Quote
Old 05-11-2006, 03:40 AM   #24
haste
haste's Avatar
thanks..
yeah, a stacker would probably work well for space at the bottom but then i would lose the spot for the 3 hard drives up top. that wouldnt work for me because i need all my front drive bays.
either way i still like my armor. i can understand why people dont like some thermaltake products but they do have some good ones...
__________________
Old 05-11-2006, 03:43 AM   #25
JoeBar
Xtreme Mentor
JoeBar's Avatar
I agree with u. They have made quite a few underperforming products in the past and still they do, but some other are really good.
A friend of mine has a stacker and i still prefer my kandalf.
__________________
Watercooling setup:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
