XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 04-26-2006, 06:22 PM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
Angry Switched from water to phase and oc *dropped* 100mhz???
I have no idea wtf is happening anymore. I was on water before using a 3800+X2 and was getting 2.6ghz dual prime stable at 44C max load. Now I cant even input 2.6 into cg witout is bsoding. I isolated the problem as my cpu since my htt can go up to 295 and mem can go high too and I run it below stock for now anyways. My dual prime load @ 2.5ghz@ 1.5 volts is -7C right now. idle is about -30C on cpu core. The previous owner of the cpu said there isnt any coldbug and was able to suicide at 3.3ghz on dice. Can anyone shed any light on this because I didnt just spend a lot of money on a chilly 1 unit to get a WORSE oc. Am I somehow getting coldbugged?
using a dfi ultra-d, pc power and cooling 510 deluxe, 2 raptors raid 0, and 1900xtx.
EDIT: WOW this is ed up my 3d05 score dropped by 1k just from switching cooling method.
One_Hertz is offline   Reply With Quote
Old 04-26-2006, 07:11 PM   #2
fhpchris
fhpchris's Avatar
Holy Crap! You need 1.5V to do 2.6ghz?
You cannot compare DICE and a SS with -7 load core temp.
fhpchris is offline   Reply With Quote
Old 04-26-2006, 07:25 PM   #3
mikenam
coldbug maybe?
mikenam is offline   Reply With Quote
Old 04-26-2006, 07:32 PM   #4
dogsx2
What's the stepping on that chip? Did you see ss of what the last owner did with the chip?
dogsx2 is offline   Reply With Quote
Old 04-26-2006, 09:39 PM   #5
n91htmare
n91htmare's Avatar
your temp went from -30 to -7...I'm no phase expert but isn't that a big drop?..
I idle at 28 on air and thats like me going 51 on Full load But The max i get is 35 which is 7 deg increase..... but a 23 degree increase in temp?
__________________
Asus P5B-D WiFi
E6300 L626 @ 3.2@ 1.32V
EVGA 7900GTX
Big Typhoon Air cooling
Crucial Ballistix 2x1GB Anniversary
320GB SeagateSATA
Enermax 460W PS
n91htmare is offline   Reply With Quote
Old 04-26-2006, 10:13 PM   #6
Maelstrom2160
If its not a cold bug try reseating the head unit. If you've mounted the unit on a verticaly mounted mobo the head units weight maybe unseating the head a little and lowering your max clocks, turn ya system on its side so the mobo's horizontal.
your PSU maybe a little weak when you pass your present CLK's with your x1900 OC'ed at full 3d load.
Maelstrom2160 is offline   Reply With Quote
Old 04-27-2006, 04:27 AM   #7
One_Hertz
One_Hertz's Avatar
resat the head, same god damn thing. My 1900xtx isnt oced right now so i doubt my psu isnt strong ehough...
yeah I saw a ss at 3.3ghz....
Coldbug doesnt make much sence to me here because I dont have any problems until I up the cpu speed past 2.5 and it never even goes unstable, it just bsods and thats it.
What I am concerneed about is that my mobo is bent a little because the condensation proofing in the back is a little big and is interfearing with my case. Could that screw up my mobo?
Another weird thing is that my computer is making a really weird noise coming from the block area and its not the block making that noise. It sounds exactly like a fan barely touching something plastic, but its definately no fan. I cant hear it from a meter away, but it still concerns me.
Old 04-27-2006, 04:30 AM   #8
CedricFP
CedricFP's Avatar
Something may be shorting the mobo if it's bending - though it seems unlikely.
CedricFP is offline   Reply With Quote
Old 04-27-2006, 04:37 AM   #9
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
The HTT 295 you did was that on phase or water? To check if its coldbug at 10x250 i would try to see how high you can get HTT using a lower multi. A weak drive strength and data drive might help a little if its the cold.
__________________
loc.o is offline   Reply With Quote
Old 04-27-2006, 07:19 AM   #10
v0dka
Hardware addict
v0dka's Avatar
What he said
__________________
Antec P180 Mini - DFI JR X58 T3H6 - Xeon W3570 - 6GB G.Skill 1333C7 - TRUE120 lapped & modded - GTX285 - Intel X25-M (G2) & Samsung F1 640GB
v0dka is offline   Reply With Quote
Old 04-27-2006, 10:15 AM   #11
Levish
Send a message via AIM to Levish Send a message via MSN to Levish
have you tried the burn in method?
go up from stock speed/volts and burn in for a hour then bump 1mhz.
I like to see the max speed at default vcores or near it before bumping
works for my fx60 which is currently 3130 @ 1.4vcore and still climbing, (I'm hoping for 3.2ghz @ 1.4 or more). I do have the luxury of unlocked multis
running 15x208
__________________
i7 @ 4000mhz 1.25vcore | Evga x58 | OCZ Gold 3x2GB | Powercolor HD4890
Levish is offline   Reply With Quote
Old 04-27-2006, 12:00 PM   #12
arisythila
arisythila's Avatar
-7 on the core is horrible.. My little tiny guy gets -29 to -35c on the core.
~Mike
__________________
AMD Phenom 2 940 @ 4Ghz (air)
Corsair Dominators 4 x 4gb (4-4-4-15 1T) 880 mhz
PCPC 1000w
DFI 790FX
Nvidia GTX290
EBAY:HEAT
arisythila is offline   Reply With Quote
Old 04-27-2006, 12:03 PM   #13
Levish
=P
might not do nearly so well with a dual core
__________________
Old 04-27-2006, 12:11 PM   #14
arisythila
arisythila's Avatar
yes, but This compressor is a 950 BTU unit, Vapochill is atlease a 3k BTU unit probably more.
~Mike
__________________
PCPC 1000w
DFI 790FX
Nvidia GTX290
EBAY:HEAT
Old 04-27-2006, 12:20 PM   #15
One_Hertz
One_Hertz's Avatar
~Mike
You cpu temp is -30C under max load? I really doubt that. The 295 htt is under phase btw... I will try a different cpu in a few days to check if it is coldbug.
Old 04-27-2006, 12:49 PM   #16
arisythila
arisythila's Avatar
under load I hit about -22c
~Mike
__________________
PCPC 1000w
DFI 790FX
Nvidia GTX290
EBAY:HEAT
Old 04-27-2006, 03:54 PM   #17
iboomalot
iboomalot's Avatar
arisythila FX-55 is a single core producing less heat thus lower temps
__________________
i7 920 @4.305 ghz (205*21 HT on) Prime stable@ 1.312v (Batch# 3844A717) your results may vary
i7 920 @4.410 ghz (210*21 HT on) 1hr Prime stable@ 1.39v (Batch# 3844A717) could push more but no reason too
Enzotech Heat Killer SCW-REV.A (very nice block 73c / 79c per above voltages)
GA-EX58-UD4P (Bios ????),, 6GB- OCZ3P1600LV6GK (7-7-7-20 @1640 mhz) 1:1
XFX-5870 with Swiftech nickel block
Water Cooling - TFC X-Changer 480 and 6-Scythe SFF21E fans @1000 rpm , Vario 655
Raid 0 velociraptors 600GB,, ZM1000-HP (powerfull and silent)
Mitsubishi 22" CRT
(old school ,,no input lag , no slow response times , true color reproduction & blacker blacks) its deep but so what
iboomalot is offline   Reply With Quote
Old 04-27-2006, 06:09 PM   #18
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
Try running SP2004 then clockgenning. If that works you're bugging
My LDBHE 3800+ cold bugged around -30c. The 3dmark scores also sucked on dice. Strange...
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 04-27-2006, 06:27 PM   #19
TheMeatFrog
Send a message via AIM to TheMeatFrog
That's basically how the cold bug works. It limits your htt, so you being fine up to say 250-260 is normal coldbug behavor. I got my old CCB1E chip up to 260x10 with dual p95 and clockgen but anything past that... pffft don't even think about it and that was with -7 temps!
I bet if you run a lower multi your max htt would probably be the same. Give it a try though, if you can get past around the same htt then you'll know it's not the coldbug holding you back.
__________________
Intel C2D E6300
DFI Blood-Iron P35
2x1GB Crucial Ballistix PC8500
BFG 8800GT OC 512MB
Corsair HX520
Heatware
TheMeatFrog is offline   Reply With Quote
Old 04-27-2006, 06:49 PM   #20
FragTek
Banned
FragTek's Avatar
Send a message via ICQ to FragTek Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
~Mike
What kind of unit are you using to hit that and yet call it "little"?
FragTek is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
